Wiring OCD.... where should they go?
johanmarais
johanmarais is offline
PostPosted: Mon Mar 20, 2017 12:51 pm    Post subject: Wiring OCD.... where should they go? Reply with quote
So I might have a little OCD when it comes to wiring.
So far I've noticed that there's two connection in the engine bay that should be connected somewhere, and my question is.....where?
Hopefully someone can share some light on this.
This first image is of a white wire and a black with yellow wire.
This second image is of two gray wires
1990 Vanagon 2.1i (South Africa Caravelle)
Wildthings
Wildthings is offline
PostPosted: Mon Mar 20, 2017 12:57 pm    Post subject: Re: Wiring OCD.... where should they go? Reply with quote
Not answering your question, but the red wire to your alternator looks really bad, you can buy an improved replacement alternator harness from GoWesty and others.
I also don't like the looks of the braided hose running up to your cooling vent ring. It looks original and on the verge of failure.
johanmarais
PostPosted: Mon Mar 20, 2017 1:01 pm    Post subject: Re: Wiring OCD.... where should they go? Reply with quote
Yes, that is correct.
I just got the Bus 2 weeks ago and I'm in the process of sorting and replacing everything.
djkeev
djkeev is offline
PostPosted: Mon Mar 20, 2017 3:02 pm    Post subject: Re: Wiring OCD.... where should they go? Reply with quote
There is nothing OCD about wanting an engine area properly and safely wired!! You're just smart!
Here is my 86 before I began work......
Dave
Ghia
Vanagon
Beetle
Wildthings
PostPosted: Mon Mar 20, 2017 4:03 pm    Post subject: Re: Wiring OCD.... where should they go? Reply with quote
djkeev wrote:
Dave
Those could be the one set of wires the OP asked about. Would the others be the wires to the oil pressure switches? Don't have any source to check for colors.
Robw_z
Robw_z is offline
PostPosted: Mon Mar 20, 2017 9:36 pm    Post subject: Re: Wiring OCD.... where should they go? Reply with quote
johanmarais wrote:
On my van, the yellow and white wires go to the idle stabilizer valve.
johanmarais wrote:
The sheathing on these wires matches the sheathing that goes to a diagnostic port on the alternator(on my van), which is redundant for most people, unless you have the VW special tool to read the output from the crank sensor.
I am only 90% on both these answers.
-Rob
