chachi Samba Member
Joined: November 18, 2003 Posts: 858 Location: the weeds
Posted: Sun Mar 19, 2017 10:10 am Post subject: putting the bus back together, some inital head questions |
refreshing this CA case motor i got a few years ago, running with decent compression. ran it with a progressive for awhile till the progressive stuck open, so i got my original PDSITs rebuilt and am now mounting those, giving it new seals and running it. tearing into it, i noticed a couple things. one of the heads has some some marks, probably where somebody pried the manifold off with a screwdriver. how bad are these? luckily they're at the outside edges.
also, i was delighted to find what i can only assume is a head temp sensor port drilled on the 1-2 side. or is that not what this is...?
also, i have tried to find some source for manifold to head gaskets for awhile, and i think i even posted here asking about them but never found any. am i just going to have to cut them out of gasket stock? _________________ '74 transporter panel
'91 vanagon carat NAHT |
foxmon Samba Member
Joined: September 20, 2012 Posts: 126 Location: Maine
Posted: Sun Mar 19, 2017 5:56 pm Post subject: Re: putting the bus back together, some inital head questions |
chachi wrote: |
For FI Temperature Sensor II on the 3-4 side _________________ '78 CEII Deluxe Westy Auto 2.0 FI Hydro now w/'79 heads
Bus driver since 1975 |
timvw7476 Samba Member
Posted: Sun Mar 19, 2017 7:14 pm Post subject: Re: putting the bus back together, some inital head questions |
those are EGR ports, they get blocked with crimped old exhaust gas port stems, or threaded valve adjust screws.
The gaskets for the intake, the best would probably be from CB Performance.
The true temp sender for FI threads off to the side of #3 cylinder, and you can see the threads from the outside. |
Posted: Sun Mar 19, 2017 9:53 pm Post subject: Re: putting the bus back together, some inital head questions |
This is the early TSII sensor location, if you use it you should probably add the extension that moves the sensor further from the head. It is also a PITA to access the TSII sensor in this position and you need the correct hole in the tin and the grommet for the hole. I would not recommend using it for those reasons.
This drilling would be for the later TSII location. The same location was used for the air injection on 73-74 models, in that case the hole would be deep and go through into the exhaust port. The easiest location to service the TSII sensor is on the #4 cylinder. You can see what you are doing and reach it much more easily than when using the hole next to the #3 cylinder.
Are these 1800cc AMC heads?
Your dings are of no consequence but maybe run a flat file over them to be sure nothing is sticking up above the mating surface.
chachi Samba Member
Posted: Mon Mar 20, 2017 7:26 am Post subject: Re: putting the bus back together, some inital head questions |
thanks for the info on the TSII port. i haven't verified whether these are AMC heads yet but it does have an 1800 fan shroud. i probably have the tin to use this location (i have a mountain of tin) but access is a valid concern.
bad news last night. got the oil cleaned off the top to find this. guess that's what that "G" stamped next to the engine code is all about and i'll be building another motor sooner rather than later.
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Mon Mar 20, 2017 7:54 am Post subject: Re: putting the bus back together, some inital head questions |
I've got one of those-- it's in blue bus right now almost brand new- If I'd known, I'd never have bought the bus- but now - after changing out the lifters- (ya they failed before the motor got dirt on it) and the cali hacked exhaust, It's starting to run better.- I'm still going for a replacement on a pallet ready to ship before any extended trip- Any one had success with GEX??? _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
chachi Samba Member
Posted: Mon Mar 20, 2017 10:09 am Post subject: Re: putting the bus back together, some inital head questions |
yeah, i'll get whatever i can out of it. i'm not proud. _________________ '74 transporter panel
Posted: Mon Mar 20, 2017 1:25 pm Post subject: Re: putting the bus back together, some inital head questions |
chachi wrote: |
yeah, i'll get whatever i can out of it. i'm not proud. |
X2- For the $ I paid for it- it's gotta run 30,000 or I'm going to feel real bad.
Any way with new exhaust and lifters it actually sound like some one else built it--even with the miss matched push rods. _________________ some days I get up and just sit and think. Some days I just sit.
