Love My Westy Samba Member
Posted: Mon May 03, 2010 10:30 am Post subject: GoWesty Poptop Lift Assist Kit |
This question is for those of you who have the GoWesty Poptop Lift Assist Kit installed on your Westy. If you have the kit installed in the forward position for more lift, how difficult is it to lower the top if you do not have extra weight on top? I often carry a canoe that weighs about 75 lbs, but not always. GoWesty sells extra brackets that can be mounted in the standard position and they told me I should move the struts between the two depending on the load. That seems like a big hassle (and expense) to me if I can make do just using the struts in the forward position.
Rich |
Westy-Life Samba Member
Joined: June 24, 2008 Posts: 178 Location: The Road or Calgary AB
BushChicken Samba Member
Joined: March 11, 2010 Posts: 250 Location: California
Posted: Mon May 03, 2010 3:03 pm Post subject: |
I don't think many here are going to have the GoWesty kit (at least not yet).
You could call them and ask. Make sure you report back with your answer. |
wallanoise Samba Member
Joined: October 01, 2008 Posts: 96 Location: Crumsville
Posted: Mon May 03, 2010 3:48 pm Post subject: |
I think it's great that folks throw the "check this guys out" advise but why stray from the original inquiry. I would really like feed back on the GoWesty kit. I know that the other works well but why not explore other options. I to haul around a bunch of gear and would like to consider my options. |
madspaniard Samba Member
Zero419 Samba Member
Posted: Mon May 03, 2010 5:16 pm Post subject: |
+1 _________________ 1987 Westy Auto Bostig 2.0 Ztec |
Posted: Mon May 03, 2010 9:22 pm Post subject: |
Thanks to all of you. Great information! That's what's so great about Samba. I really wasn't anxious to drill all those holes in my sheetmetal, and maybe have to buy 2 of the GoWesty kits for at least $129.95 each(they are on sale right now, reg. price is $149.95) plus the tool for mounting, plus shipping.
I like the design of Jackbombay's kit and think I'll go with it, ordering both the regular and the heavy duty struts. I have faith that the fiberglass is strong enough seeing how many years I've been hauling all kinds of canoes and kayaks on it. Maybe that bolt sticking out can be reversed so that only the head is showing and painted to match the top.
Rich |
Jon_slider Samba Member
Posted: Mon May 03, 2010 11:03 pm Post subject: |
if you have not already drilled for racks, here is a pop top shock mounted to share the mounting hole for the rack gutter
I have racks on 2 westies, neither has any problems with the hole cracking the fiberglass, I think thats an academic consideration, not real world.. besides, theres a steel plate on both sides of the fiberglass, spreading the load, its not just a rack resting on a bolt hole.. just do it, racks rock when youve got pop top shocks <g> |
jonsonneborn Samba Member
Joined: January 01, 2015 Posts: 51 Location: San Rafael, Ca
Posted: Tue Mar 21, 2017 9:24 am Post subject: |
Jon_slider wrote: |
<g> |
Hey Jon_Slider, Do you have more info on this mounting point on the back of the artificial raingutter mount? I am installing the GW lift assist kit now & have 3 sets of the Thule artificial raingutters on my top now. I'd love to not have to drill additional holes in the top if there is a good solition to tie into the back of the thule plate. Thx! _________________ Luna is a 1989 Vangaon Blue Star Edition with a 2.2L Subaru/Kennedy Conversion. I have grafted a donor Westfalia roof on & now she is a Westy! |
dsdunbar Samba Member
Joined: December 19, 2014 Posts: 564 Location: Crozet VA
Posted: Tue Mar 21, 2017 10:44 am Post subject: |
I cant speak for the GW kit or Jon_Slider, but from my experience installing the JB lift kit and Yakima widebody artificial rain gutters...
Jon Sliders picture doesnt give me enough information to tell if forward of the van is to the left or to the right in the picture. I would ASSUME the van is forward to the LEFT, meaning the reuse of that stainless bolt (looks like a 2 bolt ARG) is the aft most bolt of the ARG. The advantage to this is that the forward bolts wont interfere with the shock when top is lowered.
My experience w/ my rack set up, is minimize how many bolts will fall within the arc of the strut. Each bolt that falls WITHIN the arc of the strut is at risk of coming in contact w/ the strut and binding.
to get a better idea of what i am describing look at the second to last post on page 3 of this topic (PDXWesty), it shows a taped up mock up:
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=40
from PDX's post you can see the location of all the bolts will pass by the strut when lowered, meaning potential for impact. Now if the ARG was installed such that the back left bottom bolt shared the same as the strut then all the bolts would miss the shock. Make sense?
Hope that helps.
jonsonneborn wrote: |
Jon_slider wrote: |
<g> |
Hey Jon_Slider, Do you have more info on this mounting point on the back of the artificial raingutter mount? I am installing the GW lift assist kit now & have 3 sets of the Thule artificial raingutters on my top now. I'd love to not have to drill additional holes in the top if there is a good solition to tie into the back of the thule plate. Thx! |
_________________ '89 2WD Westy "Grey Goose" - Manual 4spd
Crozet VA
Vanaru EJ25, Peloquin |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16506 Location: Brookeville, MD
Posted: Tue Mar 21, 2017 1:04 pm Post subject: |
Jon_slider wrote: |
<g> |
Since your raingutters are already installed you'd have to win the lottery for the existing bolt hole to be exactly where it needs to be to install the shock. Those that arrange this install the raingutter at the same time as the shock system AFAIK. But maybe you'll get lucky. _________________ Dave O
The Western Syncro build
Posted: Tue Mar 21, 2017 1:09 pm Post subject: |
[quote=]Since your raingutters are already installed you'd have to win the lottery for the existing bolt hole to be exactly where it needs to be to install the shock. Those that arrange this install the raingutter at the same time as the shock system AFAIK. But maybe you'll get lucky.[/quote]
That’s a good point. Ido imagine there is a tiny bit of wiggle roof for the upper ball location. If it doesn't match the hole location but falls somewhere along the backing plate for the artificial rain gutter than my though is to drill a hole in thr backing plate & tap it to screw in a ball. This seems even better because it'd be distributing the pressure along the entire clamped piece vs. Just on the hole (maybe)? _________________ Luna is a 1989 Vangaon Blue Star Edition with a 2.2L Subaru/Kennedy Conversion. I have grafted a donor Westfalia roof on & now she is a Westy! |
danfromsyr Samba Member
Posted: Tue Mar 21, 2017 1:15 pm Post subject: Re: GoWesty Poptop Lift Assist Kit |
there are literally hundreds (if not more) of poptop assist struts w/o any backing other than the large washer provided.
it's really a non-issue...
though sure a little thought is nice when drilling holes into a top.. _________________
Abscate wrote: |
Posted: Tue Mar 21, 2017 1:15 pm Post subject: |
[quote=]Since your raingutters are already installed you'd have to win the lottery for the existing bolt hole to be exactly where it needs to be to install the shock. Those that arrange this install the raingutter at the same time as the shock system AFAIK. But maybe you'll get lucky. |
That’s a good point. Ido imagine there is a tiny bit of wiggle roof for the upper ball location. If it doesn't match the hole location but falls somewhere along the backing plate for the artificial rain gutter than my though is to drill a hole in thr backing plate & tap it to screw in a ball. This seems even better because it'd be distributing the pressure along the entire clamped piece vs. Just on the hole (maybe)?[/quote]
I don't know if the backing plate or the ball stud would hold up well to having the ball stud just screwed only the depth of the backing plate. I could see it bending out. If it were mine I'd drill all the way thru the pop top. BTDT.... _________________ Dave O
Posted: Tue Mar 21, 2017 1:53 pm Post subject: |
D'oh, reading comprehension fail....I missed that the ARG's were already installed...ignore my post
dobryan wrote: |
Crozet VA
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Tue Mar 21, 2017 3:38 pm Post subject: |
dsdunbar wrote: |
Jon Sliders picture doesnt give me enough information to tell if forward of the van is to the left or to the right in the picture. I would ASSUME the van is forward to the LEFT, meaning the reuse of that stainless bolt (looks like a 2 bolt ARG) is the aft most bolt of the ARG. The advantage to this is that the forward bolts wont interfere with the shock when top is lowered. |
Ideally the ARG's should be mounted further back than forward, the further back they are the shorter the distance the additional weight on the roof will need to be raised when popping the top, and with the racks further back the amount of energy needed to pop the top will vary less when the racks are loaded vs unloaded.
Cutting the bolts can be difficult depending on what tools are available, but cutting the ARG bolts so they don't protrude past the nut inside the pop top has always, as far as I know, eliminated interference between the strut and the bolts.
With the ever increasing roof loads that wesites are carrying nowadays keeping the weight farther back is important, I have a link in my sig for DIY ARG's that use the rear hinge mounting hardware to mount to which gets weight as far back as possible and minimizes the need for additional holes in the pop top. _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
Andymon Samba Member
Joined: February 24, 2015 Posts: 314 Location: Medford, OR
Posted: Wed Mar 22, 2017 9:02 am Post subject: Re: GoWesty Poptop Lift Assist Kit |
Love My Westy wrote: |
Rich |
Rich, I have that kit and am quite satisfied with it. We have a Yakima rocket box on top along with a kayak now and then. When the box is full I have to give the top a little extra push but not much and when lowering, not a problem.
Andy _________________ "Blanch" '85 Westy
"Too many freaks and not enough circuses". |
Viva.Sabata Samba Member
Posted: Sat Dec 26, 2020 11:40 pm Post subject: Re: GoWesty Poptop Lift Assist Kit |
Does anyone know an alternate source for the GoWesty lift assist struts? They are currently sold out. One of mine is dead (no resistance to compression) and they are sold out. The part number is GSEL-1022-2050-090 and is 44.5 inches ball center to ball center fully extended. I’ve tried some of the online gas strut retailers and they sell 44 inch struts, not 44.5. Not interested in drilling more holes in my van!
Cheers _________________ Sabata
1987 Westy Full Camper, Peloquin 5-Speed 2wd |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
deadaheadub Samba Member
Joined: April 18, 2004 Posts: 787 Location: New Mexico
Posted: Sun Dec 27, 2020 8:30 am Post subject: Re: GoWesty Poptop Lift Assist Kit |
Viva.Sabata wrote: |
Cheers |
You mean, like this? https://www.busdepot.com/pts1
Or here? https://www.vancafe.com/Vanagon-Poptop-s/2885.htm
https://poptopshocks.blogspot.com/ _________________ Grateful daily,
Ryan
______________________________________
Past loves: '65 Bug, '70 Westy poptop, '64 Squareback project, '76 Westy tintop "Loose Lucy", '76 Westy tintop "Sharee"
Current:'84 Westy poptop "Ramblin' Rose- Rosie" w/ 2003 Subaru EJ25 conversion |
