Dürtwagen Samba Member
Joined: May 13, 2016 Posts: 271 Location: Cottonwood, Arizona
Posted: Mon Mar 20, 2017 9:21 pm Post subject: Lightening stock flywheel |
Topic says it all. Im very confident in my local auto machine shop to do a job like this, but has anyone done this apposed to buying an aftermarket one? Can this be done? I'm really only looking to go through the trouble if its a noticeable upgrade. It's a 1600 dual port with a weber 40 which makes it a little peppy I guess. Would lightening the flywheel give me that launch I'm looking for? I just put a new clutch in and got me thinking. Thanks _________________ 1974 VW baja bug
1979 Mercedes Benz 300D |
Multi69s Samba Member
Joined: January 24, 2006 Posts: 5364 Location: Lefty, CA
Posted: Tue Mar 21, 2017 12:49 am Post subject: Re: Lightening stock flywheel |
I throw mine on the lathe and lighten them myself. All you need is a four jaw chuck, dial indicator and patience. However, they MUST be balanced after they are lightened. Will you see any power difference, nope. You didn't mention the car, but I have a general rule of thumb, the lighter the car, the lighter the flywheel. So if this engine is in a Baja with a stock trans, leave it. However if it is a light rail at the dunes, go for it. _________________ 69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight= |
Posted: Tue Mar 21, 2017 7:11 am Post subject: Re: Lightening stock flywheel |
It is in a baja with a stock trans so I'll take your word for it and just leave it .
I read about the piston kits to convert to a 1641 or something close to that which required NO machine work to the heads, and I think there was a 1681? Kit that required a little work to the heads. Now are these worth it? Noticeable power increase large or small or any?
mkparker Samba Member
Joined: October 12, 2004 Posts: 332 Location: Sherman, Tx
Posted: Tue Mar 21, 2017 11:53 am Post subject: Re: Lightening stock flywheel |
Very informative read, thank you _________________ 1974 VW baja bug
Posted: Tue Mar 21, 2017 1:22 pm Post subject: Re: Lightening stock flywheel |
I'm definitely going to look into to those 1.4:1 rockers _________________ 1974 VW baja bug
