WADVR Samba Member
Joined: December 03, 2015 Posts: 108 Location: Carnation, WA
Posted: Tue Mar 14, 2017 12:06 am Post subject: 12 volt engine swap into 6 volt car |
Not that I need any more projects but I am looking to get my '66 on the road while I keep plugging away on the '67. My '66 is missing complete engine and I would like to swap in the engine from my '67(which is not original). What is my best route here? Grind the tranny for the 12v flywheel and convert the car to 12v or what parts should I collect to convert my engine to 6 volt? I would like this car to be a driver, no full rebuild just a car to drive.
No other '67 parts will be swapped over just the non-original engine.
Thanks _________________ - 67 Beetle Full Resto Project
- 66 Beetle “Parts Car” Project |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Tue Mar 14, 2017 12:35 am Post subject: Re: 12 volt engine swap into 6 volt car |
WADVR wrote: |
What is my best route here? Grind the tranny for the 12v flywheel and convert the car to 12v or what parts should I collect to convert my engine to 6 volt? |
Your "best route"?
You will need to decide . . . converting the engine to 6-volt will require a flywheel swap . . . and the obvious 6-volt generator/regulator, and ignition coil.
Is it best to convert the car to 12-volt? you will need to decide if that is best!
Did ya read this yet . . . http://www.thesamba.com/vw/forum/viewtopic.php?t=233946 . . . found in the F.A.Q. section because your question is . . . frequently asked! _________________ Jesucristo es mi Señor y Salvador! |
drs1023 Samba Member
Joined: October 20, 2011 Posts: 1682 Location: Georgia, USA
Posted: Wed Mar 15, 2017 11:57 am Post subject: Re: 12 volt engine swap into 6 volt car |
Grinding a small trans for a 200 mm flywheel isn't all that complicated. I install the flywheel and mate the motor as close as possible to the trans. When the larger flywheel touches, turn the crank nut to score the inside of the small transaxle. I grind with a coarse flap wheel to reduce sparks. |
planenut Samba Member
Posted: Wed Mar 15, 2017 2:44 pm Post subject: Re: 12 volt engine swap into 6 volt car |
If you stay 6V, in addition to the coil, starter, and flywheel, don't forget your electric choke. |
