cracked piston - thoughts?
iamdonquixote
iamdonquixote is offline
PostPosted: Sat Nov 19, 2016 4:43 pm    Post subject: cracked piston - thoughts? Reply with quote
Pulled the engine because it had quite a bit of blow by. See: http://www.thesamba.com/vw/forum/viewtopic.php?t=667243&highlight=
The spark plugs on the 3/4 side looked good but the 1/2 side looked black , so I started by pulling the 1/2 side head.
Well the #2 looked like this:
I could see oil push through the crack as I turned the engine over.
thoughts? what could have caused this?
modok
modok is online now
PostPosted: Sat Nov 19, 2016 5:47 pm    Post subject: Re: cracked piston - thoughts? Reply with quote
It would be VERY RARE for a piston to crack like that.
Call it a casting defect, replace all four, don't worry about it happening again.
iamdonquixote
PostPosted: Sat Nov 19, 2016 5:53 pm    Post subject: Re: cracked piston - thoughts? Reply with quote
thanks, I never heard of it myself, I assume its the cause of the blow by?
Anything else to check out? Should I split the case?
iamdonquixote
PostPosted: Sun Nov 20, 2016 8:21 pm    Post subject: Re: cracked piston - thoughts? Reply with quote
Some additional pictures of the head and #1 piston and cylinder.
kokanee
kokanee is offline
PostPosted: Sun Nov 20, 2016 8:26 pm    Post subject: Re: cracked piston - thoughts? Reply with quote
unless you have the spark plugs loose you have the wrong ones in those heads as far as the crack just replace all four and call it good
splitjunkie
splitjunkie is offline
PostPosted: Mon Nov 21, 2016 8:42 am    Post subject: Re: cracked piston - thoughts? Reply with quote
The crack is inline with the wrist pin. Could be caused by detonation due to some low octane gas or excessive compression ratio.
Chris
iamdonquixote
PostPosted: Wed Nov 30, 2016 12:13 pm    Post subject: Re: cracked piston - thoughts? Reply with quote
The spark plugs are just loosely threaded in.
Took, the #3 piston & cylinder off.
Things look bad, thoughts on why this occured?
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Wed Nov 30, 2016 12:40 pm    Post subject: Re: cracked piston - thoughts? Reply with quote
Detonation/ Preignition
SBD
SBD is offline
PostPosted: Wed Nov 30, 2016 12:45 pm    Post subject: Re: cracked piston - thoughts? Reply with quote
But I remember when auto manufacturers used to say that a little bit of that noise was normal. Very Happy
"Just $99 down and $64 a month for 36 months buys you a brand new Volkswagen Beetle!"
mark tucker wrote:
I wouldent waste $ or thyme on building a small motor. build it big so it dosent have to work hard.remember it's only as fast as your foot alows it to be unless you build a small turd then it just stinks as it squishes up through your toes when you step on it.
splitjunkie
PostPosted: Wed Nov 30, 2016 5:32 pm    Post subject: Re: cracked piston - thoughts? Reply with quote
Yep. Pretty much confirms my earlier post.
The only other thing that could cause that much damage would be a sledge hammer.
By the way, you are taking a really big chance if you just put new rods and pistons and cylinders on that engine. All of that broken and squished out metal has surely contaminated the bearings and oil ways, probably scored the crank and oil pump and crudded up the oil cooler. The crank could be bent too. I would call the rods toast. I also wouldn't rule out case damage and cracks.
Time for a full tear down and rebuild. Bummer.
If the case was machined where the cylinders sit or the heads were re decked and then it was not shimmed to bring the compression ratio back down then the CR might have been very high and combined with bad gas you will get detonation. The distributor also could have been set wrong causing too much advance or retardation.
Chris
PostPosted: Wed Nov 30, 2016 5:38 pm    Post subject: Re: cracked piston - thoughts? Reply with quote
In fact you'll see marks on the rod bearings as well sometimes called aligatoring . Take pics.
williamM
williamM is offline
PostPosted: Wed Nov 30, 2016 6:11 pm    Post subject: Re: cracked piston - thoughts? Reply with quote
That also looks like a very tight pin to small end of the rod fit- with that damage to the end of the pin and pin bore in the piston.
Would that go along with detonation??? or looking at 2 problems?
some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any!
modok
modok is online now
PostPosted: Wed Nov 30, 2016 6:21 pm    Post subject: Re: cracked piston - thoughts? Reply with quote
that could be caused by many things. You will have to guess based on the other clues you have. If the piston tried to seize or the pin tried to seize you should be able to see that on the skirt. If if the skirt is small (bent in) at the bottom then possibly the pin seized. If it overheated you will have four corner scoring. The pin may have seized and broke the piston, or the piston may have broke first, due to who knows why. Ring butted, hydrolocked on fuel? Detonation maybe but once cleaned you should see some sign of it.
Measuring the skirt and examining the piston, check ring gaps, and knowing the conditions is all you can do. Was the pin clips still in place? possibly the pin walked sideways and caused it. Many VW shops do not know "Rod alignment" is a thing.
williamM
williamM is offline
PostPosted: Sat Dec 03, 2016 7:56 am    Post subject: Re: cracked piston - thoughts? Reply with quote
Embarassed Embarassed so what did the rest of the pistons look like?
Show us her skirts Rolling Eyes
Don't step in any!
57BLITZ
57BLITZ is offline
PostPosted: Sat Dec 03, 2016 3:23 pm    Post subject: Re: cracked piston - thoughts? Reply with quote
I'm curious also!
The top of #2 . . .
The bottom of #3 . . .
Jesucristo es mi Seņor y Salvador!
iamdonquixote
PostPosted: Sun Mar 05, 2017 5:41 pm    Post subject: Re: #2 cracked piston - thoughts? Reply with quote
well , I spilt apart the case, and I'm in need of expert advice on its usability.
I'm concerned about the dowel pin that is loose at the rear bearing saddle.
Also, it appears that the installed the bearings incorrectly as the oiling hole in the bearing did not line up with the one in the case.
also, in my post I wrote it was the #3 cylinder but it was #2.
williamM
williamM is offline
PostPosted: Sun Mar 05, 2017 5:57 pm    Post subject: Re: cracked piston - thoughts? Reply with quote
How do those lifter brackets work- I'm unfamiliar with that set up.
judging by the groove in the #3 bearing, your due for an excessive line bore or a new block.
Don't step in any!
iamdonquixote
PostPosted: Sun Mar 05, 2017 5:59 pm    Post subject: Re: cracked piston - thoughts? Reply with quote
I thought that was a 36 hp thing? But I've never looked inside a 36 hp block until today.
txoval
txoval is offline
PostPosted: Sun Mar 05, 2017 7:19 pm    Post subject: Re: cracked piston - thoughts? Reply with quote
That is a 36hp case...which is why you see those lifter guides.
I highly recommend you take this to the Vintage Speed Forum. The 36hp experts hang out over there.
I will tell you, rebuilding 36hp engines cost much more than late models. Less parts available and some are expensive.
Mr. Okrasa is selling a few stroker 36hp based engines for I believe $3200.
For reference, I had to spend $900 in case machine work to get my 36hp case back to spec.
iamdonquixote
PostPosted: Sun Mar 05, 2017 8:45 pm    Post subject: Re: cracked piston - thoughts? Reply with quote
calling admin,, can we move this thread to vintage speed forum?
