markcm2 Samba Member
Joined: September 02, 2015 Posts: 505 Location: Bellingham, Washington
Posted: Thu Dec 15, 2016 11:09 am Post subject: What engine oil are you using in your VR6 01-03 VW T4 Eurovan? |
Just wondering what engine oil is preferred in the last generation 01-03 T4 with the VR6?
Thanks |
jjvincent Samba Member
Joined: January 11, 2016 Posts: 1268 Location: Bethlehem, PA
Posted: Thu Dec 15, 2016 1:45 pm Post subject: Re: What engine oil are you using in your VR6 01-03 VW T4 Eurovan? |
Oh Boy. Another motor oil question on a forum. These never turn out well. |
Posted: Thu Dec 15, 2016 1:48 pm Post subject: Re: What engine oil are you using in your VR6 01-03 VW T4 Eurovan? |
I'm mostly curious what the spec oil weight is, like 5w-30? 10w-40?
I pretty much use Rotella T-6 in all my vehicles, I know its a diesel oil with a multi use rating, but it works for me, really well. but it only comes in 5w-40, I'm wondering what the spec oil weight is for these engines. |
Posted: Thu Dec 15, 2016 2:25 pm Post subject: Re: What engine oil are you using in your VR6 01-03 VW T4 Eurovan? |
I mostly run Rotella T6. Just because I can use it in the TDI also and the price is right. Only time I run anything different (Elf, Total or Liqui Molly) is because I can get it even cheaper and free shipping when I get a load of parts.
I do suggest going with anything light because one thing nobody ever talks about is the workings of the cam timing. They only talk about cylinder wear and bearings. If you ever took at the engine apart, the bottom end is like anything from the last 50 years. It's just things like the cam timing (I can't remember what VW calls it buy the same as BMW Vanos or Porsche Variocam) and lifters are tiny and intricate. Thus a thick oil is not the best when it comes to making them work properly over the range of temps that an engine sees.
Best thing to say is that motor oil is so good as compared to 30 years ago, it isn't even funny. |
fkahlert Samba Member
Joined: September 30, 2016 Posts: 57 Location: Connecticut
Posted: Thu Dec 15, 2016 2:53 pm Post subject: Re: What engine oil are you using in your VR6 01-03 VW T4 Eurovan? |
Without going further in it and for informational purpose only...
VW specifies 5-40 for the Eurovan but says topping up with 5-30 is acceptable.
Right there in the manual.
Florian 03 MVWK |
Posted: Thu Dec 15, 2016 3:34 pm Post subject: Re: What engine oil are you using in your VR6 01-03 VW T4 Eurovan? |
Thanks guys,
That's what I was looking for. |
Posted: Thu Dec 15, 2016 4:06 pm Post subject: Re: What engine oil are you using in your VR6 01-03 VW T4 Eurovan? |
Plus, the coolant is lifetime. Just so you know, never change it because VW doesn't want you to.
On a side note, my 17 yer old Jetta and my 2003 EV still have the original coolant in it. I screwed up on the oil but I made up for it in the coolant department. |
Posted: Thu Dec 15, 2016 6:23 pm Post subject: Re: What engine oil are you using in your VR6 01-03 VW T4 Eurovan? |
lifetime - so was the trans fluid - at least for a while.
Also, the Passat oil filter suddenly got bigger after the oil sludge debacle.
But still - i think its fair to say that VW proposes fairly wide range oils 5-40 and pretty thin ones as well.
Not like my BMW 1200Gs that used 20-50 tractor fluids.... |
gakali Samba Member
Joined: August 19, 2007 Posts: 448 Location: Cambridge, Ontario, Canada
Posted: Tue Dec 20, 2016 5:37 pm Post subject: Re: What engine oil are you using in your VR6 01-03 VW T4 Eurovan? |
Re. lifetime fluids - I was told by a VW engineer that "lifetime" is considered as 150,000 km from their standpoint. This makes sense to me. _________________ Why do it? Because you can.
1999 Eurovan
2003 A4 Avant 1.8T Quattro
1992 W201 190e 2.3 Mercedes
2006 W220 S600 V12 Twin Turbo 5.5 Mercedes |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Tue Dec 20, 2016 6:30 pm Post subject: Re: What engine oil are you using in your VR6 01-03 VW T4 Eurovan? |
I run 0W-40 Mobil in mine
It's run upstate in moderate climates for the most part
See sticky oily thread above, too. _________________ .ssS! |
