HPMX float level question
wuwei75
wuwei75 is offline
PostPosted: Sat Feb 18, 2017 4:44 pm    Post subject: HPMX float level question Reply with quote
Hi all
Took my hpmx's apart to clean and such before installing and noticed that the floats are at different length from top of carb when seated. They are same for both carbs.
This normal?
Thanks
Brett
1974 Super Beetle (Jill)
1972 Fastback (Maude)
Mikedrevguy
Mikedrevguy is offline
PostPosted: Sat Feb 18, 2017 5:40 pm    Post subject: Re: HPMX float level question Reply with quote
Picture didn't come through, but not sure what you mean??
74 1303 (RevBug): plan for German Look
76 914 with 2260
69 Bwajaja
"The wise speak because they have something to say; while the foolish speak because they have to say something." Plato
Illigitimi non-Carborundum!!
wuwei75
wuwei75 is offline
PostPosted: Sat Feb 18, 2017 5:52 pm    Post subject: Re: HPMX float level question Reply with quote
not sure why pic didn't come through. Hmm.
Anyway, there are two floats, one for each bowl. ON the float closest to pivot, the distance to the top of the carb is 10mm exactly. But on the float furthest away from pivot, the distance is 13mm. It's the same set up on both carbs.
Hopefully that makes sense.
thanks,
brett
[email protected]
gkeeton@zbzoom.net is offline
PostPosted: Sat Feb 18, 2017 5:56 pm    Post subject: Re: HPMX float level question Reply with quote
When setting the level, you measure the point furthest away from the needle/seat. So, in your case, your float level is 13mm. If you're not off-roading, you could probably adjust them a little more so the measurement is closer to 10mm.
wuwei75
wuwei75 is offline
PostPosted: Sat Feb 18, 2017 6:30 pm    Post subject: Re: HPMX float level question Reply with quote
Thanks. In this case since the closest one is at 10 and furthest at 13, I'm assuming I carefully bend arm right at where closest float starts to 'level them out'?
Brett
mark tucker
mark tucker is offline
PostPosted: Sat Feb 18, 2017 6:33 pm    Post subject: Re: HPMX float level question Reply with quote
it's on a pivot. kinda hard to get them exzact.but it can be done.but it may be too high then. also ploat drop is very importaint.as is making sure the float dosent stick any where.
wuwei75
wuwei75 is offline
PostPosted: Sat Feb 18, 2017 6:51 pm    Post subject: Re: HPMX float level question Reply with quote
A tiny bit of tweak at pivot as mark said and both are at 10mm and then adjusted to 32.5 for max drop. Bada bing bada boom!
Thanks for all the help. Learning as I go!
Brett
Dale M.
Dale M. is offline
PostPosted: Sat Feb 18, 2017 8:21 pm    Post subject: Re: HPMX float level question Reply with quote
Not sure what you are seeing here... As you measure float at end furthermost from pivot..
Dale
slalombuggy
slalombuggy is offline
PostPosted: Sun Feb 19, 2017 12:12 am    Post subject: Re: HPMX float level question Reply with quote
Do not bend the arm to level them out.
Just measure from the float to the gasket at the furthest point. If you bent the arm straighten it out or your float level will be too high and you will flood your carbs.
brad
wuwei75
wuwei75 is offline
PostPosted: Sun Feb 19, 2017 5:02 am    Post subject: Re: HPMX float level question Reply with quote
brad
Are you suggesting I shouldn't adjust it at the pivot to make furthest point 10mm?
I verified when I adjusted at pivot that both floats were 10mm.
Thanks
Brrtt
67rustavenger
67rustavenger is offline
PostPosted: Sun Feb 19, 2017 8:18 am    Post subject: Re: HPMX float level question Reply with quote
Adjust the float level at the furthest point away from the pivot to 10mm with the gasket in place.
Just bend the little tab that the needle rides against.
FWIW I have mine set at 11.4mm. My engine seems to run better at that setting.
Good Luck.
brad
Thanks
Brrtt
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
wuwei75
wuwei75 is offline
PostPosted: Sun Feb 19, 2017 9:18 am    Post subject: Re: HPMX float level question Reply with quote
Awesome. That's what I did. We shall see how it goes. The joys of learning dual carbs.
Good Luck.
brad
Thanks
Brrtt
