Fifty-Eight Rag Samba Member
Joined: September 07, 2011 Posts: 936 Location: St. Louis, MO
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
Posted: Wed Mar 29, 2017 4:00 pm Post subject: Re: Mechanical Advance Distributor ID |
It's a Bosch 010.
There were 2 versions, one with a VW part number and one without. They are identical. _________________ Glenn
Member #1009
#BlueSquare |
Glenn Mr. 010
Posted: Wed Mar 29, 2017 4:58 pm Post subject: Re: Mechanical Advance Distributor ID |
It original part used on the 59-1/2 to 60 Bastard 40hp engine in a Bus.
Prices for 010 cores range from $50 to $300. It just depends on how fast you want to sell it and how greedy you are. I've seen some 010 with high prices sit for years. Yours is missing the correct condenser bracket which will hurt its value.
It was never used on a Porsche.
I have a NOS one that I should sell because it's just sitting in a box under my workbench.
Member #1009
#BlueSquare |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Wed Mar 29, 2017 8:49 pm Post subject: Re: Mechanical Advance Distributor ID |
The "30" designation on these is still a bit of mystery. The date stamps I have seen on them were all mid 1960's, none for 1959/60. That would indicate parts counter replacement. The oldvolkshome website lists them for early 1950's 25 hp which is not correct. The badge is obviously the later design. The lack of a correct condenser clip should knock $25 off it's value. I don't generally pay more than $50 for one of these as a core but you see them priced a whole lot higher than that. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Jacks Samba Member
Joined: July 15, 2006 Posts: 2348 Location: San Clemente, Ca.
