Spot Weld Cutters
Page: Previous  1, 2, 3, 4
spectre6000
spectre6000 is offline
PostPosted: Sun Nov 15, 2009 5:42 pm    Post subject: Reply with quote
I've been using the above Blair cutter in a regular drill, and it works pretty well insofar as I can tell. I got 312 welds cut with the first cutter (comes with three) before I decided to go ahead and change it (probably could have done quite a few more if I wanted to stretch it), so it seems to be reasonably durable.
Jason Hopper
-'58 German Market Deluxe Beetle (in progress)
-'84 M1009 CUCV
-'81 K10
"Buy the best, cry once." -Gene Berg
"A cheap man will always buy the cheapest thing available, and then buys another one hoping for a better result, and then spends the rest of his life in misery complaining about it. A thrifty man will buy a good part once and never think about it again." -RockCrusher
"Don't feed the Shitty Parts Monster!" -Me
WrennMetallWerks
WrennMetallWerks is offline
PostPosted: Sun Nov 29, 2009 11:44 pm    Post subject: Reply with quote
zuggbug wrote:
jmillers62 wrote:
I just bought this one.
I'll never use anything else.
I have been using these bits with a drill - very slow go and a lot of elbow grease - I just bought a Rigid impac driver
had to modify the bit a little but MAN!!!! Very Happy Very Happy it cut thru the metal like a hot knife cuts thru butter.
has it seemed to be long lasting for you... mine seem to work great at first but then lost its fight and just wanted to jump around... then again.. i made it thru a whole split bus roof transplant.. just for the price i hoped it wud had lasted me longer... Laughing Laughing Laughing
⚒ Believe In The Power Of Positive Thinking ⚒
Purpose Over Pleasure 🕊
“Hard Werk ⚒ God First “
https://music.youtube.com/watch?v=0-PSeV52tZ4&si=wpcuRnQyvIFo2nCJ
https://music.youtube.com/watch?v=PaCorLXzC5w&si=cbzT8fjlzVlIWfSV
https://music.youtube.com/watch?v=_aoE5aYSutY&si=mkZKPxd_41QA1kfs
https://music.youtube.com/watch?v=_NzUyyVexAE&feature=share
https://music.youtube.com/watch?v=UI8yUrIWS7E&feature=share
burnt63
burnt63 is offline
PostPosted: Mon Nov 08, 2010 3:31 pm    Post subject: Reply with quote
The_Codeman wrote:
is used one of these from harbor freight when i replaced my front apron/tire tray.
3/8 is a little large but it did work very well for $4
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=95343
codeman
i used this to remove a rear apron. did the job with no problems. 3/8 was a little large like mentioned before.
'63 bug...'67 bug... '87 cabriolet... '08 rabbit
View user's profile Send private message Instagram Classifieds Feedback
noexit
noexit is offline
PostPosted: Fri Dec 31, 2010 1:17 am    Post subject: Reply with quote
codeman
I used the harbor freight one to remove my floor pans. I wire bush everything to get the spot welds to show themselves, then hit each weld with a punch to keep the bit from walking. Apply moderate pressure for the first few seconds while the blade starts to cut, then you can bear down on it. You'll often hear a pop of feel it give when it breaks through the first layer.
girlnouveau
girlnouveau is offline
PostPosted: Sat Apr 09, 2011 7:44 pm    Post subject: Reply with quote
I have a 7amp B&D drill and picked up some of those bullet/pilot tips drill bits in 1/8 people recommended. They did a nice job on my headlight buckets.
Before my Bug, my tools were only used for random household or art projects. I went through like 10 before it even occurred to me that maybe it wasn't right for the job. Any new tools I bought for the Bug I got heavy duty ones, the ones I already had, I didn't even think about it.
Truth be told I was using my husband's scratch awl to center punch, and then I broke it after 8 spot welds. (Brilliant, I know.) Without the punch the drill seemed to struggle and I didn't want to bear down on it and then break the drill too.
What's a good sized regular drill for this job?
Getting a real center punch is on my to-do list tomorrow.
AutoGuru
AutoGuru is offline
PostPosted: Tue May 03, 2011 10:04 am    Post subject: We use ABDS spot weld cutters Reply with quote
We found these guys a few months ago and have been using there bits ever since. I spoke with the owner and they specialize in spot weld cutters, USA made. They are tough as nails and priced well. I think the owners name is Mike.
http://www.autobodydrill.com/
[/url]
WoodyAlan
WoodyAlan is offline
PostPosted: Wed Jun 01, 2011 5:26 am    Post subject: Reply with quote
Used a step drill bit on my bus floor to remove welds; fast and easy;
Cheap set from Harbor Great did the trick.
"My other car is a VW"
'90 Cabriolet
'03 Passat GLX Wagon
Aircooled gone but not forgotten!
ALIEN3T
ALIEN3T is offline
PostPosted: Thu Oct 06, 2011 8:58 pm    Post subject: Re: We use ABDS spot weld cutters Reply with quote
[/url]
I like the prices and choices from here.
Does anyone know what spot weld cutters from here be the best. and what diameter? I'm ready to order them but the company has no phone number on the site. The work I'm doing I'm at a stand still till i split all the spot welds. I tried the HF hole bit looking one, Keeps going through both pieces to easy. Some weld I'm removing for good, Some I'm splitting then want to be able to reattach later.
Thank you.
Evil_Fiz
Evil_Fiz is offline
PostPosted: Sat Oct 29, 2016 5:03 pm    Post subject: Reply with quote
noexit wrote:
...I used the harbor freight one to remove my floor pans. I wire bush everything to get the spot welds to show themselves, then hit each weld with a punch to keep the bit from walking. Apply moderate pressure for the first few seconds while the blade starts to cut, then you can bear down on it. You'll often hear a pop of feel it give when it breaks through the first layer.
I followed the same process with the HF spot weld cutter. It was $5 and I did about 125 floor pan spot welds with one side of the cutter before I had to flip it over. I did not have any of the sticky cutting oil/compound many have recommended but WD-40 and low speed worked just as well.
“…It's not just about what's interesting. It's also about what's helpful, and it's helpful even if it helps just one other guy working on a Ghia.”
kiwighia68
See my build on TheSamba at:
The K_R_A_K_E_N_N : a 70 Ghia Convertible reinterpreted
Busstom
Busstom is offline
PostPosted: Tue Sep 04, 2018 11:24 am    Post subject: Reply with quote
KYbuggy1 wrote:
I drill more spot welds than I care to remember, every day practically. This is the back , elbow and wrist saving"est" tool I've ever purchased:
http://www.dentfix.com/viewItem.asp?idProduct=17&a...SS_Capable
Nearly effortless.
Hard to swallow the price at first, but WELL worth it in the long run. A hobbyist would never wear it out if it wasnt abused. Comes with an inline oiler attached.
And if you cant get to the backside, you can remove the clamp and it still works better than any spotcutter bit out there, and I've tried every single new thing that came along on the tool trucks until I bought the spitznagel.
The link above is dead, here is an updated link:
https://www.dentfix.com/shop-1/Spot-Annihilator-Deluxe-Kit-p65881292
Page 4 of 4
