1300 heads and 1300 manifold on 1200 40 hp engine
Pirulero1986
Pirulero1986 is offline
PostPosted: Wed Aug 03, 2016 1:01 am    Post subject: 1300 heads and 1300 manifold on 1200 40 hp engine Reply with quote
it's possible to use a sinlge port 1300 manifold on a 1200 40 hp engine with 1300 sp heads?
i want to know because 1300 manifold have a bigger diameter than the 1200 and the openings of the heads are different
thanks
michele
earthquake
earthquake is offline
PostPosted: Wed Aug 03, 2016 11:36 am    Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine Reply with quote
I think you can do it, if it was me I would try to find a set of DP 1300 heads, they were used on European motors.
Casey
74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
Kelly J. Nolte 3/20/53 - 11/6/08
http://www.rememberingkelly.com/
DEATH TO CHINGERS!
Robert Chambers
Robert Chambers is offline
PostPosted: Wed Aug 03, 2016 4:12 pm    Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine Reply with quote
The 1300 block is wider than the 40 block. Also the stroke is longer 69 mm verses 64 mm. So the 1300 intake manifold has to be wider than the 40 intake manifold. I guess you can do it by modifying the 1300 manifold?
'63 OG 117 Herbie Replica
'56 Euro Oval Deluxe
'52 Standard Zwitter
'63 OG 117
sgmalt46
sgmalt46 is offline
PostPosted: Thu Aug 04, 2016 12:52 pm    Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine Reply with quote
the 40hp case and the 1300 case are the same size i dont know what the other guy is talking about. Confused the motor is wider not the case.and i hate when they call a engine case a block! yes the 1300 heads and manifold will go right on. its a good upgrade. just need the 1300/1500/1600 cylinder tin.which makes the motor a little wider.has nothing to do witk the crank inside Confused
55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back
46 beetle
Robert Chambers
PostPosted: Thu Aug 04, 2016 1:52 pm    Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine Reply with quote
Sqmalt46 what I should have said is the case with the cylinders and heads installed is wider than the 40 horse. That is why the 1300/1500/1600 tins are wider. With a 69 mm crank the cylinders are longer. That is why the engine is wider. Therefore the 1300 intake is wider than the 40 hose intake. That was my intent. By the way when I said block, I meant the long block. That means the case with the cylinders and heads installed. And I do know what I am talking about. I am a former VW of America Unit Shop Mechanic. Cool
'63 OG 117
sgmalt46
sgmalt46 is offline
PostPosted: Thu Aug 04, 2016 2:55 pm    Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine Reply with quote
gotcha that makes sense Wink
64 crew cab
55 rag top beetle
66 beetle
71 square back
46 beetle
johnr156
johnr156 is offline
PostPosted: Thu Aug 04, 2016 4:20 pm    Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine Reply with quote
Does the angle of the intake port on the head come into play? I'm not certain when VW started putting the 20 degree angle on the heads.
Robert Chambers
PostPosted: Thu Aug 04, 2016 5:29 pm    Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine Reply with quote
Yes, 1966 1300 type 1 was the first type 1 angled. I think 1963 type 3 started the angled intake. Not sure about type 2. I think 1963 1500 type 2 was angled? That was the early 1500 engine similar to the 1967 type 1 if I remember correctly. Question
'63 OG 117
PostPosted: Thu Aug 04, 2016 11:07 pm    Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine Reply with quote
'63 Type 3s are angled, '62s are not.
'63 1500cc Bus is angled.
Mr. Motorhead
Mad Scientist
Mr. Motorhead is offline
PostPosted: Wed Aug 10, 2016 12:08 pm    Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine Reply with quote
Casey
Just in case anyone is interested, I have a pair of freshly built 1300 DP heads that don't have a home. PM me for a price if you want them.
30 years experience in the sales of new and used auto parts!
36 horsepower parts for sale at http://www.aircooledresearch.com/
Or the new site at http://www.bugparts.com
Check out the Bonneville project:
http://aircooledresearch.com/docs/thebonnevilleproject.html#
"All limitations are self imposed."
Some Chinese guy
k9hdlr
k9hdlr is offline
PostPosted: Sun Apr 02, 2017 12:35 pm    Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine Reply with quote
Mr. Motorhead wrote:
Casey
Do you still have the DP1300 heads?
k9hdlr
k9hdlr is offline
PostPosted: Tue Apr 04, 2017 2:11 pm    Post subject: Re: 1300 heads and 1300 manifold on 1200 40 hp engine Reply with quote
I read somewhere that the top headbolts needed to be longer to properly fit the 1300 head on my 1200 40hp. Is that right? Or no? Be nice if it just fits.
