Airkewld Samba Member
Joined: November 14, 2003 Posts: 3152 Location: Goodyear, AZ USA
Posted: Mon Nov 28, 2016 9:10 pm Post subject: Re: Throttle cable and tube angle issues |
Mr. Electric Wizard wrote: |
Answering my own questions here:
1) got the empi universal braided throttle cable - 15' long
2) will just use the sheet metal screw instead of dealing with the nut and trying to glue it in
3) will just use all purpose grease for the throttle cable.
Probably going to do some butty's bits throttle linkage for up front as well. |
I don't know if you got the email, but my answers were exactly yours but the email came back as bad. _________________ TheSamba members-only discount - Samba24
Win a FREE Chassis Rebuild - https://airkewld.co/WinAChassis
Learn from a PRO on Patreon - https://www.patreon.com/Airkewld
FAQ - https://airkewld.co/FAQ
View our Industry Leading Products - https://www.airkewld.com/Products-s/2322.htm
We made a iPhone Ringtone with a Classic VW Turbo Engine - https://airkewld.co/RingtoneTurbo
YouTube Channel - https://airkewld.co/SubSamba |
Mr. Electric Wizard Samba Member
Joined: August 07, 2003 Posts: 2846 Location: Smyrna, TN
Posted: Tue Nov 29, 2016 6:16 am Post subject: Re: Throttle cable and tube angle issues |
Weird. Thanks Pete, maybe I read your mind. _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
(T)exas (C)oalition (B)uses
(H)eidenhammer (B)ully (B)oyz
--1966 De Luxe Camper |
Posted: Tue Dec 06, 2016 8:09 am Post subject: Re: Throttle cable and tube angle issues |
Finally got my roller tube thing installed and so far it's great!
At the same time I installed a new braided throttle cable and greased the heck out of it with white lithium grease.
Last week I also ordered one of Butty's Bits throttle linkage kits.
Good to go now!
Thank you for the suggestions. _________________ "Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
plane_ben Samba Member
Joined: February 27, 2005 Posts: 349 Location: Tucson, AZ
Posted: Tue Dec 06, 2016 10:21 am Post subject: Re: Throttle cable and tube angle issues |
Late to the thread here, but I have a solution to both the throttle dragging issue on carb linkage and transaxle. I run a length of bicycle brake sheath the entire length of the bus all the way through the fan shroud until I have an inch poking through. Then I use the braided throttle cable. Ran this set up on my last three busses, no issues with throttle hang up.
If I were running a show VW, I think the roller tube is a nice custom "looks" upgrade. _________________ I'm at the age were "fuck off", "fuck you", and "fuck it" answer most questions. |
