durfeec Samba Member
Posted: Thu Jan 09, 2014 5:38 am Post subject: |
Daniel G wrote: |
I'm thinking of doing the same thing to my bus due to all the rust holes in the cargo floor. I have two ideas: Either make it out of luan and put a plexiglass window in it, or sew one up out of fabric and then make a window out of a shower curtain or some other strong, but flexible, clear plastic. If I make it out of wood it would look a lot nicer, but be harder to mount. If I make a fabric one I could put velcro or snaps in the bus to mount it with and take it out in like a minute. I am leaning toward the wood option though, as it would look a lot better...Plus I would hardly ever need to take it out until the weather got warmer, so that is not a big deal to me. |
I have a third idea. Fix the holes in the floor. _________________ 1960 Bus Panel/Camper |
rebapuck Samba Member
Joined: May 17, 2007 Posts: 1023 Location: Chapel Hill NC
Posted: Thu Jan 09, 2014 10:04 am Post subject: |
I'd make the whole thing out of a clear shower curtain. for visability. Hang it with rare earth magnets.
I do like the idea of a solid divider being quieter though. _________________ Judy
1966 Camper "Hannah"
1967 SingleCab "Khady" |
Daniel G Crazy Amish Guy
Joined: April 23, 2004 Posts: 828 Location: Central Alabama Amish Country
Posted: Sat Jan 11, 2014 2:52 am Post subject: |
durfeec wrote: |
I have a third idea. Fix the holes in the floor. |
Sounds great! I'll pm you a list of metal I need and my shipping address
Otherwise the metal work will be waiting til next winter...I need to replace my center pin as well as a few other odds and ends before I start back doing body work to it. _________________ 1967 13 Window Deluxe
1966 Beetle
1971 Panel
1978 Westfalia Camper
Transmissions For Dummies |
dirtylawnchair Samba Member
Joined: January 26, 2004 Posts: 1234 Location: Bradenton FL
Posted: Sat Jan 11, 2014 5:35 am Post subject: |
RobzKombi wrote: |
Here's the divider that came in my bus (ambulance divider). Since I had my bus repainted I had to remove the frame and the channel felt simply crumbled when I took it out. Now I'm trying to piece together channel felt to put back in .
The dividers Clara sells are neat and easy to remove if you want to go back full view back there.
There a few other buses I've seen with this divider. |
Rob please be sure to update the M529 thread during this process.
I am excited about cruising a bus with a divider for the noise reduction. I hope its as quiet as a single cab. _________________ Paulie
63 Standard OG paint |
RobzKombi Samba Member
Posted: Thu Oct 09, 2014 1:46 am Post subject: |
I am working on a cab divider for my bus currently, but I will still have to upload the pics. I am mounting a sliding side window from a Vanagon westy in it. It is almost the same size as a ambulance divider, so visibility should not be an issue.... _________________ 1967 13 Window Deluxe
1966 Beetle
1971 Panel
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
mandraks Samba Member
Joined: November 28, 2004 Posts: 7047 Location: Lawrenceville, Ga
Posted: Thu Oct 09, 2014 10:30 am Post subject: |
easy e wrote: |
Deluxe bus + ambulance divider: http://www.thesamba.com/vw/classifieds/detail.php?id=1671549
Maybe he would send you some pics detailing the headliner / partition fitment.
If he does... maybe post them in this thread, so the rare view of a partitioned deluxe don't evaporate when the classified is taken down.
e |
maybe you can also borrow the belly pans, since he is not using them right now? _________________ regards
Uli
kenshapiro2002 Samba Member
Joined: April 26, 2013 Posts: 1826 Location: Bawlmer Hon
Posted: Thu Oct 09, 2014 5:08 pm Post subject: |
At 130K...if he's anywhere near firm, that ad isn't coming down anytime soon. _________________ Looking for a correct 1967 rear seat
Looking for '67 Engine / Block HO 183xxx - HO 194xxx |
easy e Samba Member
Posted: Fri Oct 10, 2014 5:30 am Post subject: |
easy e wrote: |
mandraks wrote: |
maybe you can also borrow the belly pans, since he is not using them right now? |
Heh... nice observation
Makes me suspect of the partition... |
Agreed. With a bus with such an odd comination he should have a birth cirtificate as one of the pictures in the add. _________________ Paulie
Big Bill Samba Member
Joined: June 21, 2005 Posts: 1782 Location: Santa Rosa, Ca
Posted: Fri Oct 10, 2014 7:24 am Post subject: |
Wouldnt that 130K Deluxe have a White steering column. shifter and E-brake lever?? Not a dig, just asking. |
EverettB Administrator
Joined: April 11, 2000 Posts: 69809 Location: Phoenix Metro
GTV Samba Member
Posted: Fri Oct 10, 2014 3:03 pm Post subject: |
The placement of the clock in the dash looks really goofy to me... _________________ EMPI Power Rules! |
Posted: Fri Oct 10, 2014 7:17 pm Post subject: |
EverettB wrote: |
1958 and earlier are brown like that.
It's sort of a weird combination if you are used to the later Buses. |
Thanks E, good info to know. |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2610 Location: Phoenix AZ
Posted: Fri Oct 10, 2014 8:05 pm Post subject: |
Rob, did that bus come out of AZ? _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
Posted: Fri Oct 10, 2014 11:46 pm Post subject: |
GTV wrote: |
The placement of the clock in the dash looks really goofy to me... |
On the '57 Deluxe we are talking about?
I think it looks goofy because of the grab handle.
The grab handle was not a factory installation on 57s and that one was not installed centered over the clock like others I have seen.
'58 example
_________________ How to Post Photos
mtb7001 Samba Member
Joined: February 11, 2009 Posts: 899 Location: Meridian Idaho
Posted: Sat Oct 11, 2014 7:42 pm Post subject: |
1974, Alaska, friggin cold in the winter. Simple frame of 1x2's covered with carpet and insulation. From barely survivable to nicely workable. Still had to scrape the inside of the windshield. Best backwoods rabbit hunting vehicle ever. A few of your best friends and loaded weapons on four wheel drive trails in 2 feet of snow. _________________ 63 15 window deluxe Turkis walk through 1500
"comfort the afflicted, afflict the comfortable" |
Posted: Wed Dec 28, 2016 3:24 am Post subject: Re: Anybody Use / Build A Divider On Their People Carrier ? |
I finally uploaded some pics to the gallery. Here is how my divider turned out. I have used it in the bus for the past couple years, but it started rattling and I took it back out this fall. I never finished cutting the top out so it could screw to the air box cover holes, and it finally worked it's way loose at the top. The Vanagon sliding windows were the perfect size though, no visibility problems whatsoever. Plus you can open it up if you want to...
1966 Beetle
1971 Panel
