sslick Samba Member
Posted: Sat Oct 29, 2016 4:36 pm Post subject: Deck height tolerance for compression ratio? |
So, my deck height is within .003 of the specified height given on the vw engine calculator to achieve an 8.5:1 compression ratio. What is an acceptable tolerance for deck height between each cylinder and also what is an acceptable deviation from a given deck height on the engine calculator? |
ps2375 Samba Member
Joined: April 24, 2014 Posts: 2471 Location: Meridian,ID
Posted: Sat Oct 29, 2016 8:01 pm Post subject: Re: Deck height tolerance for compression ratio? |
Depending upon which calculator you use, as some only go one decimal place and others may go two. That much is pretty close. You'll want to check that the tops of cylinders are even with a good straight edge. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
sslick Samba Member
Posted: Sat Oct 29, 2016 8:13 pm Post subject: Re: Deck height tolerance for compression ratio? |
ps2375 wrote: |
The CB performance calculator goes three decimal places (.xxx). |
sslick Samba Member
Posted: Sat Oct 29, 2016 8:23 pm Post subject: Re: Deck height tolerance for compression ratio? |
I did, Glenn. I plugged the numbers into the CB calculator. Here are my figures: 64mm stroke, 83mm bore, one head is 43cc, the other is 44cc. I am looking for 8.5:1 comp ratio. The calculator says .023 deck for the 43cc head and .016 for the 44cc head. My actual measurements of deck height on my engine are: cyl#1&2=.019 and #3=.022, #4=.025. so, I am wondering if using the 43cc head on #3&4 and the 44cc head on #1&2 would be recommended? |
sled Samba Member
Posted: Sat Oct 29, 2016 11:18 pm Post subject: Re: Deck height tolerance for compression ratio? |
Those are very tight deck heights. Maybe you want to flycut the heads slightly to achieve your desired comp ratio?
You definitely run the risk of having the Pistons collide with the chamber at .016 deck (as well as the engine going "solid" at higher Rpms) Many people say .030-.040 is minimum safe limit. _________________ drive your split. |
sslick Samba Member
Posted: Sun Oct 30, 2016 4:18 am Post subject: Re: Deck height tolerance for compression ratio? |
sled wrote: |
You definitely run the risk of having the Pistons collide with the chamber at .016 deck (as well as the engine going "solid" at higher Rpms) Many people say .030-.040 is minimum safe limit. |
Ok, I hear you. Here's another idea...if I run 8:1 comp (instead of 8.5), my deck for the 43cc head calculates out to .047, and .040 for the 44cc head. What if I remove a few thousandths from the barrels and add shims to get the deck where it needs to be? #1&2 measure the same deck height but 3&4 are .022 and .025. Is that .003 difference going to give me problems? I know I cannot remove an unequal amount from the barrels on that side of the engine...the head would not sit flat. |
sled Samba Member
Posted: Sun Oct 30, 2016 9:05 am Post subject: Re: Deck height tolerance for compression ratio? |
Im not sure why you would need to remove anything from the cylinders, just use shims between the cylinders and the case to increase your deck height.
what engine is this for, seems like a 40 horse? what cam are you running that you want 8.5:1 comp?
I'd shoot for .045 - .050 deck height for a 40 horse with stock internals. .050 is plenty tight to give you some squish. The chamber design of 40 heads is more of a limiting factor when being concerned with squish. _________________ drive your split. |
sslick Samba Member
Posted: Sun Oct 30, 2016 9:27 am Post subject: Re: Deck height tolerance for compression ratio? |
sled wrote: |
Im not sure why you would need to remove anything from the cylinders, just use shims between the cylinders and the case to increase your deck height. |
Because shims are only available in .010 increments, in order to achieve the 8:1 compression and the required .047 deck (on the 43cc head) and the .040 deck (on the 44cc head), I would have to remove some material from the cylinders and then shim accordingly. I listed my current deck height above.
sled wrote: |
what engine is this for, seems like a 40 horse? what cam are you running that you want 8.5:1 comp? |
This is for a big bore 40hp with an Engle w100 cam. I have had second thoughts on the 8.5 compression based on the low deck height and possibility of collision
sled wrote: |
I'd shoot for .045 - .050 deck height for a 40 horse with stock internals. .050 is plenty tight to give you some squish. The chamber design of 40 heads is more of a limiting factor when being concerned with squish. |
I am using early type 3 heads which have been flycut for this engine (maybe flycut too deep?) |
Kjell Roar Samba Member
Joined: December 08, 2008 Posts: 1326 Location: Norway
Posted: Tue Nov 01, 2016 10:06 am Post subject: Re: Deck height tolerance for compression ratio? |
A good tinsmith can make you some spacers in different thickness... _________________ I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438 |
ps2375 Samba Member
Posted: Wed Nov 02, 2016 1:08 pm Post subject: Re: Deck height tolerance for compression ratio? |
sslick wrote: |
ps2375 wrote: |
The CR only goes 1 decimal place. |
modok Samba Member
Posted: Tue Nov 22, 2016 9:52 pm Post subject: Re: Deck height tolerance for compression ratio? |
.042-.058"
no more than .008 variance
"racing" or 'blueprinted" tolerances, cut that in half |
bugmandave Samba Member
Joined: December 30, 2005 Posts: 642 Location: Illinois
Posted: Sat Jan 07, 2017 7:39 am Post subject: Re: Deck height tolerance for compression ratio? |
My deck height is .017 on a 69 x 83 40hp with 7.9:1 cr . Mild cam with 1.1:1 rockers too. 2 years and over 3000 miles with no issues. I got my .100 inch cylinder shims made by Rimco. _________________ '63 Karmann Cabriolet L456 Rubin (Ruby Red)
'71 Westfalia campmobile tourist delivery
January '59 SWR panel
'63 Karmann Cabriolet L54 Poppy Red |
bastardbus Samba Member
Joined: July 13, 2000 Posts: 1768 Location: Toledo, Ohio
Posted: Sun Apr 26, 2020 9:40 pm Post subject: Re: Deck height tolerance for compression ratio? |
bugmandave wrote: |
My deck height is .017 on a 69 x 83 40hp with 7.9:1 cr . Mild cam with 1.1:1 rockers too. 2 years and over 3000 miles with no issues. I got my .100 inch cylinder shims made by Rimco. |
Those numbers come out to around 9-1 comp ratio with 43-45CC stock heads. Where did you get 7.9-1 from?? Did you really open up your head chambers or something. _________________ Samba Member #95 |
