socalsean Samba Member
Joined: December 11, 2008 Posts: 24 Location: Monterey, CA
Posted: Mon Mar 13, 2017 6:24 pm Post subject: What type Judson is this? |
A friend of mine was cleaning out his garage and gave this to me about about 18 years ago. He said it was for a 40hp but wasn't certain. The pulley that came with it (for the blower) uses two belts.
Is this for a 36 or a 40? If the ID tag is useless to answer this question what can I measure on the blower itself to determine it's application? Thanks in advance.
sean |
Steve22 Samba Member
Joined: March 05, 2004 Posts: 1389 Location: the wild unknown
Posted: Tue Mar 14, 2017 12:33 pm Post subject: Re: What type Judson is this? |
2 belts = 36hp pulley _________________ '65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
'73 Sunroof Transporter |
Posted: Wed Mar 15, 2017 8:50 am Post subject: Re: What type Judson is this? |
Steve22 wrote: |
2 belts = 36hp pulley |
Thanks for the reply. My only concern is that the pulley may not be the correct one for the blower as everything was taken apart and tossed in a box when I received it.
What other type of identification can be used to make sure it is indeed for a 36hp?
sean |
Posted: Wed Mar 15, 2017 12:40 pm Post subject: Re: What type Judson is this? |
The Judson Register (or at least the info from it) should be in the archives section above. If memory serves, then the VW2 is the 40 horse model. _________________ '65 Karmann Ghia 'vert
'73 Super Beetle
'59 Beetle ragtop
Posted: Thu Mar 16, 2017 7:45 pm Post subject: Re: What type Judson is this? |
Steve22 wrote: |
The Judson Register (or at least the info from it) should be in the archives section above. If memory serves, then the VW2 is the 40 horse model. |
Thanks again. I've browsed through that archive but didn't find anything to answer my question. I will go back and read through everything.
sean |
John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13953 Location: Southampton U.K.
Posted: Tue Mar 28, 2017 1:08 am Post subject: Re: What type Judson is this? |
socalsean wrote: |
Steve22 wrote: |
sean |
If the label has "VW" on it the blower will be a 36hp.
It wasn't until the 40hp version arrived (designated "VWII" on the ID label) that the 36hp label was changed to read "VWI"
Even without the blower pulley you can tell which blower version you have. Turn it upside down and measure from the centre of the outlet port to the front plate and from the centre of the outlet port to the back plate. If they are the same (ie centred) then you have the 36hp blower. If it is shorter to the back plate than the front you have the 40hp version. _________________ John.
