67ctbug Samba Member
Posted: Thu Sep 15, 2016 2:27 pm Post subject: 1967 Beetle Pan |
I'm trying to install the pan and I think I'll have to get a new one. I want to plug weld, but my measurements are off so there is no way I can do that with these pans. Here's a picture
Also it doesn't close at the end
_________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
Posted: Fri Sep 16, 2016 4:16 am Post subject: Re: 1967 Beetle Pan |
To me it looks like you got a repair pan rather than a full pan. |
Posted: Fri Sep 16, 2016 4:43 am Post subject: Re: 1967 Beetle Pan |
No it's a full pan
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
chopped73beetle Samba Member
Posted: Tue Sep 27, 2016 2:22 pm Post subject: Re: 1967 Beetle Pan |
Where in ct are you? I'm doing pans and rocker on the passenger side this month. This will be my third time doing it on separate bugs. I bought the Wolfsburgwest pans and it fit like a glove , no trimming at all.
The way i do floors is remove old floor and test fit the new floor and then fit the body back on, Making sure the hardware fits up.
what floors did you get? Are you doing rockers too? |
Posted: Tue Sep 27, 2016 2:52 pm Post subject: Re: 1967 Beetle Pan |
I'm in Manchester. I got floors from Johns Car Corner in VT. If by rockers you mean heater channels, then yes. I'm actually planning on getting Wolfsburg west pans as these ones are ruined now. The edge isn't large enough, they're rusting, and an unplanned rainstorm filled them with water for a few days. They are also like 21 or 22 gauge. It's good to hear the WW ons fit as I really don't like having to trim them as I also think I'll mess up . _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Wed Oct 05, 2016 7:10 am Post subject: Re: 1967 Beetle Pan |
I've been messing with my floors and I'm a bit upset. They wouldn't sit flat so I removed the rear support and welded that to the floor. Well that went on crooked and it didn't work . This is becoming a real fiasco! _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Posted: Sat Oct 15, 2016 6:35 pm Post subject: Re: 1967 Beetle Pan |
from large photo you uploaded, it looks like there's room to trim some metal off on the back, inside edge (near the "transmission tunnel". That should allow the section by seat rail (as shown in your first photo) to fit closer to the tunnel .... _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Posted: Sat Oct 15, 2016 7:26 pm Post subject: Re: 1967 Beetle Pan |
Yes sir there was and I did, but there's still a 1/4 inch gap. I also had to shave some off the front on the passenger(this is where I tested cutting near the transmission) I cut too much up there and now it won't be able to get welded up front. So many problems I know! _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
And it still won't sit flat _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sun Oct 16, 2016 10:43 am Post subject: Re: 1967 Beetle Pan |
Do these crappy pans also have crappy seat rails? My crappy pan's seat rails appear to be made out the same thin gauge metal as the pans ...whereas the OEM pan rails used MUCH heavier gauge metal. SO ...more work to cut the crappy rails off the crappy pans; cut the good rails off the rusty pans and weld them onto the crappy pans. More expensive, better fitting pans are looking more and more like a less expensive option in the long run .... _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Posted: Sun Oct 16, 2016 11:00 am Post subject: Re: 1967 Beetle Pan |
Digger89L wrote: |
...More expensive, better fitting pans are looking more and more like a less expensive option in the long run .... |
This is exactly what I'm beginning to think. This wouldn't of happened if the guy at WW knew what he was talking about. I called and asked when pans would be in stock. He said about 6 weeks. I said alright and went to VT for pans. The next day WW had them in stock . And yes they have the tracks as the same gauge of pan metal. Sorry for my little rant. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Sun Oct 16, 2016 11:11 am Post subject: Re: 1967 Beetle Pan |
That indeed is a bummer ...obviously the guys who make these pans don't have an engineer on staff!!
I wonder if the new, weld-on seat tracks (http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=113701421D) or (http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC-113-701-435) are made of proper-thickness steel? At least using these would eliminate one step in replacing crappy tracks .... _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Posted: Sun Oct 16, 2016 11:26 am Post subject: Re: 1967 Beetle Pan |
I'm going to get some WW pans and I heard they have good solid tracks. Is this not true? _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Mon Oct 17, 2016 2:22 pm Post subject: Re: 1967 Beetle Pan |
I'm posting pics of the old pans to see if I can get opinions on if I should use them. They predict it'll start snowing by the end of the month so I have to hurry. Is it okay if I use these?
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
Posted: Mon Oct 17, 2016 2:49 pm Post subject: Re: 1967 Beetle Pan |
I think if you tack-weld them to the tunnel flange along the edge of the pan (where you don't have room to drill holes and do it that way) ....and do it on the top-side AND bottom-side, you should be okay. Maybe have a tack-weld every half-inch or so when you're done. Do the drill-holes-in-the-pan-and-weld-thru in the places where there is room to do that. Clean up the welding with a flap-disk on the grinder, and cover with seam-sealer ...good to go. IMO _________________ "If you can't fix it with pop rivets, crazy glue and duct tape, or hold it together with zip ties, velcro or magnets, it REALLY is broken." |
Posted: Mon Oct 17, 2016 2:54 pm Post subject: Re: 1967 Beetle Pan |
Alright one last problem, those supports for it don't sit flat on the pan. _________________ '67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
KentPS wrote: |
mukluk wrote: |
