Generator idiot light comes on with key, but Not charging still?
driftman11
driftman11 is offline
PostPosted: Sat Mar 04, 2017 10:10 pm    Post subject: Generator idiot light comes on with key, but Not charging still? Reply with quote
So today I started my vw thing's engine for first time after re-installing it. I started it today and it ran the battery down and died. My gen. idiot light comes on when the key is turned on. It goes off when running, making me think it was functional. Anybody have any insight on what could cause this?
74 Thing
74 Thing is offline
PostPosted: Sat Mar 04, 2017 11:49 pm    Post subject: Re: Generator idiot light comes on with key, but Not charging still? Reply with quote
Did you check the brushes, the wires and wire ends, regulators, is it polarized?
http://www.thesamba.com/vw/forum/viewtopic.php?t=337164&highlight=polarizing+generator
driftman11
PostPosted: Sun Mar 05, 2017 8:51 am    Post subject: Re: Generator idiot light comes on with key, but Not charging still? Reply with quote
alright, so I just tried to polarize the generator. When I touched the power wire, it spun for like 1 second then stopped. now it won't spin anymore by doing this. Does this mean its bad or could something else have happened?
74 Thing
74 Thing is offline
PostPosted: Sun Mar 05, 2017 1:10 pm    Post subject: Re: Generator idiot light comes on with key, but Not charging still? Reply with quote
It is either the wiring, reglulator, or generator.
There are lots of tests for the generator (some are here or search thesamba-get your volt meter out)...
https://www.youtube.com/watch?v=RjLW_eb3D-c
https://www.youtube.com/watch?v=JUeeuDrIKVQ
Maybe it is time for a rebuild.
driftman11
PostPosted: Mon Mar 06, 2017 10:52 am    Post subject: Re: Generator idiot light comes on with key, but Not charging still? Reply with quote
yep. I think it came down to the wiring. while further testing, I noticed the spot where my ground connects to body from battery was throwing sparks, meaning it had bad connection. I cleaned up both the wire and the mounting point, and hooked it back up. did a test run, no sparks and my multimeter showed an increasing voltage at battery once it was running, showing that my generator was indeed charging the battery. within couple minutes it went from 12.6 to 14.3. This seems to be symptoms of a good charging system?
citroen
citroen is offline
PostPosted: Tue Mar 07, 2017 3:16 pm    Post subject: Re: Generator idiot light comes on with key, but Not charging still? Reply with quote
I always run extra grounds you can't have too many grounds remember you are driving a over 40 year old pile of rust with paint making it look good or not.
Ron Domeck
Ron Domeck is offline
PostPosted: Tue Mar 07, 2017 8:29 pm    Post subject: Re: Generator idiot light comes on with key, but Not charging still? Reply with quote
Are you talking about me putting to much paint on and you have to make new grounds?
citroen
citroen is offline
PostPosted: Wed Mar 08, 2017 12:07 pm    Post subject: Re: Generator idiot light comes on with key, but Not charging still? Reply with quote
yes
