Lightening stock flywheel
Dürtwagen
Dürtwagen is offline
PostPosted: Mon Mar 20, 2017 9:21 pm    Post subject: Lightening stock flywheel Reply with quote
Topic says it all. Im very confident in my local auto machine shop to do a job like this, but has anyone done this apposed to buying an aftermarket one? Can this be done? I'm really only looking to go through the trouble if its a noticeable upgrade. It's a 1600 dual port with a weber 40 which makes it a little peppy I guess. Would lightening the flywheel give me that launch I'm looking for? Surprised I just put a new clutch in and got me thinking. Thanks
1974 VW baja bug
1972 VW beetle
1982 BMW 320i
Multi69s
Multi69s is offline
PostPosted: Tue Mar 21, 2017 12:49 am    Post subject: Re: Lightening stock flywheel Reply with quote
I throw mine on the lathe and lighten them myself. All you need is a four jaw chuck, dial indicator and patience. However, they MUST be balanced after they are lightened. Will you see any power difference, nope. You didn't mention the car, but I have a general rule of thumb, the lighter the car, the lighter the flywheel. So if this engine is in a Baja with a stock trans, leave it. However if it is a light rail at the dunes, go for it.
69 road Bug 2110
69 Baja Bug 2010 - 5 Rib Bus Transaxle
73 Squareback - 2L, T4, Automatic
Plus more toys then I have time for
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
Dürtwagen
PostPosted: Tue Mar 21, 2017 7:11 am    Post subject: Re: Lightening stock flywheel Reply with quote
It is in a baja with a stock trans so I'll take your word for it and just leave it .
I read about the piston kits to convert to a 1641 or something close to that which required NO machine work to the heads, and I think there was a 1681? Kit that required a little work to the heads. Now are these worth it? Noticeable power increase large or small or any?
Thanks
1974 VW baja bug
1972 VW beetle
1982 BMW 320i
mkparker
mkparker is offline
PostPosted: Tue Mar 21, 2017 8:32 am    Post subject: Re: Lightening stock flywheel Reply with quote
All the engine info is right here:
http://www.aircooled.net/vw-performance-engines/
Michael
Driver 1061/1062 TDRA and BITD
Dürtwagen
PostPosted: Tue Mar 21, 2017 11:53 am    Post subject: Re: Lightening stock flywheel Reply with quote
Very informative read, thank you
1974 VW baja bug
1972 VW beetle
1982 BMW 320i
Multi69s
Multi69s is offline
PostPosted: Tue Mar 21, 2017 12:16 pm    Post subject: Re: Lightening stock flywheel Reply with quote
This article is also a good read.
http://www.aircooled.net/vw-performance-easy-mods-bolt-on/
69 road Bug 2110
My builds
Dürtwagen
PostPosted: Tue Mar 21, 2017 1:22 pm    Post subject: Re: Lightening stock flywheel Reply with quote
I'm definitely going to look into to those 1.4:1 rockers
1974 VW baja bug
1972 VW beetle
1982 BMW 320i
