VJU 4 BR 8 distributor advance curve?
Komissar
Komissar is offline
PostPosted: Thu Mar 16, 2017 4:12 pm    Post subject: VJU 4 BR 8 distributor advance curve? Reply with quote
Hello,
Does anyone have the specs (advance curve plot) for the mechanical and vacuum advance of the Bosch VJU 4 BR 8 distributor? (Stndard distributor for oval-era engines)
Thanks in advance.
1965 Sunroof Beetle
1972 Type 3 Squareback
1978 Skoda 105S
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Mar 16, 2017 4:24 pm    Post subject: Re: VJU 4 BR 8 distributor advance curve? Reply with quote
Yes, I'll post it later when I get home.
Glenn
iRide4Sue.org Please Donate to fight Cancer. $31,000 raised in 2018, hoping for the same in 2018
Komissar
Komissar is offline
PostPosted: Thu Mar 16, 2017 4:25 pm    Post subject: Re: VJU 4 BR 8 distributor advance curve? Reply with quote
Thanks. I appreciate this a lot.
1965 Sunroof Beetle
1978 Skoda 105S
Mr. 010
Glenn is offline
PostPosted: Thu Mar 16, 2017 4:29 pm    Post subject: Re: VJU 4 BR 8 distributor advance curve? Reply with quote
This was in the gallery, I should have one with both mechanical and vacuum at home.
Glenn
Komissar
Komissar is offline
PostPosted: Fri Mar 17, 2017 1:44 am    Post subject: Re: VJU 4 BR 8 distributor advance curve? Reply with quote
Thanks.
I would be interested to know the degrees of advance for the vacuum unit as well, and if possible the value of the vacuum depression itself.
1965 Sunroof Beetle
1978 Skoda 105S
Lingwendil
Location: Oakley, behind enemy lines in communist California
Lingwendil is offline
PostPosted: Fri Mar 17, 2017 3:54 pm    Post subject: Re: VJU 4 BR 8 distributor advance curve? Reply with quote
Tagging along, I just cleaned one of these up (0 231 115 040, actually, but who's keeping track Rolling Eyes ) and was curious what it should be at. Other than dirt and external rust, it looks NOS inside and is nice and tight.
73 super beetle thread!
http://www.thesamba.com/vw/forum/viewtopic.php?t=649622
How to- Modify your Kadrons for SVDA!
http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Fri Mar 17, 2017 8:01 pm    Post subject: Re: VJU 4 BR 8 distributor advance curve? Reply with quote
Komissar wrote:
I would be interested to know the degrees of advance for the vacuum unit as well, .
in my own little "gallery" here's the vacuum and centrifugal:
Andy T.
-Volunteer Post-Production Sound Editor for Starship Excelsior - A Star Trek Fan Production.
tasb Premium Member
The Distributor Distributor
tasb is offline
PostPosted: Sun Mar 19, 2017 7:33 am    Post subject: Re: VJU 4 BR 8 distributor advance curve? Reply with quote
The vacuum canister delivers between 8 and 12 degrees of advance.
Roads Scholar & distributor restorations
1956 oval third owner 36 hp- slow drag Champion 2012, 2014, 2015, 2017
1957 Kombi low mileage 36 hp governor equiped M 178 Slow Drag Winner 2014, 2015, 2018
1960 sunroof beetle owned since 1991 36 hp
1965 hrdtop Deluxe Microbus owned since 1990 M 620 factory 12 v 1500cc
Frederik
Frederik is offline
PostPosted: Tue Mar 21, 2017 1:55 pm    Post subject: Re: VJU 4 BR 8 distributor advance curve? Reply with quote
There is a small difference early and late vju4br8, this is early (before mars 1956/ date code 3M).
EVfun
EVfun is offline
PostPosted: Sun Mar 26, 2017 12:08 pm    Post subject: Re: VJU 4 BR 8 distributor advance curve? Reply with quote
Here is some numbers from "Notes on the Practical Work" #13 a Volkswagenwerk Service School publication posted here on theSamba.
These motors don't run much advance as it looks like the later 36 horse distributor only has 14-20 degrees of centrifugal advance all in up around 3200-3600 rpm. The vacuum advance is 7 to 13 degrees. Total advance under load would then only be 21.5 to 27.5 degrees and max total advance only 28.5 to 40.5 degrees (wow, quite a range.)
Wildthings wrote:
