Anyone have a photo of rust on a 914?
Westy Steve
Westy Steve is offline
PostPosted: Sat Sep 10, 2016 5:14 pm    Post subject: Anyone have a photo of rust on a 914? Reply with quote
Hey guys,
I've researched this, but I can't seem to find a photo that shows me exactly where to look for rust in the Hell Hole and the Longitudinals (sp?) on a Porsche 914. I've found pictures showing these areas without rust, so I don't know where to look. And I know the hell hole is under the battery, but all the photos seem to have the batteries removed. See my dilemma?
So maybe I'm going about this all wrong. Does anyone have a picture of a badly rusted out Hellhole and Longitudinal on a 914? Or borderline rusty? Then I'd know what to avoid when I'm shopping around.
Thanks for any help,
Steve
Have nice 914, want nice Bug
slave1pilot
slave1pilot is offline
PostPosted: Sat Sep 10, 2016 5:55 pm    Post subject: Re: Anyone have a photo of rust on a 914? Reply with quote
Not being a porsche guy at all, I had to google what the F a hell hole and longitudinal actually were.
So after that quick education, I found this:
http://motorsport.zyyz.com/project_914_03_06.htm
hope that helps
My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle
Westy Steve
PostPosted: Sun Sep 11, 2016 9:24 pm    Post subject: Re: Anyone have a photo of rust on a 914? Reply with quote
hope that helps
You are the Jedi Master of Google. Thanks for the link. So apparently the Hell Hole runs parallel to the rear axle and can be accessed by removing some kind of body panel.
Reading that tech article, the guy went deep into it to fix the problems. I wonder if you could just reinforce it by adding extra metal? I guess the other question I have is whether you could improve on the design, like to use bar stock instead of something hollow? But I can understand avoiding the rust is the best solution.
Thanks,
Steve
falcor75
falcor75 is offline
PostPosted: Thu Sep 22, 2016 6:36 am    Post subject: Re: Anyone have a photo of rust on a 914? Reply with quote
The hellhole is just the common name for the lower part of the area under the battery. Rain and leaky batteries in combination with poor drainage from this area causes 914's to rust, once the rust goes thru the upper layer it spreads into the lower sections and the longs.
In the image above the hell hole is the recessed darker area left of the center of the image.
ALANSD
ALANSD is offline
PostPosted: Fri Oct 07, 2016 8:49 am    Post subject: Re: Anyone have a photo of rust on a 914? Reply with quote
the battery tray area is very prone to leaks, the acid get washed down by rain, etc
Wolfgangdieter
Wolfgangdieter is offline
PostPosted: Tue Oct 11, 2016 3:31 pm    Post subject: Re: Anyone have a photo of rust on a 914? Reply with quote
Always a good idea to remove 914 top and open both doors at same time. Run away if you can no longer shift vehicle or close the doors!.
CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy
Inverted Guzzler
Inverted Guzzler is offline
PostPosted: Wed Oct 12, 2016 3:58 am    Post subject: Re: Anyone have a photo of rust on a 914? Reply with quote
I have alot of rust pix on this site
https://buggleysgarage.shutterfly.com/pictures
look under the 1975
