Syncro Jael Samba Member
Posted: Fri Jul 18, 2014 8:29 am Post subject: |
I have a couple Allstate single wheel trailers and have thought about the Syncro pulling one. What is nice is you cannot "jackknife" one and my wife has no issues backing up a single wheel trailer
Here is a photo of my old wooden Allstate.
_________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6245 Location: Portland OR
costal_cat Samba Member
Posted: Mon Jul 21, 2014 2:45 pm Post subject: |
I have this run away trailer... Pulls great , has AC , my wife and i fit in there comfortably while the kids kick it in the van when camping.
here are some pics
I got this last fall. Since I have added new springs to the van and a 3 in drop hitch which leveled it all out.
I also added a carrier to the top of the trailer for bikes and such.... _________________ 87 Syncro Westy
TDI Overland Parts engine conversion |
alaskadan Samba Member
Joined: January 09, 2013 Posts: 1857 Location: anchor pt. alaska
Posted: Mon Jul 21, 2014 7:22 pm Post subject: |
Syncro Jael wrote: |
Thats pretty cool. That looks alot earlier than the one Ive been seeing. It has a metal box around the perimeter reminiscent of an early tent trailer. Now that I was gonna get a pic it has moved! Been there for years. Im not sure about it being behind my syncro either. Couldn't put a wheeler on it. |
denwood Samba Member
Joined: July 29, 2012 Posts: 1047 Location: Thunder Bay, Ontario, Canada
Posted: Tue Jul 22, 2014 10:57 am Post subject: |
Just got back from a weekend towing this Hobie 18 and custom trailer (modified boat trailer)....16.5 mpg towing at around 60mph over 190 miles, with the family and camping gear on board.
It's noticeably more work to tow than the typical setup I posted earlier. Oil temps up to 110C, and noticeably lower mileage. On the same run (kayaks up top for half the trip) Road Trip (my favorite mileage/maintenance iOS app) reported 22mpg with no trailer attached. _________________ Cheers,
Dennis Wood
The Grape |
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1649 Location: Between Here and There
Posted: Tue Jul 22, 2014 3:16 pm Post subject: |
Is there a similar app for android? Samsung Galaxy III...looked but didn't see one that looked like what you're talking about... _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
KindaHippyish Samba Member
Joined: December 18, 2007 Posts: 109 Location: Austin, TX
Posted: Tue Jul 22, 2014 3:35 pm Post subject: |
Glad to see you're able to pull loads like that, denwood. I'm on my way to swapping the 1.8 block currently in my van with a 2.0 bubble block, and it's nice to know it'll be able to handle taking like what you've shown. _________________ 1995 Eurovan Camper 5SPD
1991 Vanagon GL 4SPD – Subaru DOHC EJ25 - SOLD
1984 Vanagon Wolfsburg 4SPD – 1.8 I4 - Traded Away
1986 Vanagon GL Syncro 2.1L WBX 4SPD - RIP |
Posted: Tue Jul 22, 2014 11:05 pm Post subject: |
vdub, this is the app: http://darrensoft.ca/roadtrip/
Doesn't look like an Android port
TT, a few things have likely contributed to some longevity with the i4 swap and a fair bit of towing.
1. Auto trans cooler replaced with air/oil from FAS.
2. Oil cooler replaced with Mocal air/oil in fender
3. Oil pan windage tray (essential if you're using the 50 degree/diesel setup)
4. As of a few weeks ago, a new oil pump with a properly clearanced (.002") new diesel pickup tube. I'm able to run 5w30 synthetic now with oil pressure about 2 bar/1000rpm, a bit less towing the cat above with oil temps in the 110C to 115C range.
5. Lowered compression from 10.5:1 with a knock sensor.
6. Techtonics digifant chip/knock sensor bushing (installed last year)
The i4setup with larger 2.1 pistons in the 3A block is good for ~ 140-145 HP. I really like the fact that the 3A block/digifant head has piston squirters, knock sensing and in our case, slightly lowered compression. When towing the cat, I generally fill up with 92 octane, 87 otherwise.
We're about 10 years in now with no engine issues..the oil pump should have been clearanced properly from the get go..and was not. Big difference there as evidenced by last weekend's tow, hot weather, and the 5w30 run for the first time. I had towed the same cat about 320km pre conversion..and it was painful. _________________ Cheers,
Dennis Wood
The Grape |
Posted: Wed Jul 23, 2014 7:41 am Post subject: |
"vdub, this is the app: http://darrensoft.ca/roadtrip/
Doesn't look like an Android port Sad"
Thanks Denwood! I emailed him to find out if there is an Android version, but doesn't look like it. Too bad ~ looks very useful and well executed. _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
termuehlen Samba Member
Joined: May 02, 2012 Posts: 993 Location: Redwood City
Posted: Mon Nov 14, 2016 3:13 pm Post subject: Re: Best Trailer Setup? Post your pics! |
How about a Wesfalia to tow behind your Westfalia? $2,910 seems pretty reasonable. Although you would have to be pretty short to use the inside for anything other than cargo transport.
https://www.classicdriver.com/en/car/porsche/trailer/1977/408436
_________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2330 Location: Southeast Kentucky
Posted: Mon Nov 14, 2016 5:30 pm Post subject: Re: Best Trailer Setup? Post your pics! |
Not a Westy and not a trailer ..........
I've pulled this PopUp Camper to Alaska and back twice.
_________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
tlbranth Samba Member
Joined: May 24, 2014 Posts: 209 Location: Carnation, Wa
Posted: Mon Nov 14, 2016 6:25 pm Post subject: |
Envious wrote: |
I don't know who made it but my trailer rocks. I've installed a double bike rack to the back of it and the tow behind double bike trailer for my kids folds flat and is attached to the lid with a spider bungy. I actually thought it was home made with a car carrier lid until I met another vanagon with the identicle rig. It's all steel sides on a steel chasis. It weighs almost nothing and holds our Coleman, folding picnic table, chairs, firewood, beer cooler, kids toys, etc, etc. It's great having the floor of the Vanagon completely clear when we're on the road.
That looks a bit like a motorcycle trailer to me. _________________ Terry
1991 Westfailure. 2004 Forester 2.5 engine. 4speed Standard transmission. |
Posted: Mon Nov 14, 2016 6:32 pm Post subject: |
Timwhy wrote: |
Those with the smallish trailers like the Harbor Freight kind or the motorcycle trailers. How
do they travel? Can you do highway speeds with them attached? |
I looked at HF when I needed something to tow a motorcycle and it seems to me I had to pass on account of the low speed rating on either the tires or the axle. I bought an Aluma M/C trailer. I'd check the speed rating of the tires. _________________ Terry
Posted: Mon Nov 14, 2016 6:37 pm Post subject: |
alaskadan wrote: |
Did someone build a single swivel wheel trailer for vw? I'll have to get a pic but I've seen on in a yard that may be about 4x6ft with a single swiveling wheel and two small tongues on front. Then it has a big vw emblem on the back.
I did a search online and found that sears (I think ) made something like it. |
Nice job. _________________ Terry
AKWesty Samba Member
Joined: April 12, 2014 Posts: 680 Location: Haines, Alaska
Posted: Mon Nov 14, 2016 9:40 pm Post subject: Re: Best Trailer Setup? Post your pics! |
_________________ 84' Westy 2wd
EJ22 - 4spd - Peloquin TBD
GW +1.5 Springs
215/70-16's
www.CatchTheKraken.com
"Never go to Alaska as a young man because you'll never be satisfied with any other place as long as you live." -John Muir |
0to60in6min Samba Member
Joined: November 27, 2006 Posts: 3416 Location: OR & CA (Oregon/California)
Posted: Mon Nov 14, 2016 9:50 pm Post subject: Re: Best Trailer Setup? Post your pics! |
@termuehlen
I love that picture... it's a Citroen DS
Posted: Tue Nov 15, 2016 10:12 am Post subject: Re: Best Trailer Setup? Post your pics! |
0to60in6min wrote: |
Yes, also known as "the goddess"! _________________ 1988 Westfalia automatic Subaru OBD1
Posted: Tue Nov 15, 2016 10:28 am Post subject: Re: Best Trailer Setup? Post your pics! |
Quote: |
Yes, also known as "the goddess"! |
DS in French: Déesse
translation in English is Goddess
there's a movie about a guy who wants to be an astronaut, went thru surgery to be qualified, cheat etc... in the movie he drives an Citroen DS... I forgot the name of the movie.. |
Halifaxwesty Samba Member
Joined: October 21, 2012 Posts: 213 Location: Halifax, Nova Scotia, Canada
Posted: Tue Nov 15, 2016 8:32 pm Post subject: Re: Best Trailer Setup? Post your pics! |
Just scored this little fella on Kijiji....
1985 HP 350
_________________ 84 Westfalia Vanagon
2.2 RMW Conversion
Work in Progress
My first car was a 1968 VW Bug |
lmyester Samba Member
Posted: Wed Nov 16, 2016 5:51 am Post subject: Re: Best Trailer Setup? Post your pics! |
1974 Appleby Tent Trailer
Sears Allstate Trailer
