Lightening stock flywheel
Dürtwagen
Dürtwagen is offline
PostPosted: Mon Mar 20, 2017 9:21 pm    Post subject: Lightening stock flywheel Reply with quote
Topic says it all. Im very confident in my local auto machine shop to do a job like this, but has anyone done this apposed to buying an aftermarket one? Can this be done? I'm really only looking to go through the trouble if its a noticeable upgrade. It's a 1600 dual port with a weber 40 which makes it a little peppy I guess. Would lightening the flywheel give me that launch I'm looking for? Surprised I just put a new clutch in and got me thinking. Thanks
1974 VW baja bug
1979 Mercedes Benz 300D
Multi69s
Multi69s is offline
PostPosted: Tue Mar 21, 2017 12:49 am    Post subject: Re: Lightening stock flywheel Reply with quote
I throw mine on the lathe and lighten them myself. All you need is a four jaw chuck, dial indicator and patience. However, they MUST be balanced after they are lightened. Will you see any power difference, nope. You didn't mention the car, but I have a general rule of thumb, the lighter the car, the lighter the flywheel. So if this engine is in a Baja with a stock trans, leave it. However if it is a light rail at the dunes, go for it.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
Dürtwagen
PostPosted: Tue Mar 21, 2017 7:11 am    Post subject: Re: Lightening stock flywheel Reply with quote
It is in a baja with a stock trans so I'll take your word for it and just leave it .
I read about the piston kits to convert to a 1641 or something close to that which required NO machine work to the heads, and I think there was a 1681? Kit that required a little work to the heads. Now are these worth it? Noticeable power increase large or small or any?
Thanks
1974 VW baja bug
mkparker
mkparker is offline
PostPosted: Tue Mar 21, 2017 8:32 am    Post subject: Re: Lightening stock flywheel Reply with quote
All the engine info is right here:
http://www.aircooled.net/vw-performance-engines/
Michael
Pit Boy 6163 Spec Trophy Truck
Dürtwagen
PostPosted: Tue Mar 21, 2017 11:53 am    Post subject: Re: Lightening stock flywheel Reply with quote
Very informative read, thank you
1974 VW baja bug
Multi69s
Multi69s is offline
PostPosted: Tue Mar 21, 2017 12:16 pm    Post subject: Re: Lightening stock flywheel Reply with quote
This article is also a good read.
http://www.aircooled.net/vw-performance-easy-mods-bolt-on/
69 road Bug 2110
My builds
Dürtwagen
PostPosted: Tue Mar 21, 2017 1:22 pm    Post subject: Re: Lightening stock flywheel Reply with quote
I'm definitely going to look into to those 1.4:1 rockers
1974 VW baja bug
