driftman11 Samba Member
Joined: August 01, 2012 Posts: 141 Location: little rock,ar
Posted: Sat Mar 18, 2017 7:00 pm Post subject: loose Guard bolts cause oil leak? |
ok, I am wondering if the bolts that hold the engine guard that covers the oil pan seal up the engine case? If they are loose, could this cause oil leaking out the case seam on the bottom? Are these essential bolts to tighten the case? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Sat Mar 18, 2017 7:07 pm Post subject: Re: loose Guard bolts cause oil leak? |
They do hold the case together.
Torque them to 14 ft-lbs. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Mar 18, 2017 7:09 pm Post subject: Re: loose Guard bolts cause oil leak? |
ok, do you know if them being loose will cause oil to seep out the seam or out the bolt holes? I'm having a mystery leak and it doesn't ness. look like the oil pump but it is right in the area of where the grille bolts in. |
Glenn Mr. 010
Posted: Sat Mar 18, 2017 7:11 pm Post subject: Re: loose Guard bolts cause oil leak? |
I doubt they are the cause of the leak. _________________ Glenn
Member #1009
#BlueSquare |
c.davis419 Samba Member
Posted: Sat Mar 18, 2017 8:14 pm Post subject: Re: loose Guard bolts cause oil leak? |
It is likely the oil pump cover plate seal that has failed causing the leak. It is a thin paper gasket that some engine builders don't use gasket maker to seal up. _________________ 1967 beetle
1974 Thing |
Posted: Sat Mar 18, 2017 9:04 pm Post subject: Re: loose Guard bolts cause oil leak? |
yea, this was a fresh tear down. the guy who did the work is going to come over and check it out for me. After a brighter light and little closer inspection, I think you are correct about the oil pump seal. it looks to be coming from the bottom of it. Thank you |
Posted: Sun Mar 19, 2017 8:26 am Post subject: Re: loose Guard bolts cause oil leak? |
well, to give an ending to this story, the engine guard grille bolts do, in fact, need to be tightened to seal the engine case on bottom. After i tightened it last night, came back this morning to a dry area and no drip forming on oil pan. yay!!! |
NY thing Samba Member
Joined: March 23, 2010 Posts: 100 Location: Queens New York
Posted: Mon Mar 20, 2017 7:45 pm Post subject: Re: loose Guard bolts cause oil leak? |
glad you fixed it. I like when people post the answer once they figure it out. It will help someone else out down the line |
