1959 vw bug restoration
eladi
eladi is offline
PostPosted: Wed Nov 16, 2016 9:44 am    Post subject: 1959 vw bug restoration Reply with quote
Decided to share this restoration projact, bought this beauty three years ago.
1959 vw bug in rough condition. last driven in back 1994. all floor pans are rusted, heat channels too, doors are danted, engine and gear condition is unknown . but I love it.
eladi
eladi is offline
PostPosted: Wed Nov 16, 2016 9:52 am    Post subject: Re: 1959 vw bug restoration Reply with quote
After removing most of the interior, glasses, fenders and taking the bug apart, today I took the shell off the pan in order to start replacing the floor pans , having the brakes fixed, replacing bushing and every thing that will need replacing . the goal is the have it mechanic fixed before the shell will be put back.
going airborne..
rust every where
67ctbug
67ctbug is offline
PostPosted: Wed Nov 16, 2016 11:12 am    Post subject: Re: 1959 vw bug restoration Reply with quote
Go Wolfsburg West for the pans... you'll be happier.
'67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote:
...or the PO envied the terrorists' bus in "Back to the Future". Laughing
mukluk wrote:
He's fine, just waiting for the dragon in winklepickers to move out of his lane.
vwnut1
vwnut1 is offline
PostPosted: Wed Nov 16, 2016 11:24 am    Post subject: Re: 1959 vw bug restoration Reply with quote
It appears to be a lot of work due to corrosion issues. Do you plan on doing a VW showroom restoration? If so, expect to spend spend more than you think if that's your goal. Every system (paint, metal work, suspension, drivetrain, interior, trim, etc.) will need attention.
The 1st thing I would do is have the body shell media blasted and then sealed to prevent rust. This way you know exactly what your dealing with and there will be no surprises.
1957 VW Oval Resto Mod
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Wed Nov 16, 2016 1:42 pm    Post subject: Re: 1959 vw bug restoration Reply with quote
Wow, that bug was rode hard and put up wet! Why all the rust on it? Is it humid there or was it by the ocean salt air? Seems like a lot of salt type rust damage.
Good luck with your project. You've got LOTS of work ahead of you but it's so worth it when you're driving it down the road when it's done.
The Samba member since 2004.
eladi
eladi is offline
PostPosted: Sat Nov 26, 2016 11:23 am    Post subject: Re: 1959 vw bug restoration Reply with quote
Removing the rusted floors and fixing new ones.
67ctbug
67ctbug is offline
PostPosted: Sat Nov 26, 2016 11:27 am    Post subject: Re: 1959 vw bug restoration Reply with quote
Noooooooo! Orange pans Shocked Confused Your gonna have to move the seat tracks and those things are like paper. You should have taken my advice...
Anyway, it's good to see you are jumping right in with the floors and not trying to make patches everywhere.
'67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
eladi
eladi is offline
PostPosted: Sat Nov 26, 2016 12:48 pm    Post subject: Re: 1959 vw bug restoration Reply with quote
I bought this pans almost a year ago, before your advice.. from CSP that was the thicker one they had
Why will I need to move the tracks??
67ctbug
67ctbug is offline
PostPosted: Sat Nov 26, 2016 1:03 pm    Post subject: Re: 1959 vw bug restoration Reply with quote
From what I understand of the orange pans, the tracks are angled toward the tunnel if you look at the head on.
'67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
Rome
Rome is offline
PostPosted: Sat Nov 26, 2016 6:21 pm    Post subject: Re: 1959 vw bug restoration Reply with quote
Are you able to find new replacement parts from dealers anywhere in your country, or do you need to import them from Europe? Are there junkyards in your country away from the big cities where there might be a Beetle with less rust, that you can use for parts or for cutting out original metal sections to fix yours?
Is that a 34hp (40hp in the US) 1200 engine with "stale air" heater boxes, based on the outward bump of the fan shroud near the bottom as seen on the passenger side of the engine? Or actually fresh air heater boxes?
eladi
eladi is offline
PostPosted: Sun Nov 27, 2016 11:02 am    Post subject: Re: 1959 vw bug restoration Reply with quote
finding a 1959 vw bug here is near to impossible, I am very lucky to find the one I am restoring. so forget about getting a donure car in decenat shape .
the engine and transmission arent original they are from 1969 bug.
JeffRens
JeffRens is offline
PostPosted: Sun Nov 27, 2016 11:23 am    Post subject: Re: 1959 vw bug restoration Reply with quote
Looks like fun. Slightly worse shape than my 56 Oval project. Like the other posts said, be prepared for some expenses. I ended up with $14K into mine.The only thing I jobbed out was the heater channel and front cross-member replacement so it would be square again and assembly of the short block. Great therapy though....
eladi
eladi is offline
PostPosted: Tue Dec 20, 2016 10:14 am    Post subject: Re: 1959 vw bug restoration Reply with quote
got the second floor pan or what left of it off, put the new one just to get a nicer view
[/img]
67ctbug
67ctbug is offline
PostPosted: Tue Dec 20, 2016 1:18 pm    Post subject: Re: 1959 vw bug restoration Reply with quote
Looks good, just make sure to check those seat rails.
'67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
