40 horse oil pump??
RPGreg2600
RPGreg2600 is offline
PostPosted: Wed Mar 08, 2017 9:50 pm    Post subject: 40 horse oil pump?? Reply with quote
Does anyone sell an oil pump with the correct 6mm holes for the studs? I've ordered 2 pumps so far, one from IMC, and one from Wolfsburg West. I haven't found anyone else who lists a pump as fitting a 40 horse. Both have 8mm holes, which makes centering the pump in the case not so exact...
RPGreg2600
PostPosted: Thu Mar 09, 2017 8:53 am    Post subject: Re: 40 horse oil pump?? Reply with quote
I was wrong, the ww pump has more like 7mm holes which are about what the original pump had... nevermind.
ONEBADBUG
ONEBADBUG is offline
PostPosted: Thu Mar 09, 2017 9:34 am    Post subject: Re: 40 horse oil pump?? Reply with quote
I could sell you an old original pump, but to use an 8 mm pump, I use flange head bolts, and make sure the space is full of sealant.
diablosandwich
diablosandwich is offline
PostPosted: Thu Mar 09, 2017 8:45 pm    Post subject: Re: 40 horse oil pump?? Reply with quote
Here are a couple from the classifieds... http://www.thesamba.com/vw/classifieds/detail.php?id=2027644
http://www.thesamba.com/vw/classifieds/detail.php?id=1680314
1966 Java Greens
