loose Guard bolts cause oil leak?
driftman11
driftman11 is offline
PostPosted: Sat Mar 18, 2017 7:00 pm    Post subject: loose Guard bolts cause oil leak? Reply with quote
ok, I am wondering if the bolts that hold the engine guard that covers the oil pan seal up the engine case? If they are loose, could this cause oil leaking out the case seam on the bottom? Are these essential bolts to tighten the case?
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Mar 18, 2017 7:07 pm    Post subject: Re: loose Guard bolts cause oil leak? Reply with quote
They do hold the case together.
Torque them to 14 ft-lbs.
Glenn
Member #1009
#BlueSquare
driftman11
PostPosted: Sat Mar 18, 2017 7:09 pm    Post subject: Re: loose Guard bolts cause oil leak? Reply with quote
ok, do you know if them being loose will cause oil to seep out the seam or out the bolt holes? I'm having a mystery leak and it doesn't ness. look like the oil pump but it is right in the area of where the grille bolts in.
Mr. 010
Glenn is offline
PostPosted: Sat Mar 18, 2017 7:11 pm    Post subject: Re: loose Guard bolts cause oil leak? Reply with quote
I doubt they are the cause of the leak.
Glenn
Member #1009
#BlueSquare
c.davis419
c.davis419 is offline
PostPosted: Sat Mar 18, 2017 8:14 pm    Post subject: Re: loose Guard bolts cause oil leak? Reply with quote
It is likely the oil pump cover plate seal that has failed causing the leak. It is a thin paper gasket that some engine builders don't use gasket maker to seal up.
1967 beetle
1974 Thing
driftman11
PostPosted: Sat Mar 18, 2017 9:04 pm    Post subject: Re: loose Guard bolts cause oil leak? Reply with quote
yea, this was a fresh tear down. the guy who did the work is going to come over and check it out for me. After a brighter light and little closer inspection, I think you are correct about the oil pump seal. it looks to be coming from the bottom of it. Thank you
driftman11
PostPosted: Sun Mar 19, 2017 8:26 am    Post subject: Re: loose Guard bolts cause oil leak? Reply with quote
well, to give an ending to this story, the engine guard grille bolts do, in fact, need to be tightened to seal the engine case on bottom. After i tightened it last night, came back this morning to a dry area and no drip forming on oil pan. yay!!!
NY thing
NY thing is offline
PostPosted: Mon Mar 20, 2017 7:45 pm    Post subject: Re: loose Guard bolts cause oil leak? Reply with quote
glad you fixed it. I like when people post the answer once they figure it out. It will help someone else out down the line
