Looking for engine stand tester
Thomas333is
Thomas333is is offline
PostPosted: Sun Sep 25, 2016 6:34 pm    Post subject: Looking for engine stand tester Reply with quote
Hi all
I just bought dual port 1600cc and need start the engine outside from the car. I want to check compressor, oil leak....ecr before I tear down engine
Anyone know or do home made stand tester?
Thanks
retterath
retterath is offline
PostPosted: Sun Sep 25, 2016 7:17 pm    Post subject: Re: Looking for engine stand tester Reply with quote
A 3 rib bus bell housing will let you attach a starter. Gravity feed gas tank and a battery should let you run it on the floor.
Thomas333is
PostPosted: Sun Sep 25, 2016 7:44 pm    Post subject: Re: Looking for engine stand tester Reply with quote
You mean that bell housing from
Bus can fit to our Bug? And the engine can sit on the floor? Don't really need stand?
Thanjs
enjoyther1de
enjoyther1de is offline
PostPosted: Sun Sep 25, 2016 8:56 pm    Post subject: Re: Looking for engine stand tester Reply with quote
You can cut the bell housing off a t1 trans and build your own.
Or maybe try and borrow one.
Oh, do yourself a favor and put it on a table so you can work upright.
HBB took me to BBV.
early
early is offline
PostPosted: Mon Sep 26, 2016 7:25 am    Post subject: Re: Looking for engine stand tester Reply with quote
here is one we built from an old Transaxle .
battery is connected, gas from gas can fed to steel fuel line, remote starter button.
engine sitting on a 4 wheel Dolly running on the floor
early-
my 73 sports bug project build
http://www.thesamba.com/vw/forum/viewtopic.php?t=497088
Current Projects :
73 Sport Bug - L13M
68 Corvette Roadster - Small Block, 4 Speed
86 GMC Sierra Classic- 4x4, Shortbed
94 Harley Flstn
03 BMW R1150RT
Thomas333is
PostPosted: Mon Sep 26, 2016 8:58 am    Post subject: Re: Looking for engine stand tester Reply with quote
Thankyou. Soon I get transaxle I let engine sit on dolley and start it
Thanks again
Thomas
pwmcguire
pwmcguire is offline
PostPosted: Mon Sep 26, 2016 1:33 pm    Post subject: Re: Looking for engine stand tester Reply with quote
Cut 3 mounting holes on the transmission. Like the picture
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Sep 26, 2016 1:42 pm    Post subject: Re: Looking for engine stand tester Reply with quote
Please use the existing topic: http://www.thesamba.com/vw/forum/viewtopic.php?t=380203
Glenn
Cast Iron and Aluminum distributors rebuilt since 2000.
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Beetle - Late Model/Super - 1968-up All times are Mountain Standard Time/Pacific Daylight Savings Time
