Fitting 356 Oil filler into a 36hp engine - NEED HELP
grailoc
grailoc is online now
PostPosted: Tue Mar 07, 2017 8:03 pm    Post subject: Fitting 356 Oil filler into a 36hp engine - NEED HELP Reply with quote
Hi everyone,
I am trying to fit a 356A oil filler onto my 36HP engine.
I saw several old speed engine with the modification,
however I need help to understand how make this fit my 36hp case ?
Here are some picture of the oil filler I have:
It came with a 356 generator stand. Difference with a 36hp case is that the filler is just round and there is just one hole on the side to hold the filler on the case.
Any help or detailled pciture of the modification will be greatly appreciated.
Thanks for help.
My 59 low light ghia: http://www.thesamba.com/vw/forum/viewtopic.php?p=7852268
My 56 beetle convertible: http://www.thesamba.com/vw/forum/viewtopic.php?p=7796259
My 60 SO23 westy: http://www.thesamba.com/vw/forum/viewtopic.php?t=341539
Check my blog: http://us-road-trip-vw-bus.skynetblogs.be/
and my garage build thread: http://www.garagejournal.com/forum/showthread.php?t=199438
My other vehicles
KG 64
vespa 1961 Acma & spanish GT 160
2 Lambretta LI 150
2 1971 Honda CT70
cru62
cru62 is offline
PostPosted: Thu Mar 30, 2017 5:25 pm    Post subject: Re: Fitting 356 Oil filler into a 36hp engine - NEED HELP Reply with quote
I did that for an engine I'm building. I'll snap a pic of it when I get back home next week.
In the meantime I will try to describe what I did.
First I cut out two pieces of 3/16" aluminum plate to roughly match the shape of the mount for the filler. One got a stepped hole bored in it which matches the nut that attaches the stock filler to the block.
Then I made a second plate with a hole bored in it to fit over the mount for the filler base. There are holes to mount the filler through both fabricated plates using bolts.
I oriented the filler on the block so it was level and plumb and screwed in the special mounting bolt to the plate and attached it to the block. It is necessary to grind on the special bolt to clearance it. Just make sure you leave enough of the slot to remove it if you need to.
I contoured the two plates so that when everything is assembled it is smooth and blends with the mou on the filler. I'm undecided whether to paint the adapter black to make it blend in or polish it.
The one issue that I have now is that the dump tube wants to go through the rear tin in a different place than stock , so I will need to modify the tin. I think that would be easier than modifying the tube.
Sorry for the long winded response. When I get pictures it will all be clear, I promise.
Found a pic in my Gallery that shows the adapter sandwich, but not how the special nut is modified.-
Here's another one-
Sorry, I didn't realize that a 36hp oil fill is not threaded. Embarassed
"My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
Joshua B
Joshua B is offline
PostPosted: Thu Mar 30, 2017 9:40 pm    Post subject: Re: Fitting 356 Oil filler into a 36hp engine - NEED HELP Reply with quote
I did it on mine. You can look in my gallery I may have a picture. Take an exhaust flange, weld two nuts on it to bolt to the oil filler. Then weld a tab with a hole in it to the flange where it can be bolted onto the case like stock. I think I may have welded a sleeve in the inside of the flange so it fit snug to the case and snug to the outside diameter of the oil filler insert into the case. I will have to take a look. PM me if you need more info and some pictures.
grailoc
PostPosted: Sun Apr 02, 2017 6:56 pm    Post subject: Re: Fitting 356 Oil filler into a 36hp engine - NEED HELP Reply with quote
Thanks, that is a picture of your engine:
If by chance you are able to get the custom flange off the engine and take several pictures. Using the exhaust flange seemed a good idea, I this is what I will try to do as well.
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
grailoc
PostPosted: Mon Jun 12, 2017 7:31 pm    Post subject: Re: Fitting 356 Oil filler into a 36hp engine - NEED HELP Reply with quote
Hi everyone,
I wanted to give a good update on that thread.
I found an easy way to get a custom piece to hold the 356 oil filler by using a used J tube collector that I cut to about 1" from the end.
After that I have cut a custom bracket that a friend welded on the collector.
Now I just need to drill a hole on the bracket and use the screw from the original oil filler.
I will post additional pictures when the oil filler will be in place.
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
Mr. OGPaint Premium Member
Mr. OGPaint is offline
PostPosted: Tue Jun 13, 2017 10:10 am    Post subject: Re: Fitting 356 Oil filler into a 36hp engine - NEED HELP Reply with quote
I believe this is how Porsche attached the breather/filler on 2pc case engines
https://instagram.com/mr_ogpaint
Patrick Hall
grailoc
PostPosted: Thu Jun 15, 2017 7:23 pm    Post subject: Re: Fitting 356 Oil filler into a 36hp engine - NEED HELP Reply with quote
great setup. Oil filler seems from 356 pre-A
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
grailoc
PostPosted: Thu Jun 15, 2017 7:24 pm    Post subject: Re: Fitting 356 Oil filler into a 36hp engine - NEED HELP Reply with quote
Here is my final setup:
My other vehicles
KG 64
2 Lambretta LI 150
2 1971 Honda CT70
GHIA
GHIA is offline
PostPosted: Fri Jun 16, 2017 9:08 am    Post subject: Re: Fitting 356 Oil filler into a 36hp engine - NEED HELP Reply with quote
Great job JÚrome Applause
56samba
56samba is offline
PostPosted: Thu Nov 16, 2017 9:12 am    Post subject: Re: Fitting 356 Oil filler into a 36hp engine - NEED HELP Reply with quote
Looks pretty good, a clever solution...
Thanks for the "input" Very Happy
Just asking myself, what I can do to mount it on a pre56 engine without the drilled support on the case. Guess I should use a Pre A or stock VW oil filler?
---LOOKING FOR 25HP VINTAGE SPEED PARTS---
