EeVeeWee Samba Member
Joined: April 02, 2015 Posts: 836 Location: Amersfoort, Netherlands
Posted: Sat Mar 04, 2017 10:12 am Post subject: Dormobile roof, hinges left or right? |
I fitted my Dormobile roof for the first time.
It's on a LHD bus and I guess it's from a Bay Window bus, because there are locking rubbers at the outside.
I prefer the hinges at the opposite of the swing doors, but noticed that the front side is a bit other shaped than the back side.
The bottom edge of the roof is slightly wider at the back.
Is there a front and back side of a Dormobile roof?
I see them hinged at both side on Split Buses, but may be because it's a Bay window roof?
sled Samba Member
Posted: Sat Mar 04, 2017 10:39 am Post subject: Re: Dormobile roof, hinges left or right? |
Well, the simplest determining factor for me is that you can not run a westy tent if the roof hinges on the door side...
It should fit/work fine the way you have it. _________________ drive your split. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Sat Mar 04, 2017 10:46 am Post subject: Re: Dormobile roof, hinges left or right? |
5...4...3...2...1...Pyro? |
srfndoc Samba Member
Posted: Sat Mar 04, 2017 12:08 pm Post subject: Re: Dormobile roof, hinges left or right? |
A tent can be done with either side but not easily on the hinge side as Jake mentioned. You lose the ability to slide the final pole in that pulls the canvas tight. Here's an example:
_________________ RPM=(MPH*336* (R&P*4th*1.26))/Tire Diameter in inches |
Birdmanhere Samba Member
Joined: June 03, 2006 Posts: 1054 Location: CANADA EH
Posted: Sat Mar 04, 2017 12:43 pm Post subject: Re: Dormobile roof, hinges left or right? |
I hinged mine like you have yours set up, it was off of a Bay.
Most are hinged to open with the tent side above the doors.
We use an awning while camping and would not be able to the other way, plus I like the look of the windows on the open top, looking in from the door.
Also before you use those outside mounted hold down straps that look like Baja hood straps, you can get the original style straps and clasps right from Dormobile. _________________ 66 Bus
71 Bug |
Clara Samba Member
Posted: Sat Mar 04, 2017 1:03 pm Post subject: Re: Dormobile roof, hinges left or right? |
If you want to hang a westy tent
do it like this factory SO-42 dormobile:
the rear tent mount was modified/ cut slightly
I have seen bays with the same orientation:
_________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Sat Mar 04, 2017 3:08 pm Post subject: Re: Dormobile roof, hinges left or right? |
sled wrote: |
It should fit/work fine the way you have it. |
A Westy tent is no option, so this means the hinge side doesn't matter.
Thanx! |
Posted: Sat Mar 04, 2017 3:11 pm Post subject: Re: Dormobile roof, hinges left or right? |
Birdmanhere wrote: |
Also before you use those outside mounted hold down straps that look like Baja hood straps, you can get the original style straps and clasps right from Dormobile. |
Yes I know what you mean, these ones:
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12409 Location: Over 2002 posts deleted!
Posted: Mon Mar 06, 2017 7:59 am Post subject: Re: Dormobile roof, hinges left or right? |
BarryL wrote: |
EeVeeWee wrote: |
sled wrote: |
Thanx! |
The options are always open!
My top is also off a '69 phatchick and it's true that the front "edge" is shallower than the back one. I should have shaved some to make it fit better but didn't.
Anyway, I wanted my top hinged at the doors side. At the time I didn't care about a tent or paying so much for one as they are costly. However, last year I scored on this phatchick one and it fits bitchen!
Ultimately it is a personal choice as to how you want to use your bus. So knock yourself out and go with what you want! _________________ Some people are so busy being clever they don't have time enough to be wise. |
pyrOman Fire Master
Posted: Mon Mar 06, 2017 8:06 am Post subject: Re: Dormobile roof, hinges left or right? |
Here's how I use the "baja rubber straps" to hold down the Dormobil top on the inside!!!
Posted: Mon Mar 06, 2017 10:13 am Post subject: Re: Dormobile roof, hinges left or right? |
pyrOman wrote: |
That is exactly what I decided to do yesterday!
I don't mount the beds anyway, so I have space room for that. |
pyrOman Fire Master
Posted: Mon Mar 06, 2017 10:43 am Post subject: Re: Dormobile roof, hinges left or right? |
EeVeeWee wrote: |
pyrOman wrote: |
You do want to get the stronger more solid like catches for the rubber straps or beef up the ones you get! Common ones are weak and can bent back thus allowing the top to pop up while driving. Don't ask me how I know. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Mon Mar 06, 2017 12:11 pm Post subject: Re: Dormobile roof, hinges left or right? |
pyrOman wrote: |
You do want to get the stronger more solid like catches for the rubber straps or beef up the ones you get! Common ones are weak and can bent back thus allowing the top to pop up while driving. Don't ask me how I know. |
Really! Much damage? |
pyrOman Fire Master
Posted: Mon Mar 06, 2017 12:58 pm Post subject: Re: Dormobile roof, hinges left or right? |
As with anything, it all depends on the speed of the vehicle when it happens but it is no fun at ANY speed! Just make sure that when latched there is absolutely no chance of the tabs failing. On that note, I actually have an extra strap at the front just in case since I noticed the front rubber strap was becoming "soft". So even with beefing up the catch there may be a possibility of the rubber to give way. I'll try to snap a pix of the extra strap and post it here later. _________________ Some people are so busy being clever they don't have time enough to be wise. |
Posted: Mon Mar 06, 2017 2:44 pm Post subject: Re: Dormobile roof, hinges left or right? |
pyrOman wrote: |
As with anything, it all depends on the speed of the vehicle when it happens but it is no fun at ANY speed! Just make sure that when latched there is absolutely no chance of the tabs failing. On that note, I actually have an extra strap at the front just in case since I noticed the front rubber strap was becoming "soft". So even with beefing up the catch there may be a possibility of the rubber to give way. I'll try to snap a pix of the extra strap and post it here later. |
OK good advice, thanks! |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Mon Mar 06, 2017 6:01 pm Post subject: Re: Dormobile roof, hinges left or right? |
srfndoc wrote: |
I liked the conventional way where the hinges are on the side opposite of the cargo doors (aka driver side) as it was on my bus, and just about every LHD dormy in europe.
what i like in the picture is the window in the side of the fabric.
chances are it is going to be way too bright in there for here in the south. still like it _________________ regards
Uli
Posted: Tue Mar 07, 2017 3:19 pm Post subject: Re: Dormobile roof, hinges left or right? |
mandraks wrote: |
srfndoc wrote: |
chances are it is going to be way too bright in there for here in the south. still like it |
I prefer horizontal stripes.
But I made holes already, the hinges will be at the left side indeed:
Posted: Tue Mar 07, 2017 6:42 pm Post subject: Re: Dormobile roof, hinges left or right? |
vertical stripes are slimming, but i do like the original pattern better as well.
dormies are super bright, i would be thinking about tinting the windows, or putting up curtains.
bus and roof look good _________________ regards
Uli
