DrVW Samba Member
Posted: Fri Sep 16, 2016 11:40 am Post subject: CV Axle Pop after Raising any ideas? |
So what do you do if you've rsised your thing and the CV's pop. You like the way it sits and would rsther not have to lower it. Is there a bolt on fix?? _________________ Gas prices killing you too? A VW Bug still holds up to today's cars with it's awesome gas mileage! |
Shoyrtt Samba Member
Joined: August 21, 2010 Posts: 1009 Location: Redlands, CA
It's a play thing Samba Member
Joined: November 19, 2009 Posts: 575 Location: Dayton, Nevada
Posted: Fri Sep 16, 2016 7:57 pm Post subject: Re: CV Axle Pop after Raising any ideas? |
The fix is 930 cvs, what has happened is you have to much angle in the CV joint. you can lower the car or install new CV's. _________________ It's not the size of your shop, it's what comes out of it that counts.
I've been playing with my thing ever since I got it... |
kubelmann Samba Member
Posted: Fri Sep 16, 2016 8:44 pm Post subject: Re: CV Axle Pop after Raising any ideas? |
Play Thing offers good advise and here are the numbers that support his help
Degrees of non binding articulation.
Type 1 is 12 degrees
Type 2 is 17 degrees
Type 4 is 22 degrees
930 is 25 degrees
Diameter of CV
Type 1 = 94mm
Type 4 = 100mm
Type 2 = 100mm
930 = 108mm |
Posted: Fri Sep 16, 2016 9:00 pm Post subject: Re: CV Axle Pop after Raising any ideas? |
Great add-on, very helpful, thanks _________________ It's not the size of your shop, it's what comes out of it that counts.
Posted: Fri Sep 16, 2016 9:12 pm Post subject: Re: CV Axle Pop after Raising any ideas? |
Thanks... Glad its useful.. I have jsut been helping a few folks decide how to rig their various rear suspension to gain the best combo for their desired use.
Bus/Type 2 (100mm) Thing/Type4 (100mm)
Although the Type 2 and 4 Cvs have the same diameter the type 4 gains 5 degrees of articulation due to using a larger inner CV knuckle and smaller CV balls Hence the best reason to not use type 2 CVs on a Type 4 vehicle. |
DrVW Samba Member
Posted: Sat Sep 17, 2016 10:43 pm Post subject: Re: CV Axle Pop after Raising any ideas? |
Lowered the back popping stopped. Ill live with it. Thanks for the useful info. _________________ Gas prices killing you too? A VW Bug still holds up to today's cars with it's awesome gas mileage! |
limon Samba Member
Joined: September 05, 2013 Posts: 45 Location: United States
Posted: Sun Nov 12, 2017 9:46 am Post subject: Re: CV Axle Pop after Raising any ideas? |
I installed an imported axle/CV combo thinking I'd stay cleaner and have some spare parts too.
The new axle/CVs were binding horribly (I've raised my Thing one "tooth" on the spring plates).
Bought a Rockford boot kit from a type 2 supplier and reinstalled my originals so now everything is fine.
Inspecting the Chinese axle; it wasn't indexed correctly when it was assembled, I don't know if reindexing will fix the binding, or if the knockoffs just can't handle the same angles as originals.
