JDub113 Samba Member
Posted: Mon Mar 13, 2017 5:40 pm Post subject: 11cent odometer fix |
My odometer didn't work when I got the van. I took it apart and like most others, that odo gear slid out passed the worm gear that turns it. I went to a local Ace Hardware and they have all sorts of little odds and ends there. Each Ace is independently owned, so maybe yours won't carry these "push washers" or retention washers.
I pushed the little axel out from the number wheels with a straightened piece of wire to keep everything in place. I slid on the washer and it grabs very firmly to the axle. My only regret is not having it on the opposite way to give me more room for the gear to slide fully onto the other side... the axel is 3/4 into the gear. I might have to do this all over again. We'll see how long I get by, but it's almost perfect.
I think this could work for both model speedometers?
I'd put it in and test but I need to replace a leaky 3 prong brake sensor from the master cylinder, and put a new o2 coax wire in still.
_________________ 84 Wolfsburg Edition Westy
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Mon Mar 13, 2017 6:32 pm Post subject: Re: .11c odometer fix |
Good fix.
Did you mean $0.11, or 0.11 cents ($0.0011)?
I am reminded of Verizon thinking that quoting 0.002c/kB was the same as the $0.002/kB they actually charged for data usage - and having to admit they were wrong.
https://consumerist.com/2006/12/10/transcript-verizon-doesnt-know-how-to-count/ (among other sources) _________________ Jim Crowther
Vespa GTS 300 |
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Tue Mar 14, 2017 8:49 am Post subject: Re: .11c odometer fix |
fxr wrote: |
Did you mean $0.11, or 0.11 cents ($0.0011)? |
Or 11/100ths of one degree Centigrade? _________________ '87 Westy in Wolfram Grey Metallic |
bluebus86 Banned
Posted: Tue Mar 14, 2017 10:37 am Post subject: Re: 11cent odometer fix |
Haha maybe that's better for ya. Can't believe I read that whole article. Unbelievable. _________________ 84 Wolfsburg Edition Westy |
Mac_Daddy_Westy Samba Member
Joined: October 27, 2011 Posts: 154 Location: San Antonio, Tx
Posted: Tue Mar 14, 2017 11:28 am Post subject: Re: 11cent odometer fix |
this is the best idea for odometer fix I've seen, should be bookmarked! thank you! |
Posted: Tue Mar 14, 2017 12:44 pm Post subject: Re: 11cent odometer fix |
The retention washer fix is a great idea for the shaft's moving out of position, but the problem I and many others encountered is the looseness of one or more of the gears on that shaft. You might still discover that you have that problem, for which staking the shaft lightly works very well.
Good fix and great input! Thanks! _________________ '87 Westy in Wolfram Grey Metallic |
TequilaSunSet Samba Member
Joined: May 30, 2012 Posts: 2109 Location: Philippines
Posted: Tue Mar 14, 2017 2:20 pm Post subject: Re: 11cent odometer fix |
campism wrote: |
Good fix and great input! Thanks! |
Yup my similar fix was not the cure... ended up sending the unit to Van Cafe for a rebuild, works like a charm ever since! _________________ Don't harsh my mellow...
1985 Hightower Vanagon 1.8T- Gone
1972 Panel Bus- Gone
1967 Bug- Gone
1964 Euro Sunroof Bug- Gone
1969/72/63 Sunroof Bug- Gone
1975 Brazilian Bug in the Philippines 🇵🇭- New to me |
Posted: Tue Mar 14, 2017 3:31 pm Post subject: Re: 11cent odometer fix |
Thanks guys. Now I guess I'll see if all the number gears grab, spin, and if the fix holds. I should be on the road in a couple weeks unless I break something else. _________________ 84 Wolfsburg Edition Westy |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Tue Mar 14, 2017 5:42 pm Post subject: Re: 11cent odometer fix |
An even cheaper fix is to get a pair of side cutters and pinch the shaft where the gear rides on. That way the gear bites into the shaft and will not turn.
Saves you $.11 and the $5 for gas. |
Posted: Wed Mar 15, 2017 9:55 am Post subject: Re: 11cent odometer fix |
You are right if that was the problem; however I needed a washer to keep the shaft with gear from coming out of the housing.
*I originally wanted to put the washer on, facing the other direction so I'd have more room to put the gear on all the way on the other side. Once I removed the axle, I kind of abandoned the idea and ran it like I did. I did NOT NEED to remove the axle, but you learn as you go.
If anyone is going to do this, I'd get a couple washers and then carefully just slip one on without moving the gear on the other side when pushing it on. If you do, make sure both ends have enough room on the axle to function with still having a little play so nothing binds. _________________ 84 Wolfsburg Edition Westy |
Posted: Thu Mar 16, 2017 7:34 am Post subject: Re: 11cent odometer fix |
JDub113 wrote: |
A properly secured gear, will not allow the shaft to slide out. If the shaft does slide out, it's because the gear is not held in place. By installing your clip, it may prevent the shaft from sliding all the way out, but if the shaft is sliding that direction, the gear is loose.
A good mechanical bond of the gear fixes the odometer issue. Some use glue, a good mechanical bond works for me. You do not need to peen the shaft too much, just enough to add some teeth.
Understanding the entire problem will allow you to come up with a proper solution. A clip is not needed. |
Posted: Thu Mar 16, 2017 9:43 am Post subject: Re: 11cent odometer fix |
I understand. That will be the plan if or when it walks out again. Thanks _________________ 84 Wolfsburg Edition Westy |
Posted: Sun Apr 02, 2017 4:24 pm Post subject: Re: 11cent odometer fix |
Just want to report that my speedo and odo work again. It's too early to tell how long it will last, so I'll update later. First 130mi was good! _________________ 84 Wolfsburg Edition Westy |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
blurat Samba Member
Posted: Mon Oct 16, 2017 5:29 pm Post subject: Re: 11cent odometer fix |
Just exactly what is supposed to keep that axle in place originally?
I have a speedo that the whole axle walks out and it slips below the gear.
The driven gear is tight on the axleshaft. |
vwjetboat Samba Member
Posted: Mon Oct 16, 2017 6:28 pm Post subject: Re: 11cent odometer fix |
blurat wrote: |
https://www.thesamba.com/vw/classifieds/manage.php |
Posted: Mon Oct 16, 2017 6:32 pm Post subject: Re: 11cent odometer fix |
There is an aluminum gear on the opposite side of the shaft. This gear holds everything in place. If this gear is loose on the shaft two things happen, one the odometer gears do not turn, two the shaft slides out.
It is comical of all the fixes on this shaft coming out issue, but none are fixing the real issue.
Peen the shaft at the location of the aluminum gear. Do not go further than that gear because you will cause the number gears to not to slide on the shaft. |
blurat Samba Member
Posted: Tue Oct 17, 2017 8:32 am Post subject: Re: 11cent odometer fix |
Thank you Mr Butcher. |
