pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
Posted: Sun Feb 12, 2017 2:46 pm Post subject: 914 has been sitting too long. How do I turn the motor by hand? |
Yeah- my fault. Car needed a new fuel filter and probably the gas tank cleaned, so didn't get it running. For a couple of years I spun it w/the starter once in a while- after recharging the battery. Won't spin at all now- presumably a bit of rust on the cyl walls. I've pulled the plugs, inserted fat drinking straws into thee cylinders, and poured in lots of WD-40 and PB Blaster, etc.
But the flywheel nut that's easily grabbed with a wrench on non-midships Porsche 4's-- and VW air cooled (and waterboxers) can't be reached So I jacked one side of the rear, and tried spinning the jacked wheel by hand-- but no luck. Then took off the jacked wheel and tried a lever between two of the lug studs, but without major fabrication, I can't get much leverage this way either. SO- Anyone got other secrets for breaking the bond between rings and the walls?? Yeah, considering putting an electric heater under one pair of cylinders, adding more Blaster, then the other, but more leverage seems lick the ticket. Thanks for any help! |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Sun Feb 12, 2017 4:15 pm Post subject: Re: 914 has been sitting too long. How do I turn the motor by hand? |
What gear did you put it in?
If you jack up one wheel and put it in 3rd or 4th you may do quite a bit better.
That being said.....if it takes this much effort....then its more than just a little rust on the cylinder walls.....and if you have that much crap on the cylinder walls....turning the engine over is just destroying the rings and bore.
Time to tear it down. Getting it broken loose is not going to buff out the damage caused by a rust ridge. Ray |
Bleyseng Samba Member
Posted: Sun Feb 12, 2017 4:49 pm Post subject: Re: 914 has been sitting too long. How do I turn the motor by hand? |
if its on concrete I'd put it in gear and rock it back and forth in 2nd gear. If it's heavily rusted oh well time to replace the pistons and cylinders. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Starbucket Samba Member
Posted: Fri Feb 17, 2017 4:06 pm Post subject: Re: 914 has been sitting too long. How do I turn the motor by hand? |
Remove the plugs, put in 4th gear and turn rear jacked up wheel backwards, if still no luck make a mix of 50% acetone/atf. That mix will break any rusted parts loose. |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1958 Location: FL Panhandle
Posted: Mon Feb 20, 2017 5:54 pm Post subject: Re: 914 has been sitting too long. How do I turn the motor by hand? |
Marvel Mystery Oil is a great penetrating fluid. Fill plug holes and let set couple days. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
Posted: Tue Feb 21, 2017 8:43 am Post subject: Re: 914 has been sitting too long. How do I turn the motor by hand? |
Always turn backwards after putting any fluid in plug holes to keep from bending a rod as backwards will push excess fluid out the intake valves. |
malcolm2 Samba Member
Joined: September 28, 2011 Posts: 1272 Location: Mount Juliet, TN
Posted: Mon Feb 27, 2017 4:43 pm Post subject: Re: 914 has been sitting too long. How do I turn the motor by hand? |
curious.... did you get it? |
