Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Wed Feb 04, 2015 5:55 am Post subject: |
westylife wrote: |
This is awesome! I wish I saw this before I bought the GW bumper set. They want another $350.00 for their swing away that attaches to their bumper.
As far as securing the swing away to the bumper: How about using a high tension quick release pin? People in the military will recognize these with the "Remove before flight" streamer attached to them
http://www.avibank.com/index.cfm?fuseaction=home.prods&product_id=16
Great Job! Looks fantastic!
Westylife. |
Just remember to keep them lubricated! |
Vanagator Samba Member
Joined: January 14, 2009 Posts: 230 Location: Cool lush mountains in Mexico
Posted: Mon Sep 19, 2016 6:53 pm Post subject: Re: Bumper, Hitch & Tire/Fuel swing away build |
Great job SSWesty. How's it working out?
I'm planning on merging some of your design for a swing out bike rack.
How much would you say the whole bumper and one swing arm would weight? any idea?
Thanks again..... |
Posted: Wed Sep 21, 2016 3:43 pm Post subject: Re: Bumper, Hitch & Tire/Fuel swing away build |
I would like a swing out bike rack that supports two mountain bikes. I'm using part of this design in this post for my new swing away-bike rack, which will be mounted to a new rear bumper as well.
I'm on the drawing board now. I'm thinking of using my existing steel mounts to beef up the bumper to support the swing arm for bikes, similar to what SSWESTY has going on.
One issue is the end of the mounts I have are not plumb vertically. So my idea is to weld on some angle iron, kinda like this....
Not sure if this is a good idea or not yet. My other option would be to not use them at all and build an all new mounting bracket similar to bracket in above pics.
Any thoughts? |
Zeitgeist 13 Samba Member
Posted: Wed Sep 21, 2016 8:22 pm Post subject: Re: Bumper, Hitch & Tire/Fuel swing away build |
I'm trying to figure out how to build my own swing away tire carrier like this that still uses the stock fibreglass rear bumper _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Fri Sep 23, 2016 7:30 am Post subject: Re: Bumper, Hitch & Tire/Fuel swing away build |
Zeitgeist 13 wrote: |
I'm trying to figure out how to build my own swing away tire carrier like this that still uses the stock fibreglass rear bumper |
Yes, me too. Its a drag that these bumper mounts are not true vertical as I would like to have a vertical face on the new bumper.
Also, if you look at this guys thread pics, I dont know how he reinforced the inside-end of the bumper where the swing-arm mount goes. I would think you'd need extra support there. |
SSWesty Samba Member
Joined: August 20, 2008 Posts: 732 Location: Bellevue
Posted: Wed Feb 26, 2020 12:00 am Post subject: Re: Bumper, Hitch & Tire/Fuel swing away build |
Oh boy it's been about 5 years since I've touched this thread and missed a couple questions.
Weight - I don't have an exact weight but it's probably around 50 pounds.
Corner bracing - Where the swing-outs attach it caused the bumper to twist a little when the swing-outs where open. I added a gusset during the build on the back side of the bumper that ties into the end cap and that firmed it up.
Pivot points - Even though this is just metal on metal with no bushings or bearings they work fine. I don't really see that much wear if any on the swing-outs. They probably only get opened about 30 times a year if that.
One bump test - I backed into a tree one night in the middle of no where and hit the corner. Didn't even scuff the rattle can paint but did collect a small bark sample on the bumper. Thankfully that has been it in terms of impact. |
heynanc Samba Member
Joined: September 13, 2013 Posts: 35 Location: North Carolina
Posted: Tue May 16, 2023 8:50 am Post subject: Re: Bumper, Hitch & Tire/Fuel swing away build |
I’m now contemplating the rear bumper/hitch project. First, I’d like to say THANK YOU to SS for his beautiful work and posting and pics. I’m curious if the other folks on the thread would be willing to share what they ended up doing? _________________ Nancy
2011 Subaru Outback daily driver
1975 “art bus” transporter “Cherry Garcia”
1984 Westfailia Vanagon EJ22 “ Guinness”
2006 Dodge Sprinter (long/tall)
2006 Winnebago View (in case the buses aren’t cooperating) |
