campism Samba Member
Joined: September 07, 2007 Posts: 4491 Location: Richmond VA
Posted: Fri Jan 06, 2017 7:19 pm Post subject: Re: Vanagon & Westy Measurements/Dimensions |
travis740 wrote: |
Does anyone happen to know the height of a 1984 Camper? Wanting to know if it'll fit in my garage.
I can't seem to find an owner's manual online. Brand new at trying to figure this out. Thank you |
If you have the van, just get a trusty spotter in position and get the van close so you can test. Van heights can vary by year, with early ones generally having taller springs and a taller overall height. But yours might not have a roof vent, thereby giving you a little extra space. What is the height of your garage door opening? Here's my stock-height '87 going under an 84" (7'0") header. Good luck!
Keep in mind that some alterations to the van (taller tires, different springs, etc.) might alter the van's height from stock, so any book measurement you find might not apply.
_________________ '87 Westy in Wolfram Grey Metallic |
travis740 Samba Member
Posted: Fri Jan 06, 2017 7:56 pm Post subject: Re: Vanagon & Westy Measurements/Dimensions |
Thank you very much. I'm hoping to buy it tomorrow depending upon the weather. Feels like X-Mas eve for me. I have a 7 ft garage height and hoping I can keep it indoors. Hopefully, I'll find out tomorrow.
Thank you again very much. |
kamzcab86 Samba Moderator
Posted: Fri Jan 06, 2017 8:10 pm Post subject: Re: Vanagon & Westy Measurements/Dimensions |
travis740 wrote: |
Thank you very much. I'm hoping to buy it tomorrow depending upon the weather. Feels like X-Mas eve for me. I have a 7 ft garage height and hoping I can keep it indoors. Hopefully, I'll find out tomorrow. |
Take a wood yard stick (or something similar) and tape measure: Yard stick on the vent out to the van's side; keep it level and run the tape measure up to the bottom of yard stick. That's how I verified my '90 would fit, with room to spare. _________________ ~Kamz
2016 Golf GTI S
Posted: Sat Jan 07, 2017 9:43 am Post subject: Re: Vanagon & Westy Measurements/Dimensions |
travis740 wrote: |
I'm hoping to buy it tomorrow depending upon the weather. Feels like X-Mas eve for me. Hopefully, I'll find out tomorrow. |
Come back with photos!! _________________ '87 Westy in Wolfram Grey Metallic |
Eric_Taylor Samba Member
Joined: January 21, 2011 Posts: 291 Location: Bend, Oregon
Posted: Sat Jan 07, 2017 6:47 pm Post subject: Re: Vanagon & Westy Measurements/Dimensions |
Yes! Photos! I got mine at thanksgiving and I got it a storage unit as I couldn't bear to let foot after foot of snow get on top of it all winter. Some pics of your height and fit with the garage would be great too. |
Blupi Samba Member
Posted: Fri Apr 21, 2017 10:35 pm Post subject: Re: Vanagon & Westy Measurements/Dimensions |
Hello! opening up an older thread which is very helpful!
I do have a question, i recently got an 81 vanagon full camper and the whole rear kick panel needs replacing. I have found the panel itself however i'm missing the sides. See my attached image, does anyone have the dims for this (or a part number so i can buy some)
any help is appreciated! |
Bman Samba Member
Joined: April 28, 2005 Posts: 895 Location: South Coast, Oregon
Posted: Mon Nov 05, 2018 12:05 pm Post subject: Re: Vanagon & Westy Measurements/Dimensions |
Let's keep this thread going....
Does anyone have the dimensions for the FULL Weekender and/or Carat rear, fold down bed lengths?
Certain beds have different lengths depending on whether or not you are using the Carat or Weekender plastic side panels. For those switching out interiors this is very important information as Tintops with standard cardboard side panels have longer (wider) beds than Carats etc.
Here is a photo of some of the useful lengths that would help:
_________________ ~Bryan
1990 Burgandy Tintop (Wife's Daily Driver)
1989 Tiico Westfalia "Taj"
2WD Doka build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=503578&highlight=
FaceHook:
https://www.facebook.com/pages/VW-T3-DokaSinka/129026087217120?ref=hl |
Bman Samba Member
Bman Samba Member
Posted: Thu Nov 29, 2018 11:31 am Post subject: Re: Vanagon & Westy Measurements/Dimensions |
I have an on-going Syncro Tintop project that I am installing a Westy Weekender package in, researching the correct bed lengths I need to fit a functioning bed between the plastic panels...
My TT Syncro has a Rock N Roll bed in it, but is well over 60", so far sourcing an actual weekender bed has been difficult, I have however been able to find this bench seat which I am told is from an 84 wolfsburg edition; note the extended bench bottom here, with the narrow bed, did a Wolfsburg have fixed arm rests?
The picture above shows a stock weekender bed come in at 60" long, my new Wolfsburg comes in at 59"
I did not have someone to hold the tape for me, but it is close onto 59".
Other measurements:
I can confirm the bottom cushion at 19"+.....
Top Cushion height:
What's interesting about this bench seat is the lower Westy built bench seat box, clearly built for the cardboard side panels, lengths:
And bottom edge:
I'm going to see if I can build a lower bench seat with the stock Westy plastic panel, I think I need the sheet metal sides....otherwise the option is to cut this Wolfsburg bottom, I am reluctant to do that, I would rather keep it stock or pass it on to another. _________________ ~Bryan
FaceHook:
crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Thu Nov 29, 2018 11:50 am Post subject: Re: Vanagon & Westy Measurements/Dimensions |
The 1 year model tintop 84 Wolfy Weekender that seat is from had armrests mounted to the side panels at both ends. These were very similar to the right side full Westy rear armrest. That is a great seat for people wanting to add a bed as it has a lot of storage room under it.
Not sure what you wish it for but modifying it some to work for you isn't a crime. That one is hardly in pristine shape at this point.
Mark |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Thu Apr 04, 2019 10:00 am Post subject: Re: Vanagon & Westy Measurements/Dimensions |
Does anybody happen to have the interior dimensions of the D pillar (tin top Vanagon) handy? I'm researching something and I don't have my van nearby to check a measurement.
Thanks in advance! _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Ironjenn Samba Member
Posted: Wed Jun 10, 2020 8:59 am Post subject: Re: Vanagon & Westy Measurements/Dimensions |
I'm hoping to make a tool organizer similar to the Westy Bravo - the snap-on one with the pockets that goes on the back of the rear cabinets- and need dimensions. Our van is currently in the shop having some work done. Does anyone have the dimensions of that back panel? I can only find the actual storage cabinet dimensions here, and the width of the back panel. I need dimensions illustrated in the photo attached - if anyone can help would be greatly appreciated!
danfromsyr Samba Member
Posted: Wed Jun 10, 2020 11:04 am Post subject: Re: Vanagon & Westy Measurements/Dimensions |
I walked out and measured on my 1980 camper.
9in wide at the top
13 1/4in wide at the crease
the crease is 17 3/4in from the bottom and 18 3/4in from the top.
9 1/4in wide to the little cut out
the cut out is 5.5in wide by 3.5in tall
the cabinet has an overall height of 36 3/4in following the face
measurements are approximates.. to the 1/4 in.
Ironjenn wrote: |
Posted: Thu Jun 11, 2020 5:38 am Post subject: Re: Vanagon & Westy Measurements/Dimensions |
Wow, thank you!!!!!!!! This is so helpful!! |
tjet Samba Member
Posted: Mon Feb 08, 2021 4:03 am Post subject: Re: Vanagon & Westy Measurements/Dimensions |
Posted: Thu May 06, 2021 2:08 pm Post subject: Re: Vanagon & Westy Measurements/Dimensions |
how about adding a link to Curtain (westy & Weekender) dimensions thread
https://www.thesamba.com/vw/forum/viewtopic.php?t=519259 _________________
Abscate wrote: |
These are the reasons we have words like wanker |
charleslabri Samba Member
Joined: December 08, 2019 Posts: 615 Location: Nashville/Yosemite
Sodo Samba Member
Joined: July 06, 2007 Posts: 9605 Location: Western WA
Posted: Tue Jul 20, 2021 10:33 am Post subject: Re: Vanagon & Westy Measurements/Dimensions |
Tin top seatback to front seat box is 67 inches.
Full Westfalia measure the same. _________________
....KTMs, GasGas, SPOT mtb
dobryan Samba Member
Joined: March 24, 2006 Posts: 16503 Location: Brookeville, MD
