xzener Samba Member
Posted: Tue Nov 01, 2016 8:47 pm Post subject: Noisy Shifting |
Hello everyone,
Is there a way to silence a clunky, metal-on-metal, noisy shifter?? Moving the shifter side to side while in neutral sounds horrible. Is there a bushing or something that I can replace/install for smooth, silent shifting??
Thanks guys. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Paul70Ghia Samba Member
Posted: Wed Nov 02, 2016 12:28 am Post subject: Re: Noisy Shifting |
There's a nylon bush in the centre tunnel about three inches behind the shift rod - these wear and split leaving the shift rod to hit the metal hanger which is the unpleasant noise you're getting. If you search shift rod bush there are plenty of articles on how to replace. Bit fiddly but not difficult- takes an hour or so but makes big improvement to shift quality
Moderator Edit: Shift rod bushing Replacement - Cheater Method |
xzener Samba Member
Posted: Wed Nov 02, 2016 7:02 am Post subject: Re: Noisy Shifting |
Thanks Paul70Ghia,
After searching the correct wording, I did find a couple articles. JBUGS even has a great write up and YouTube video. Have the part on order, looking forward to a smooth/quiet shift soon.
http://www.jbugs.com/product/video-shifter-rebuild.html
Thanks again! _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
c21darrel Samba Member
xzener Samba Member
Posted: Wed Nov 02, 2016 3:49 pm Post subject: Re: Noisy Shifting |
I will have a look when I take things apart... Is the urethane one the way to go? Always heard urethane bushings were squeaky, not necessarily this one in particular. I think it was a swing arm bushing that was squeaky. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Wed Nov 02, 2016 8:41 pm Post subject: Re: Noisy Shifting |
Purchased. Thanks C21Darrel! _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Tue Nov 08, 2016 5:46 pm Post subject: Re: Noisy Shifting |
Replaced and test drove. Shifts quieter and smooth. After sound deadening material, carpet, upholstery... Probably won't hear a thing. Very happy with the results. Recommend this afternoon project to everyone, quick and easy. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
xzener Samba Member
Posted: Tue Nov 08, 2016 6:26 pm Post subject: Re: Noisy Shifting |
Haha! Nice one... Actually drove to my local Vdub guy for a look at why it won't idle. My first drive after purchasing it. After it struggles through 1st and 2nd, it really wants to go. Such a fun car to drive. Must have looked pretty funny driving a car with no windows. Couldn't hear anything but the wind going through my hair. 😏 _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
calexican Samba Member
Joined: June 11, 2008 Posts: 730 Location: El Paso, TX
Posted: Sun Dec 20, 2020 8:43 am Post subject: Re: Noisy Shifting |
Kind of an old post.... but thought I would share my experience. I was having smooth shifting, but a squeaky shifting situation.... so I figured shift rod bushing...when I went to replace it, I noticed that there wasn’t an old one to replace... and the new one would not fit... checked the Bentley manual, and sure enough, up to a certain chassis number there is no bushing.... so anyway, I cleaned the shift rod and greased up the guide, works perfectly.... so in the future I’ll just need to grease that spot just behind the shifter... chocked that one up for experience. |
Posted: Sun Dec 20, 2020 10:17 am Post subject: Re: Noisy Shifting |
Notice no clip either in this illustration.
The Haynes manual has the clip in the illustration. |
dualport Samba Member
Posted: Sun Feb 28, 2021 6:15 pm Post subject: Re: Noisy Shifting |
Thanks very much for this call-out. I was worried that someone fashioned their I am working on a '57 pan and am frustrated with the shifting action on the new transmission.
I guess the only thing I'll be able to do is keep sanding/smoothing the shift rod as it has gotten really corroded over the years. I'll probably need to upgrade my shifter as the '59 donor shifter pin is nearly gone.
calexican wrote: |
_________________ Conrad @ Air Coolers VW Gang http://aircoolers.org
Air Coolers Google Map of clubs, services and shops: https://goo.gl/3KM4wm |
