dwill49965 Samba Member
Joined: August 08, 2005 Posts: 1396 Location: Dartmouth, Nova Scotia
Posted: Mon May 14, 2007 7:24 am Post subject: Molded oil breather replacement hose |
I searched and searched a multitude of related topics on this last night, and read through numerous posts, but didn't find the answer.
I've seen others post about using a molded, small diameter radiator hose from a modern vehicle to replace the oil breather hose on late bay FI engines. The main problem is finding one with a molded 90 degree curve, which can then be cut and trimmed to proper length. I'm not looking for one covered with braid. Engine is a '78 2.0 L, FI. It is item H at Ratwells vacuum hose diagrams -
http://www.ratwell.com/technical/VacuumHoses.html
The problem is that I can't find an old post where the make and year of vehicle is stated that they got the hose from, which obviously makes one a lot harder to track down.
Knowing the local auto parts stores around here, a request to try and match the hose would probably be met with stunned silence , followed by several minutes of insisting on "looking it up" in the computer, followed by a "sorry, can't help you."
So, can anyone recommend a vehicle that they've had success with? _________________ Darryl
'78 Westy, Boston Bob built 2.0 L, FI, MSD 6A
Meyer wrote: |
Lastly, you just referred to US citizens as 'Americans'. Exactly what kind of Canadian are you? From what continent? |
Posted: Mon May 14, 2007 9:31 am Post subject: |
I usually just take the old hose in with me and ask the counter person to let me look at their hoses hanging on the wall. You can also ask to look in their book. If will list the end sizes and then have pictures of the various hoses. |
Posted: Mon May 14, 2007 6:18 pm Post subject: |
Well, I guess I'll try that here. Trouble is, there are NO local places here with hoses on the wall. I'll go for the books someplace, or else google the hell out of "radiator hose sizes". Thanks. _________________ Darryl
Meyer wrote: |
fusername Samba Member
Joined: March 15, 2006 Posts: 2897 Location: Boston MA
Posted: Mon May 14, 2007 7:08 pm Post subject: |
Well mine is actually some sort of heavy flex line, I don't know what it is for. Autozone always seems to have racks of hoses, do a local google search. _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote: |
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
Posted: Fri May 18, 2007 5:17 pm Post subject: |
Up unitl this afternoon, the score was FLAPS 7 Darryl 0.
Carquest to the rescue. The parts guy let me go behind the counter to the back room and let me scope out the hose wall. Found a Gates #19833 which fit the bill the closest. Its a little bit too small - about a 19.5mm inner diameter, but it fit over the oil breather outlet. Cost about $24 CDN. The guy didn't even know what vehicle it was for, and I didn't find anything on a google search, but I'm happy.
Meyer wrote: |
webwalker Samba Member
Joined: January 26, 2006 Posts: 2803 Location: Mount Laurel, NJ
SGKent Samba Member
Posted: Thu Jan 17, 2013 10:00 am Post subject: |
These fit and work well _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Thu Jan 17, 2013 10:19 am Post subject: |
I just ordered the PCV hose and the double curve Decel hose today. I got one of the earliest S-boots he fabricated and it fits like a glove, so naturally I went back to him when I needed to replace the rest of the tough to find molded hoses.
M _________________ "Consistent maintenance with quality products is the cheapest warranty you'll ever need."
1977 CE1 Transporter Deluxe, Subaru EJ22, Skills Cooling, Steedle HD 091 w/ GuardT .82 4th
Click to view image |
Sprink1es Samba Member
Posted: Mon Feb 20, 2017 11:37 am Post subject: Re: Molded oil breather replacement hose |
Bumping this because I'm currently searching for a new 22mm ID oil breather hose ("H" in the Ratwell article)
Recently I realized my PO must have had the same problem, and used a modern 7/8" ID heater hose. The diameter is good, but the length is too short so it ended up kinking/pinching/collapsing. I'm wondering if it's giving me vacuum issues for why I'm running like crap at random times... My temp fix was to tighten a hose clamp over the kink to keep it from collapsing.
I don't want to pay $72 for the above repro hose, even though it is very pretty.
I found 7/8 ID heater hose for real cheap, but only in a straight length. I can't find a 90 degree elbow, so I figured I'd use an extra long hose lol
That "Gates 19833" hose DWill uses, everything is saying its only 3/4" ID so I'm worried I'll have to carve it out to make it fit. See http://www.oreillyauto.com/site/c/detail/GAT0/19833.oap?pt=02716&ppt=C0108
Elbow would be nice but I don't want to create more problems.
Anyone else have a cheap solution? Or have an aluminum/brass 90 degree barbed union/fitting? |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Mon Feb 20, 2017 12:02 pm Post subject: |
dwill49965 wrote: |
Looks like this guy solved your problem. He even shows the Gates part number
https://www.amazon.com/Gates-19833-Coolant-Hose/dp/B000Q0YPSC _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Posted: Mon Feb 20, 2017 4:16 pm Post subject: Re: Molded oil breather replacement hose |
Gee, that was almost 10 years ago. That Gates hose is still working fine, still pliable. _________________ Darryl
Meyer wrote: |
Posted: Tue Feb 21, 2017 7:41 pm Post subject: Re: Molded oil breather replacement hose |
^ When I plug in that part number, everything says it's 3/4" ID but ratwell calls for 7/8" ID. |
Posted: Tue Feb 21, 2017 8:14 pm Post subject: |
dwill49965 wrote: |
Its a little bit too small - about a 19.5mm inner diameter, but it fit over the oil breather outlet. |
Sprinkles wrote: |
That "Gates 19833" hose DWill uses, everything is saying its only 3/4" ID so I'm worried I'll have to carve it out to make it fit. |
Sprinkles wrote: |
Yup. I said that in one of my first posts. All the links that others have provided said the same thing - its a 3/4" inner diameter hose. It fits fine. You may have to warm it up or heat it up a little with a heat gun or hair dryer and it will slip right on and stay there. _________________ Darryl
Meyer wrote: |
Hoody Samba Member
Posted: Tue Feb 21, 2017 9:19 pm Post subject: Re: Molded oil breather replacement hose |
The only problem with going that route....if it's that tight. If you have a back fire and the hose doesn't let go, which is why you should not use clamps on these hoses....you can kiss your AFM goodbye. |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Wed Feb 22, 2017 2:51 am Post subject: Re: Molded oil breather replacement hose |
I use a hose that I found a good size in my Ace hardware in the plumbing section. It was thick enough walled that it wouldn't collapse, but flexible enough to make the bend. I shaved just a tiny bit off the bottom where it plugs into the breather so it would slide on _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
Posted: Wed Feb 22, 2017 4:29 pm Post subject: Re: Molded oil breather replacement hose |
I found/bought a 2 foot section of hose off Amazon - 7/8" ID, looks like reinforced hi-temp silicone. It bends easy enough but does not kink. Going to see how that works this weekend
https://www.amazon.com/gp/product/B00566KC7E/ |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
