boomtown Samba Member
Joined: July 05, 2008 Posts: 68 Location: Daytona Beach
Posted: Sun Mar 26, 2017 12:50 pm Post subject: Oil pump gasket |
i have a gasket set with two or three different thickness gaskets for the oil pump.
What is the correct thickness for oil pump?
What would happen if I use the wrong thickness?
If I had to make a new gasket what material should be used?
Thanks in advance
David _________________ When the children get older and want to know where the money went, show them your vacation videos. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 22681 Location: Olympia Wash Rinse & Repeat
Posted: Sun Mar 26, 2017 1:26 pm Post subject: Re: Oil pump gasket |
Thicker gasket goes between the pump body and engine case.
Thinnest (about .003") between pump body and cover.
In a pinch can make the second out of thin yellow pages paper or paper gasket material from your FLAPS. _________________ In Stereo, Where Available! |
Posted: Mon Mar 27, 2017 6:42 am Post subject: Re: Oil pump gasket |
Eric&Barb wrote: |
In a pinch can make the second out of thin yellow pages paper or paper gasket material from your FLAPS. |
Thank you for the reply. Not sure what FLAPS is an abbreviation for but I have some old yellow pages. I've read that Gasgacinch should be applied to the gasket and the mating surface also. This info was on Youtube posted by VWdarrin and EZGZ. would you share your experience?
Posted: Mon Mar 27, 2017 7:33 am Post subject: Re: Oil pump gasket |
As long as both sealing surfaces are flat, you should not need any sealant. Using some sandpaper laid sand face up on a piece of flat glass is a good way to insure the surfaces are flat.
There is a "Dictionary" you can access by hovering your mouse cursor over the "Technical" button at the upper right of this web page, and left click on the "Dictionary" that pops up in a list. Left click on the "F" section at the top of that page and scroll down to "FLAPS". _________________ In Stereo, Where Available! |
mandraks Samba Member
Joined: November 28, 2004 Posts: 6016 Location: Lawrenceville, Ga
Posted: Mon Mar 27, 2017 9:36 am Post subject: Re: Oil pump gasket |
it is ensure, not insure  _________________ regards
Uli
PeteSC Samba Member
Posted: Mon Mar 27, 2017 10:10 am Post subject: Re: Oil pump gasket |
FLAPS - Friendly Local Auto Parts Store.
As for sealant; I usually use a thin bit of Permatex gasket sealer. I've never found it to hurt anything and like that there's something to help hold the gasket in place while the parts go back together. |
Posted: Mon Mar 27, 2017 10:34 am Post subject: Re: Oil pump gasket |
mandraks wrote: |
it is ensure, not insure  |
Thanks!  _________________ In Stereo, Where Available! |
Posted: Mon Mar 27, 2017 10:57 am Post subject: Re: Oil pump gasket |
Sounds good and thanks for all the advise, even at my age it's good the learn something every day. Boy have I learned much durning this whole process. wish me luck as the oil pump gets reinstalled --- again.
Starbucket Samba Member
Posted: Mon Mar 27, 2017 12:35 pm Post subject: Re: Oil pump gasket |
Never put sealant on pump cover as it will just squeeze into the gears and out the outside of the pump. I think it is more of a spacer for the proper clearance from the gears so use the wrong thickness and your oil pressure will drop if too thick and your cover will gall if too thin. |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1615 Location: Cleveland, Ohio
mr. lang Samba Member
Posted: Tue Mar 28, 2017 4:44 am Post subject: Re: Oil pump gasket |
VW had the opinion, to use only the original gasket which has 0.8mm/0.003". They especially address not to use any additional sealant.
The reason is, that the small oil return groove could be blocked up.
Don't forget to rotate the crank two times, with the oil pump screws slightly tightened, to align the pump. Then tighten them down with 7.37lbs for 6mm and 18.43lbs for 8mm, without shifting the pump. _________________ 1966 Bus | 1969 Bug | 1984 Golf 2 C (daily driver)
There are three kinds of people: those who can count and those who can't
Und läuft ... |
PeteSC Samba Member
Posted: Tue Mar 28, 2017 5:56 am Post subject: Re: Oil pump gasket |
I get the non-sealant argument (it didn't come that way from the factory, can clog, etc.), but just for the record - a "light coating" of Permatex gasket sealer spray can go on really thin and is intended to hold gaskets in place during assembly, with some small added layer of sealing between gasket and surface when tightened down. I don't think anyone is recommending a thick bead of sealer that can squish out the sides when tightened down. |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 15534 Location: NYC/Upstate/ROW
Posted: Tue Mar 28, 2017 4:54 pm Post subject: Re: Oil pump gasket |
Eric&Barb wrote: |
mandraks wrote: |
Thanks!  |
Wait till your my age, it Depends.... _________________ .ssS! |
Posted: Wed Mar 29, 2017 1:19 pm Post subject: Re: Oil pump gasket |
Thanks to all again. I did torque the nuts to the correct specs but did not rotate by hand. Seems to be running fine at present but time will tell.
Posted: Wed Mar 29, 2017 1:53 pm Post subject: Re: Oil pump gasket |
Most excellent! Have fun. _________________ In Stereo, Where Available! |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 12701 Location: Casa de Oro, California
Posted: Sat Apr 13, 2019 10:34 am Post subject: Re: Oil pump gasket |
Using this thread to ask this question.
How are the oil pump studs supposed to be. Are the stud holes blind such that the stud will bottom out?
I got my long block back from a rebuild and noticed the studs were at different protruding lengths.
I contacted the builder and he said the case was already like that and it was fine.
Should I double nut them and try to turn them in like the closest one? The picture doesn't really show that good but one is really far out, one next far out, one medium, and one close. |
Posted: Sat Apr 13, 2019 7:30 pm Post subject: Re: Oil pump gasket |
BarryL wrote: |
How are the oil pump studs supposed to be. Are the stud holes blind such that the stud will bottom out? |
Holes go thru.
Are those the stock studs or some custom lenght all thread replacements? If the latter, turning them in might end up hitting the cam gear.
Oil pump looks like one of those that puts out too much oil flow, so you end up with too much oil pressure. Which in turn messes up the oil pressure system so oil bypasses the oil cooler most of the time, even though the oil is plenty hot enough.
Personally would pull that pump out, get a CB Maxi 2 oil filter pump, and sort out the studs. _________________ In Stereo, Where Available! |
BarryL  Samba Member
Posted: Sun Apr 14, 2019 10:08 am Post subject: Re: Oil pump gasket |
Thanks for the reply.
Supposedly the studs are stock and original to that H block and according to the builder they were like that. The oil pump is supposedly stock style but new.
Since you say the holes are not blind I'll leave them alone. I feel so stupid; in all the time I had a case to view I never paid attention to the holes because they had studs installed, either the skinny ones or the fatter ones. |
