EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Thu Feb 23, 2017 9:19 am Post subject: Dellorto DRLA float needle clip |
Anyone know the size of these clips for Dellorto DRLA float? Seems to be metric, trying to source 2 of them locally, Thanks
http://www.fastech-racing.com/dellorto-needle-clip.html _________________ 1963 Ragtop Bug |
Danwvw Samba Member
Posted: Thu Feb 23, 2017 11:59 am Post subject: Re: Dellorto DRLA float needle clip |
Like little get 3 sizes at the hardware store one will fit! Yeah, I got a hold of a carb the other day that did not have one. Really though I don't think it's going to be a problem to run without one. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
Posted: Thu Feb 23, 2017 12:15 pm Post subject: Re: Dellorto DRLA float needle clip |
Danwvw wrote: |
Like little get 3 sizes at the hardware store one will fit! Yeah, I got a hold of a carb the other day that did not have one. Really though I don't think it's going to be a problem to run without one. |
Yea I got the 2 smallest ones at HD, but the smallest still slides off. I may run the carbs without them, Thx _________________ 1963 Ragtop Bug |
Danwvw Samba Member
Posted: Thu Feb 23, 2017 12:24 pm Post subject: Re: Dellorto DRLA float needle clip |
Humm, I have seen those at the local true value store the kind they have in the assorted sizes and the smallest is too small. But Yeah, they come in metric sizes like 2 mm or something. I think the size must be the ID the size of shaft they fit so they would be pretty little that little float shaft can't be much more than 1/16". _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
esde Samba Member
Joined: October 20, 2007 Posts: 5969 Location: central rust belt
Posted: Thu Feb 23, 2017 3:20 pm Post subject: Re: Dellorto DRLA float needle clip |
you can run without them, as there is no way for the screw to back out when the top is on the carb. _________________ modok wrote:
mcdragracer Samba Member
Posted: Thu Feb 23, 2017 11:11 pm Post subject: Re: Dellorto DRLA float needle clip |
Yes not necessary, but if you want I'll send you 2 for free. |
j-dub Samba Member
Joined: November 09, 2003 Posts: 865 Location: Phoenix, AZ
Posted: Fri Feb 24, 2017 8:02 am Post subject: Re: Dellorto DRLA float needle clip |
Without the e-clip the float can slide back and fourth and sometimes the float will bind in the far position. I have seen a small bit of wire twisted around the shaft in the grove to work in a pinch. _________________ 1957 Oval rag
"POLICE STATION TOILET STOLEN ... Cops have nothing to go on." |
HBRag Samba Member
Joined: April 29, 2005 Posts: 735 Location: Huntington Beach, CA
Danwvw Samba Member
