noelleon Samba Member
Posted: Fri Mar 10, 2017 12:34 pm Post subject: Aluminum rack for NAHT hightop |
So after using our NAHT for about a year and half now...I'm looking to add a rack system. I wanted it to be aluminum, lightweight, modular, and to increase the available solar area up top (also deleted and replacing the fan up there).
So this is what I've got so far! Curious as to feedback (NAHT owners as well!)
Right now the unit calculates out at under 20lbs (unloaded of course).
Rear unit:
Front:
Red Beard Samba Member
Joined: May 09, 2006 Posts: 463 Location: Seattle, WA
Posted: Fri Mar 10, 2017 12:50 pm Post subject: Re: Aluminum rack for NAHT hightop |
WANT! Let me know if you want to make two of them
I really like the idea of a lightweight, form fitted rack. |
Posted: Fri Mar 10, 2017 1:16 pm Post subject: Re: Aluminum rack for NAHT hightop |
Red Beard wrote: |
Will do. Planning to waterjet so it shouldn't be too tricky to make a couple. |
dsdunbar Samba Member
Joined: December 19, 2014 Posts: 564 Location: Crozet VA
Posted: Fri Mar 10, 2017 1:52 pm Post subject: Re: Aluminum rack for NAHT hightop |
The non-structural engineer in me asks:
How thick? is it tubular or just solid pieces of Aluminum?
The sketches look awesome...but structurally, how are you determining load capacity etc?
noelleon wrote: |
Red Beard wrote: |
_________________ '89 2WD Westy "Grey Goose" - Manual 4spd
Crozet VA
Vanaru EJ25, Peloquin |
Posted: Fri Mar 10, 2017 2:28 pm Post subject: Re: Aluminum rack for NAHT hightop |
dsdunbar wrote: |
Going to be a mix. It's designed to hold most of the weight as low as possible, with the top panel for solar acting like a truss for the larger spans. It's weakest spot currently is a side load against the top in the middle: shown here:
I'll be reinforcing the rear span of the front unit and the front span of the rear unit to minimize that. Most likely tube sections welded in. So far it's modeled in 1/8 6061 sheet. We'll see what needs to change after the first mockups.
I also need to measure and account for the degree of flex in the top itself, which the first mockup will also help me do. |
h00drat Samba Member
TequilaSunSet Samba Member
Joined: May 30, 2012 Posts: 2109 Location: Philippines
Posted: Fri Mar 10, 2017 6:27 pm Post subject: Re: Aluminum rack for NAHT hightop |
Me like... I like the rear one, even if I didn't ever use it, just looks damn cool to me _________________ Don't harsh my mellow...
1985 Hightower Vanagon 1.8T- Gone
1972 Panel Bus- Gone
1967 Bug- Gone
1964 Euro Sunroof Bug- Gone
1969/72/63 Sunroof Bug- Gone
1975 Brazilian Bug in the Philippines 🇵🇭- New to me |
tates1882 Samba Member
Joined: August 07, 2012 Posts: 275 Location: Southwest Idaho
Posted: Fri Mar 10, 2017 7:40 pm Post subject: Re: Aluminum rack for NAHT hightop |
I don't like it, Aesthetically I'm not one for a bunch of racking. Also the center of gravity would increase quite a bit, especially with liquid sloshing around in the cans. The roof gutters may also be stressed especially if the naht installer butchered the roof up. My van a 2.2 subie with 225/55 tires would not be able to run in 4th gear with that much more drag and any kind of headwind, it struggles now with just the naht and awning. Every time I see a westy or naht with swing aways, bikes, roof racks and hitch platforms I wonder just how far over the gvw they are or just how pitiful is their fuel mileage. Just my two cents. _________________ 88 Vanaru, ej22, naht |
tosimplify Samba Member
Joined: June 08, 2009 Posts: 110 Location: The Open Road
Posted: Fri Mar 10, 2017 8:09 pm Post subject: Re: Aluminum rack for NAHT hightop |
Points for the cool factor alone, but...If your main reason for doing this is to increase solar capacity, consider flexible panels instead, secured to the top with 3M Dual Lock. I managed to fit 255 watts on my hightop using just the middle and rear sections, and it's held up great during the past year+ of full time travel. I'll be adding another 100 watts to the forward section soon, using the same method.
Having said that, I do like your idea of a rack that would allow one to mount stuff to the rear of the top. Never been a fan of how that bare wall looks.
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10252 Location: N. Idaho
Posted: Fri Mar 10, 2017 8:22 pm Post subject: Re: Aluminum rack for NAHT hightop |
It would be useful to cut cleat-like shapes here n there along edges since your jetting it. Those could then be bent up at 45 deg and provide stout tie downs. Or loop shapes. It might also be useful to make provision for people to bolt on existing gear carriers such as having false rain gutters up the sloped back to secure an everyday bike or ski carrier. And perhaps holes drilled along edges likely to be used to secure obvious wire runs up to solar or the light bars you mocked up. Heck, how about half moon cutouts where you'd lay a ladder to climb up for best 4th of July viewing. Dang, possibilities are endless! Bravo. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
jimf909 Samba Member
Posted: Sat Mar 11, 2017 9:10 am Post subject: Re: Aluminum rack for NAHT hightop |
Can you point me to the source of your panels? I'm particularly interested in the one on the rear deck. I'd really like to find modular panels in strips two cells wide to install around my Fantastic fan on the top of the roof.
Thanks.
tosimplify wrote: |
_________________ - Jim
Abscate wrote: |
Posted: Sat Mar 11, 2017 9:15 am Post subject: Re: Aluminum rack for NAHT hightop |
Red Beard wrote: |
I'm interested also. I understand tate's points, but I'd really like a rack to carry SUPs or a kayak.
The rack looks great! Looking forward to seeing how it develops. _________________ - Jim
Abscate wrote: |
Posted: Sat Mar 11, 2017 9:36 am Post subject: Re: Aluminum rack for NAHT hightop |
Those are very cool panels. I'm also working on moving the venting system to the slanted area before the step down. I dig our fan but I'd love to be able to vent air in the rain. My thought is to make a cover for the lower shelf to hold that system.
I did a version using just rails and there definitely some advantages, but...I can save weight and just kinda dig first method...
so I combined the two and some of your thoughts:
The partial rail system gives strength in the weak spot and allows for hidden cable routing.
Now I only have about a 3/4 Inch deviation with a 100 pound push on the weakest spot. |
Type17 Samba Member
Joined: April 24, 2012 Posts: 300 Location: Chicagoland
Posted: Sat Mar 11, 2017 9:49 am Post subject: Re: Aluminum rack for NAHT hightop |
Very cool idea, I'm looking forward to seeing where this goes. _________________ I don't check these forums daily and often loose track of threads and comments. Please PM me a reminder if you're waiting on a reply. Thanks! |
chachi Samba Member
Joined: November 18, 2003 Posts: 858 Location: the weeds
Posted: Sat Mar 11, 2017 10:20 am Post subject: Re: Aluminum rack for NAHT hightop |
love it, best design for a NAHT rack yet. i especially love that you could just have the front or back racks. _________________ '74 transporter panel
'91 vanagon carat NAHT |
Posted: Sat Mar 11, 2017 10:31 am Post subject: Re: Aluminum rack for NAHT hightop |
jimf909 wrote: |
Can you point me to the source of your panels? I'm particularly interested in the one on the rear deck. I'd really like to find modular panels in strips two cells wide to install around my Fantastic fan on the top of the roof. |
I bought these panels from dhgate.com, though I've since checked the site, and it looks like they're not available anymore. The two bigger panels are 90 watts, and the smaller one is 75. |
Aryana Samba Member
Joined: November 09, 2015 Posts: 568 Location: Southern CA
Posted: Sat Mar 11, 2017 11:07 am Post subject: Re: Aluminum rack for NAHT hightop |
Ok, I'm subscribed! Interesting design and looking forward to seeing pics of it in the flesh. |
Zeitgeist 13 Samba Member
Posted: Sat Mar 11, 2017 12:30 pm Post subject: Re: Aluminum rack for NAHT hightop |
That rack appears to make the NAHT design much more palatable from an aesthetic perspective and adds functional load bearing and attachment points to the top. That's a solid conceptual approach and I can't wait to see a working prototype. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
bivouac Samba Member
Joined: August 18, 2010 Posts: 8 Location: Somewhereville, USA
Posted: Thu Jun 22, 2017 8:09 am Post subject: Re: Aluminum rack for NAHT hightop |
I've been wanting something like this for my '87 NAHT Syncro, make it! _________________ '87 Syncro NAHT Camper EJ25
‘84 Westfalia 1.9
'90 Multivan EJ22 |
chachi Samba Member
Posted: Fri Jun 23, 2017 7:27 am Post subject: Re: Aluminum rack for NAHT hightop |
jimf909 wrote: |
last time i talked to NAHT installer kevin gratton, he was or already had ordered some sets of custom solar panels that fit either side of the Fantastic Fan. might check with him and see if he has any left. they were 25w each. instagram: @veedubdayspa _________________ '74 transporter panel
