MConstable Samba Member
Joined: May 04, 2004 Posts: 1822 Location: Saint Charles IL
Posted: Tue Feb 28, 2017 9:18 pm Post subject: No brakes... |
Brake pedal popped and went to the floor, what do I do to fix it?
Thanks in advance |
CraigInPA Samba Member
Joined: March 09, 2011 Posts: 212 Location: Norristown, PA
Posted: Wed Mar 01, 2017 8:14 am Post subject: Re: No brakes... |
Look underneath the car for a puddle of brake fluid.
Correct any leaks and/or repair any leaking parts.
Re-fill the reservoir.
Bleed the master cylinder.
Bleed the brake system. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5986 Location: Brooklyn
Posted: Wed Mar 01, 2017 9:52 am Post subject: Re: No brakes... |
MConstable wrote: |
Thanks in advance |
1) Go find out what broke and tell us. Otherwise we have no idea what you should do to fix it. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Mon Mar 06, 2017 9:19 am Post subject: Re: No brakes... |
Ok, finally getting around to troubleshooting, filled reservoir, leak is coming from the master cylinder.
Hard lines aren't leaking, and it looks like the soft ones on top aren't either.
I'll get the wheel off and examine closer when I get time.
It is a big leak though, took all of 30 seconds to empty the reservoir
ente_kaefer Samba Member
Joined: August 22, 2013 Posts: 241 Location: St Louis, MO
Posted: Mon Mar 06, 2017 11:11 am Post subject: Re: No brakes... |
MConstable wrote: |
Ok, finally getting around to troubleshooting, where the heck is the master cylinder and reservoir?
I would check my Bentley but it's in Indiana and I'm in South Dakota.
Thanks guys |
The master brake cylinder is located behind the left front tire, and behind the firewall behind the rod from the brake pedal. Best way to get to it is to remove the gas tank.
Brake fluid reservoir is located under the dash above the hump that runs down the middle of the vehicle. There should be two, blue, braided hoses coming out of the bottom of the reservoir. |
Posted: Mon Mar 06, 2017 11:15 am Post subject: Re: No brakes... |
Thanks so much, I just edited my previous post.
Leak is at the master cylinder.
thanks for the tip on easiest way to get to it.
It's greatly appreciated. |
hobie16 Samba Member
Posted: Mon Mar 06, 2017 7:52 pm Post subject: Re: No brakes... |
ente_kaefer wrote: |
MConstable wrote: |
Thanks guys |
You don't need to pull the gas tank to replace the master cylinder.
Jack up the left front of the car and pull the wheel. Remove the hard lines and wiring.
Get inside the car and undo the bolts. DO NOT PULL THEM OUT!!! If you do the spacers between the sheet metal will drop turning the replacement job into a fishing expedition to get them out.
Go to http://www.vw-resource.com/master_cylinder.html#replacement for a detailed description to replace. _________________ Don't be fooled by appearances. In Hawaii, some of the most powerful people look like bums and stuntmen.
--- Matt King
If anything’s going to happen, it’s going to happen out there.
---Captain Ron |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Tue Mar 07, 2017 3:06 pm Post subject: Re: No brakes... |
Make sure it is not the front to back hard line it runs right under the brake pedal and always look like the master cylinder is leaking most the time the master cylinder does leak as you have said 99 times out of a 100 it is the brake line under the pedals. |
Posted: Wed Mar 08, 2017 6:48 am Post subject: Re: No brakes... |
citroen wrote: |
Thank you so much, I've never messed with the brakes on any of the air cooled VW's I've owned...and again, my Bentley is in Indiana and I'm in South Dakota.
Which hard line goes to the back wheels?
The two soft lines on top are dry and both hard lines on the side of the master cylinder facing the left front wheel are dry. |
BNMike Samba Member
Joined: November 12, 2009 Posts: 333 Location: Hot Springs, SD
Posted: Wed Mar 08, 2017 9:35 am Post subject: Re: No brakes... |
MConstable wrote: |
Where in South Dakota? I've got both the Bentley, and the car, out in the Black Hills.
BNMike |
Posted: Wed Mar 08, 2017 12:04 pm Post subject: Re: No brakes... |
The line goes from the master cylinder to the rear they seem to rust and brake right under the brake pedal that is were all the water gets and it makes a hole in the line |
Posted: Wed Mar 15, 2017 1:03 pm Post subject: Re: No brakes... |
You guys are awesome as always...thanks!
If it is the master cylinder, which brand is the best replacement? |
