driftman11 Samba Member
Joined: August 01, 2012 Posts: 141 Location: little rock,ar
Posted: Sat Mar 04, 2017 10:10 pm Post subject: Generator idiot light comes on with key, but Not charging still? |
So today I started my vw thing's engine for first time after re-installing it. I started it today and it ran the battery down and died. My gen. idiot light comes on when the key is turned on. It goes off when running, making me think it was functional. Anybody have any insight on what could cause this? |
74 Thing Samba Member
Posted: Sun Mar 05, 2017 8:51 am Post subject: Re: Generator idiot light comes on with key, but Not charging still? |
alright, so I just tried to polarize the generator. When I touched the power wire, it spun for like 1 second then stopped. now it won't spin anymore by doing this. Does this mean its bad or could something else have happened? |
Posted: Mon Mar 06, 2017 10:52 am Post subject: Re: Generator idiot light comes on with key, but Not charging still? |
yep. I think it came down to the wiring. while further testing, I noticed the spot where my ground connects to body from battery was throwing sparks, meaning it had bad connection. I cleaned up both the wire and the mounting point, and hooked it back up. did a test run, no sparks and my multimeter showed an increasing voltage at battery once it was running, showing that my generator was indeed charging the battery. within couple minutes it went from 12.6 to 14.3. This seems to be symptoms of a good charging system? |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Tue Mar 07, 2017 3:16 pm Post subject: Re: Generator idiot light comes on with key, but Not charging still? |
I always run extra grounds you can't have too many grounds remember you are driving a over 40 year old pile of rust with paint making it look good or not. |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Tue Mar 07, 2017 8:29 pm Post subject: Re: Generator idiot light comes on with key, but Not charging still? |
Are you talking about me putting to much paint on and you have to make new grounds? |
Posted: Wed Mar 08, 2017 12:07 pm Post subject: Re: Generator idiot light comes on with key, but Not charging still? |
Ron Domeck wrote: |
yes |
