How to remove side cover v channel bracket
orwell84
orwell84 is offline
PostPosted: Tue Sep 27, 2016 6:09 am    Post subject: How to remove side cover v channel bracket Reply with quote
Don't what its called exactly. I would like to get it off without wrecking it so that I can get everything free of rust. I would love to find something better to hold the covers on. Those pieces are rust magnets. Thanks for the help.
aeromech
aeromech is offline
PostPosted: Tue Sep 27, 2016 6:23 am    Post subject: Re: How to remove side cover v channel bracket Reply with quote
I wish I knew what you're talking about
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
alman72
alman72 is offline
PostPosted: Tue Sep 27, 2016 6:37 am    Post subject: Re: How to remove side cover v channel bracket Reply with quote
the clips that hold on the rear beltlines? under the side rear windows?
orwell84
orwell84 is offline
PostPosted: Tue Sep 27, 2016 6:55 am    Post subject: Re: How to remove side cover v channel bracket Reply with quote
yes thats it.
busdaddy
busdaddy is offline
PostPosted: Tue Sep 27, 2016 7:25 am    Post subject: Re: How to remove side cover v channel bracket Reply with quote
Invest in a spot weld cutter and start cleaning, there's a spot weld down in each of the notches. You may have better luck drilling small pilot holes from inside the bus, the welds are in the wavy section below the windows, the waves are there to make room for the spot welders electrodes.
Слава Україні!
orwell84
orwell84 is offline
PostPosted: Tue Sep 27, 2016 8:01 am    Post subject: Re: How to remove side cover v channel bracket Reply with quote
yes thats it.
airschooled
Air-Schooled
airschooled is offline
PostPosted: Tue Sep 27, 2016 8:26 am    Post subject: Re: How to remove side cover v channel bracket Reply with quote
Please let us know what you find. Shocked
Learn how your vintage VW works. And why it doesn't!
www.airschooled.com
williamM
williamM is offline
PostPosted: Tue Sep 27, 2016 8:32 am    Post subject: Re: How to remove side cover v channel bracket Reply with quote
can you take pics- I still don't know what your working on or the "covers" your are talking about.
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
alman72
alman72 is offline
PostPosted: Tue Sep 27, 2016 8:45 am    Post subject: Re: How to remove side cover v channel bracket Reply with quote
he said it was the clips that hold on the rear side beltlines.
the beltlines being the removable pieces under the side rear windows
orwell84
orwell84 is offline
PostPosted: Tue Sep 27, 2016 1:21 pm    Post subject: Re: How to remove side cover v channel bracket Reply with quote
I always wondered about the wavy lines. I have found replacements so I may just grind them off. I do have a resistance spot welder too. Not sure if the tongs are long enough. Thanks.
1967250s
1967250s is offline
PostPosted: Tue Sep 27, 2016 6:33 pm    Post subject: Re: How to remove side cover v channel bracket Reply with quote
Looks like most of the rust is above the groove section on the window outer section. If you carefully remove it, treat/remove the rust, you might be able to re-use the original piece. It looks to be in pretty good shape.
'72 Elm Green Deluxe
williamM
williamM is offline
PostPosted: Tue Sep 27, 2016 7:23 pm    Post subject: Re: How to remove side cover v channel bracket Reply with quote
I've only see a 2 bolt and a 3 bolt design for holding that piece Also saw a wedge rod with screw to suck it long the shelf. and wedge the piece in place. will try to get you some pics-- the wedge rod was on the 68 bay parts carcass I got for the roof.
Would not weld or glue that piece as pretty sure you'll wand to take it off in the future
Here is how the wedge lock works-
.[img]
[/img][img]
[/img]
If you brighten up this next pic 9it wouldn't load for me ) you will see a small nut holding the side cover in place just on the body near that pointy thing.
[img]
[/img]
This panel on the passengers side with the sliding door only has 2 philips head screws and a small nut holding it on- one on the back welded tab, one on the cast bump latch stop down low and the small nut. a quick rap with a dowel and hammer will pop it off. The passengers side may have 3 screws. and a nut- again just tap it straight up.
Don't step in any!
orwell84
orwell84 is offline
PostPosted: Wed Sep 28, 2016 3:45 am    Post subject: Re: How to remove side cover v channel bracket Reply with quote
Thanks that would be helpful.
orwell84
orwell84 is offline
PostPosted: Wed Sep 28, 2016 5:31 am    Post subject: Re: How to remove side cover v channel bracket Reply with quote
I found this. Seems like I could bolt these on so that I could remove them if rust ever became a problem again. Properly painting and sealing and installing the plastic trim would no doubt help too.
http://www.busdepot.com/8320
orwell84
orwell84 is offline
PostPosted: Thu Sep 29, 2016 2:30 am    Post subject: Re: How to remove side cover v channel bracket Reply with quote
Many thanks WilliamM! Very Happy
williamM
williamM is offline
PostPosted: Fri Sep 30, 2016 12:10 am    Post subject: Re: How to remove side cover v channel bracket Reply with quote
my 73 didn't have the wedge bar , just a tight fit in the channel with the bead in there. the 78 didn't have the bead- just the channel and screws and one nut.
Don't step in any!
