WHYYYTRYYY Samba Member
Joined: June 30, 2016 Posts: 50 Location: Jackson, NJ
Posted: Sat Aug 06, 2016 8:42 pm Post subject: Sebring #249 official build thread |
With significant progress on the car today, I decided to start an actual build thread to post my updates. You can see the condition of the car from the day I got it here http://www.thesamba.com/vw/forum/viewtopic.php?t=658372&highlight=
Here's a few pics to show how I received the car:
Check the previous thread to see disassembly to this point.
So today my intention was to separate body from chassis. Everything seemed to work out fine. Having a garage to work in with tons of equipment is always a huge help as well.
Pulled the canopy first and removed hinges.
Used the grinding wheel on all the rusty bolt heads mounting the body, and then added a little vertical motivation to the body only via a 2 post lift. Eventually with a little prying the body and chassis separated with a satisfying 'thwok' and the wheels plopped down the 3 inches to the ground.
Pulled the chassis out of the way...
Took some measurements, and built up a sturdy frame to drop the body on
Voila! Body is locked in place
Chassis pics
All my junk that needs to disappear from the garage by Monday morning
As always, more pics/progress to come! |
Posted: Mon Aug 08, 2016 6:35 pm Post subject: Re: Sebring #249 official build thread |
Ugh, hit a snag today. First, I got the tunnel supported so I could strip it.
Then, I started peeling up rubber sheeting on the tunnel so I could verify chassis number. Well, I immediately noticed a major problem. This is after I dug out/off all the rubber.
So. Now what? Should I attempt to repair the rear of this frame? Looks like scrap to me at this point. The chassis number did match up to the title...little consolation to me, I suppose.
After some profanity time when I discovered the major damage, I hopped on craigslist to find a better starting point. I found a guy who has a 1600cc engine that's in beautiful shape. He also has a buggy body mounted on a chassis, also excellent shape. The problem? Swing axle, not IRS.
So my question: If I were to purchase this chassis, and weld in the diagonal arm mounting brackets that are necessary, is there any other differences on the chassis? I did not see a chassis number in the same location as where mine was. Any advice guys?? Thanks for all your continuing help on this project! |
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3198 Location: Downingtown, PA
Posted: Mon Aug 08, 2016 6:53 pm Post subject: Re: Sebring #249 official build thread |
Ouch... toast. Start looking for a donor, or if you can swing it Acme in Lancaster, PA sells reconditioned chassis that are pretty nice. You can even have them install disc brake sets, engines, etc. Just tell them you don't need the pans or perimeter frame (though they may not cut those off anyway). A buggy chassis will be too short anyway.
psst... cut the VIN off the tunnel and keep it.... |
Posted: Mon Aug 08, 2016 8:34 pm Post subject: Re: Sebring #249 official build thread |
Ahhh... I didn't even consider the chassis would be different length. Damn. I will almost certainly purchase the engine from him though. It's worth what he was asking for the frame and engine combined (not that I would pay that anyway, I'm a haggler).
I will check into Acme. I will also keep the VIN 'for sentimental purposes only'
Tomorrow I will try to clean up my frame. I have grinding/blasting tools, a big welder, and time. Who knows, maybe I'll fix and reinforce the f&%k outta my current tunnel. I like to make things better than stock whenever possible.
Thanks for the help. |
woodoctr Samba Member
Posted: Mon Aug 08, 2016 8:56 pm Post subject: Re: Sebring #249 official build thread |
I've owned enough Sebrings and Sterlings to say this with some authority.... that frame is the "lifes blood" of a Sebring. Yours is dead...unsafe...do not put any more time into it. You've got to understand we don't even have the luxury of the full pan with our cars so that "backbone" frame is the only thing that is holding us on the road. The body is just along for the ride. Letterman has the right idea there... If I was building a Sebring right now I'd hit Acme up in Pennsylvania. They've also got experience with other engine types as well. They had one of their Ecotec set-ups at Carlisle. If I was going through all the stuff you are doing with this car I'd just go ahead and do Subie or Ecotec with it. |
Posted: Wed Aug 10, 2016 2:09 pm Post subject: Re: Sebring #249 official build thread |
Just spoke to 'Big John' over at Acme. Very cool and knowledgeable guy. He said he will try to track down a tunnel for me. I'll still keep an eye out , but he said he should have something for me, hopefully in a week or so. Very happy I called them. |
Posted: Thu Nov 10, 2016 11:15 am Post subject: Re: Sebring #249 official build thread |
Need some assistance here. Will a super beetle chassis fit under this body? I have a line on a '73 super beetle in decent shape that I can get tomorrow to drop this body on. Any advice? |
jspbtown Samba Member
Posted: Thu Nov 10, 2016 11:36 am Post subject: Re: Sebring #249 official build thread |
Not without significant modification. The Supers have a McPherson strut front suspension.
Now you can cut the front off and weld on the front of a standard Beetle...so anything is technically possible. |
kitcarguy Samba Member
Joined: May 06, 2007 Posts: 431 Location: North Carolina
Posted: Thu Nov 10, 2016 2:41 pm Post subject: Re: Sebring #249 official build thread |
You can use everything but the front end lol .
WHYYYTRYYY wrote: |
_________________ www.fiberclassics.org |
Posted: Thu Nov 10, 2016 7:01 pm Post subject: Re: Sebring #249 official build thread |
Ahh, I'll keep looking.
So there's been quite a time gap here since I last posted. Woman issues had me sidetracked. Anyway, a while back I brought my old cracked frame to Acme in PA, 157 miles away, and bought a 'better' frame. After laboriously sandblasting most of the 'new' frame, it was in pretty bad shape. Rust holes in various low spots on the tunnel, needed new frame head, damage tubes inside, etc... another dead end.
I must say, while I wasn't a huge fan of the owner of Acme (he told me on the phone the frame was in better shape), the two guys that actually worked there in the garage were awesome. Stayed after their shift was up to help me pull a couple extra parts off my old frame, and showed me the garage and sweet jigs they use to properly align frame while cutting and welding it. And gave excellent information for my build. They also refused a tip, even though for a while I was just wasting time checking out the cool builds they were working on! I left one for them anyway because of the excellent service, but still. Good people.
To get this project rolling, I am now trying to just buy a running beetle and swapping the body, instead of building from scratch. Hard to find these things! Anyone know of a lead on a running and driving, but ugly beetle for sale in the NJ/PA ish area? |
sbussard Samba Member
Joined: April 19, 2011 Posts: 432 Location: Pittsburgh, PA (near enough)
Posted: Fri Nov 11, 2016 9:29 am Post subject: Re: Sebring #249 official build thread |
http://www.searchtempest.com/ is a decent way to search multiple craigslist sites. Sometimes you need to change around the keywords you use when you search, because you never know how people have listed their stuff. Try vw bug, vw beetle, add the word frame or maybe the word chassis. That kind of thing.
My son and I picked up a 72 vw chassis in ohio a few years ago for $350 with title. They are out there, just getting harder to find.
I searched around a bit just now and without too much hassle found this one.
http://youngstown.craigslist.org/cto/5826883301.html At $1500, I wouldn't buy that one, but I would at least contact the guy and see if he'd be willing to keep the motor, etc.
Another good place can be ebay. Here's a no reserve auction currently at just over $1000 in Ohio. Clean title and with a motor that turns. http://www.ebay.com/itm/1967-Volkswagen-Beetle-Classic-/192019864569?_trksid=p2141725.m3641.l6368
Good luck with the build, I'm looking forward to seeing it come together for you.
Scott _________________ Manxter #122
First time, garage built, and living out the childhood dream of owning a life-size Hotwheel!
Check out my build thread-->My Manxter 2+2 |
Posted: Sat Nov 12, 2016 7:18 pm Post subject: Re: Sebring #249 official build thread |
Unfortunately I've heard that about Acme. And their engine builds aren't the highest caliber. Check Craigslist locally... http://frederick.craigslist.org/cto/5869731998.html
Sell what you don't need... |
JiI Samba Member
Joined: February 18, 2006 Posts: 1845 Location: Michigan
Posted: Tue Nov 15, 2016 9:32 am Post subject: Re: Sebring #249 official build thread |
Letterman7 wrote: |
Toast? That's mint condition here in Illinois!
Jeff |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Wed Nov 16, 2016 7:03 pm Post subject: Re: Sebring #249 official build thread |
Progress finally.
Made a big purchase and bought a 'running' 1969 bug.
It's a shame the body is so nice, but I need that chassis its riding on! Today I got the body totally separated from the car. Unfortunately the 2 two post lifts we have were occupied, so I couldn't start the body swap. This beetle body is FOR SALE, by the way, and is in excellent shape. Any estimates on it's value?? I'm including everything from the car, minus the actual car part. Taking offers...
Beetle received a full restoration in early 2000's, and everything is in very good shape. Honestly it kills me to separate a car this nice, but you do what ya gotta do. |
64glitterbug Samba Member
Posted: Wed Nov 16, 2016 7:34 pm Post subject: Re: Sebring #249 official build thread |
NO..........Don't do it.....Find another sacrificial bug. That looks too nice! |
Posted: Wed Nov 16, 2016 7:44 pm Post subject: Re: Sebring #249 official build thread |
64glitterbug wrote: |
Yeah, I heard that from every person that saw it as well. But I wanted a clean chassis, and this is how to get it. The car will live on if someone buys this body! |
Posted: Wed Nov 16, 2016 8:18 pm Post subject: Re: Sebring #249 official build thread |
Too nice to sacrifice - there are other chassis out there. Don't take a nice VW off the streets. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
JiI Samba Member
Posted: Thu Nov 17, 2016 12:54 pm Post subject: Re: Sebring #249 official build thread |
I have a 1965 chassis available. That bug is in too good of shape, and I'm from Volksrods.com!
Jeff |
aquavette Samba Member
Joined: May 30, 2007 Posts: 176 Location: Argyle, TX.
Posted: Fri Nov 18, 2016 3:52 pm Post subject: Re: Sebring #249 official build thread |
Cut it up.
If the price was right, parting out what you don't want might make you a buck.
