SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
riverside66 Samba Member
Joined: June 04, 2008 Posts: 218 Location: Sparta, NC
Posted: Tue Mar 21, 2017 12:59 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
SamboSamba22 wrote: |
Riverside66,
That is a HUGE improvement from the offered/available replacement. |
You know what....now that you mention it, I do remember ordering another one that was worse than this. It was all shabby looking and malformed. I think I just threw it out it was so bad!
For what it's worth, you might want to give these guys a shot:
https://www.customandcommercial.com/vw-baywindow/b...74-79_838/
I know...it's a crap-shoot, buuut I did just order their steering coupler a few weeks ago, and can vouch for it. It's much better than the other couplers you find out there. _________________ 1977 Standard Beetle -Sold-
1979 Transporter - "Wheatbread" -Sold- |
Posted: Sat Apr 01, 2017 7:17 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
So I've discovered a bubbling or hissing sound of what seems to be hot gases in the passenger side air intake, or better yet with the rear deck lid popped open, I can hear vividly a hot "steamy" gas sound coming from either the battery tray or the tubing of the evap system.
Is there a hose connecting the hard lines of the evaporative system on the passenger side?
If it is indeed the battery (scary) what would cause the water to get hot within the battery, a bad battery, a bad voltage regulator?
I do have a video clip, I'll share later today when I get a chance to post it.
Thanks guys, _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
Wasted youth Samba Member
Joined: July 06, 2012 Posts: 5134 Location: California's Hot and Smoggy Central Valley
Posted: Sat Apr 01, 2017 8:31 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Does the battery have a warm or hot feel? Is the battery fluid level over the tops of the cells? Hard to see without an inspection mirror and flashlight, or pull the battery for service and inspection.
I was pleasantly surprised the the Harbor Freight battery load tester actually works pretty well. |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Sat Apr 01, 2017 8:45 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
then release the gas cap- it may be leaking pressure- you should be able to tell right away- _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51146 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Apr 01, 2017 9:17 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Does this sound occur all the time?, just after a drive?, in the morning?, after sitting for days? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Apr 01, 2017 11:00 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
How clean are your heat exchangers? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Apr 01, 2017 2:13 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Long shot, weird thought...
Did you replace all the rubber gas tank vapor lines? There are two metal tubes up in the air intake plenums, one each side. Could there be trapped gasoline in there somehow? Kinda screwy idea, I guess.
As previously posted, did you see if when removing the gas cap you hear a pressure/ vacuum? |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
Posted: Sun Apr 02, 2017 6:19 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Well cruised a good ways today, got back to the house, hopped out and walked to the rear, hissing and gas pressure sounds again. Popped fuel cap off and.....nothing. Left it off thinking maybe it'd take a minute or two, but nothing changed, sounds continued.
Battery doesn't feel hot or smell.
Perhaps some corrosion in the Evap systems' hard lines? There isn't a hose connection on the passenger side, so I'm curious what's the verdict. _________________ The Bus Barn Ltd. Co.
Posted: Wed Apr 05, 2017 6:45 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
lil-jinx wrote: |
You're hearing this sound with the engine off,how long does it continue,could it be your fuel pressure regulator. |
When engine is off, I haven't walked around while the bus is running to see if it does it then as well.
Can't be a regulator, I have the mechanical pump. Seems like gas pressure leaking out of something.
Continues until the motor cools down a bit, as far as I can tell, haven't sat there and read a book or anything, but it lasts a while _________________ The Bus Barn Ltd. Co.
Posted: Wed Apr 05, 2017 11:03 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
lil-jinx wrote: |
Just throwing darts,maybe engine vent,try removing oil cap. |
I'm grateful for you doing so, a couple knuckleheads are better than one, at least it goes something like that
I've tried the oil cap as well.
Right now, I'm solely believing it to be corrosion in the evap lines or hoses not being tight enough, and with hot pressured gases they are expanding the hoses and escaping. Criminal gases, shall not be contained!
Here's the video I promised and forgot about:
https://youtu.be/NXMVR7knfAo
Ideas gents? _________________ The Bus Barn Ltd. Co.
Posted: Fri Apr 07, 2017 6:41 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
And not a penny less! Bus is lookin good man! _________________ 1977 Standard Beetle -Sold-
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Fri Apr 07, 2017 7:14 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Your bus has gone thru an amazing transformation in the relatively short time you've had it. It will be interesting to hear what the insurance value is versus the price you paid for it. _________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
