DSweinhagen Samba Member
Joined: July 30, 2002 Posts: 382 Location: Phoenix, AZ
Posted: Fri Mar 17, 2017 3:02 pm Post subject: 1952 Deluxe |
Hi- I'm starting this thread to document a good friend/client's 1952 Deluxe. The bus was purchased in the early 1990s and I believe came out of the Modesto, California area. I've heard it was a known bus so if anyone has info or pictures, feel free to post.
It was fairly complete and had been a driver with a later bug 36hp but hadn't been on the road for a while. I remember putting a new transmission in it, going through the brakes and putting new tires on it and getting it back on the road. The bus was left that way through the mid to late '90s. Here's a couple picts when we drove it to Jerome, probably around 1998...
Sometime around 2000 there was a decision to restore it. We disassembled it and I had the body media stripped and got started on the bodywork. That ended up being short lived as the owner made a move a couple hours north and shortly after that I moved across town. We decided to put the bus in storage up in Northern Arizona and I'd get back on it once I was settled into my new place... So 15 years or so later, I went back up and got it. I can't seem to find any pics of the work I did on it back then but it wasn't very much. I'll do my best to keep this thread updated. Here's a couple pics back in Phoenix and off the trailer...
_________________ David S |
GTV Samba Member
Posted: Fri Mar 17, 2017 3:47 pm Post subject: Re: 1952 Deluxe |
Wow, Jerome '98 was the first year I attended Looking forward to the progress! _________________ EMPI Power Rules! |
Posted: Fri Mar 17, 2017 5:15 pm Post subject: Re: 1952 Deluxe |
Now it's in the shop, emptied out and deciding where to start. Obviously it's pretty good for a '52, though it does have its share of damage and odd localized rust. In addition to that, some PO went around drilling and poking holes where I guess they thought it needed to drain. It probably helped though many areas they hammered on a screwdriver till it tore through the metal stretching it pretty good in spots.
My plan is to preserve as much metal as possible. With that said the right side is the worst and the plan is to go all the way with this bus, so door fitment will be important. Here are some picts of the quarter panel and cargo doors...
Luckily we were able to source some new sheetmetal a while back.
obus Samba Member
Joined: March 08, 2001 Posts: 11069 Location: just off Garden State Parkway Exit 81
Posted: Fri Mar 17, 2017 6:43 pm Post subject: Re: 1952 Deluxe |
I was reluctant to go immediately to the new sheetmetal... So I took some measurements and messed around with the cargo doors for a little bit but didn't see it coming out well. Both the lower hinges and mounting points on the pillars were wasted, as I know most barn doors are, but I didn't want to end up with a bunch of time into repair and not be really happy with it. So I tried to fit the new doors, but they weren't even close with the damaged pillars and ended up scabbing in the mounting point on the B-pillar to get the door where I wanted it. Now I have the forward cargo door where I want it and am comfortable using it as a base-point to fit the rear up to...
Some more quarter panel damage, and then removed...
I was hoping to salvage the C-pillar, but ended up replacing it with with an Autocraft piece to give me the flexibility I needed to get the rear cargo door fit.
Everything clamped up and doors are finally getting close.
wcfvw69 Samba Purist
Posted: Fri Mar 17, 2017 6:46 pm Post subject: Re: 1952 Deluxe |
Wow.. that bus is going to look great. I'm looking forward to the updates on such a nice Samba. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Fri Mar 17, 2017 6:50 pm Post subject: Re: 1952 Deluxe |
obus wrote: |
Looking forward to watching this one!!
If anyone can do this bus justice it's you! I still get compliments on the work you did on my mango. |
Thanks Paul!! Hope all is well.. _________________ David S |
Posted: Fri Mar 17, 2017 7:25 pm Post subject: Re: 1952 Deluxe |
Repairing the corner, wheel well and battery tray while the quarter panel is off...
Posted: Fri Mar 17, 2017 8:08 pm Post subject: Re: 1952 Deluxe |
Quarter panel is ready to weld on now...
I fabbed a wheel well brace. This bus had one on the right side, but not on the left...
Finished the repair on the B-pillar and more cargo door fitting with hardware installed.
vwhelmot Samba Member
Joined: May 04, 2006 Posts: 617 Location: united kingdom
Posted: Sat Mar 18, 2017 2:51 am Post subject: Re: 1952 Deluxe |
Nice work! |
Brian_1952 Samba Member
Posted: Sat Mar 18, 2017 4:12 am Post subject: Re: 1952 Deluxe |
My dream barndoor _________________ (20-024785)Ambulance (20-037784)truck (20-035850)panel
(20-035778)kombi
WANTED 52 parts and NOS sheet-metal |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Sat Mar 18, 2017 9:12 am Post subject: Re: 1952 Deluxe |
I remember this bus, I have some old pictures of it in a box somewhere. I think they were taken around 2000 _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
squareweave Samba Member
Joined: November 15, 2004 Posts: 448 Location: British Columbia
Posted: Sat Mar 18, 2017 9:27 am Post subject: Re: 1952 Deluxe |
Beautiful work!! I'm looking forward to following this thread. |
VWmeister Samba Member
Posted: Sat Mar 18, 2017 9:29 am Post subject: Re: 1952 Deluxe |
I bought this bus along with a 52 pickup in 1994. In the Barndoor Registry it is the 4th oldest 1952 24G. It was a good driver as witnessed the trek to the Jerome Jamboree.
I had an awesome time at Bad Camberg in 1999 with the Return to the Fatherland tour. I wanted to return in 2003 with a vehicle to hold 4 people and luggage. Hence taking the 52 bus.
Took it apart and 9/11 occurred. Plans changed. We got it media blasted and David replaced the front clip. Then it sat for years storing parts.
Decided about 2 years ago to go ahead but had to wait for David until he picked it up in January. Planning on full restoration so enjoy this thread as it progresses. |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2177 Location: Graz, Austria, Europe
ian macdowall Samba Member
Joined: September 02, 2007 Posts: 114 Location: Devon, England
Posted: Sun Mar 19, 2017 6:21 am Post subject: Re: 1952 Deluxe |
That's a nice early 52 in good shape, great work, looking forward to seeing the progress. _________________ '51 Beetle Deluxe
'52 Barndoor Deluxe |
BulletBus Samba Member
Joined: August 17, 2005 Posts: 1276 Location: Panama City Beach
Posted: Mon Mar 20, 2017 4:28 am Post subject: Re: 1952 Deluxe |
Two NOS cargo doors and an NOS quarter panel? Daaayum. _________________ 53 Hatch Barndoor
If it's not a bus, it's bus money waiting to happen. |
vdouglu Samba Member
Posted: Mon Mar 20, 2017 11:07 pm Post subject: Re: 1952 Deluxe |
Awesome! |
Scotty Samba Member
Joined: July 02, 2003 Posts: 1531 Location: Northampton - Uk
Posted: Tue Mar 21, 2017 6:18 am Post subject: Re: 1952 Deluxe |
Nice work! _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
aa390392 Samba Member
Posted: Tue Mar 21, 2017 10:26 am Post subject: Re: 1952 Deluxe |
You are a craftsmen, very nice work.
Thanks for sharing.
Thomas
Is there a forum on on Returning to the fatherland? Bill Bowman has told me about it, would make a great story of all the stories of the journey. _________________ .
getting grumpy & less tolerant!
55 ragtop
56 delux sedan
56 Kabriolet |
