Engine compartment seal
ldj1002
ldj1002 is offline
PostPosted: Mon Apr 03, 2017 1:02 pm    Post subject: Engine compartment seal Reply with quote
I bought engine compartment seal and installed with engine in. Problem is the lower lip that goes over engine tin won't fit, tin is too high and the lip barely goes in the rubber and won't stay. Before I bought the seal I got water pipe insulation and it works great except where close to exhaust it melts. I've read to get seal for bus that it is foam. Will it melt where close to exhaust? How does it fit. Does it seal good? Looks like the way it is made it would be wavy going around the curve. Anyone know where I can get something like that water pipe insulation that won't melt. That stuff sealed good and looked good.
Boy I would have been mad if I had pulled engine and still couldn't use the seal.
Al Capulco
Al Capulco is offline
PostPosted: Mon Apr 03, 2017 6:07 pm    Post subject: Re: Engine compartment seal Reply with quote
A picture would help, but my seal goes under the tin not over.
ldj1002
ldj1002 is offline
PostPosted: Mon Apr 03, 2017 8:04 pm    Post subject: Re: Engine compartment seal Reply with quote
My seal also goes under the tin but over that lip that hangs down under the tin.
74 Thing
74 Thing is offline
PostPosted: Mon Apr 03, 2017 10:02 pm    Post subject: Re: Engine compartment seal Reply with quote
Late Bus foam engine seal....
https://www.thesamba.com/vw/forum/viewtopic.php?t=607161&highlight=bus+engine+seal
GI Joe
GI Joe is offline
PostPosted: Tue Apr 04, 2017 3:50 pm    Post subject: Re: Engine compartment seal Reply with quote
Sounds like you may have it in upside down....(?).
I did this on mine, and it was caught by my mechanic during dual carb tuning..
Just a thought.
'74 Thing, "Our Thing"....Blue 181
http://www.thesamba.com/vw/forum/viewtopic.php?t=4...p;start=60
'71 Beetle RPU
http://www.thesamba.com/vw/forum/viewtopic.php?p=8080337#8080337
www.NLEOMF.com
Respect, Honor, Remember
mondshine
mondshine is offline
PostPosted: Tue Apr 04, 2017 5:07 pm    Post subject: Re: Engine compartment seal Reply with quote
ldj1002
ldj1002 is offline
PostPosted: Tue Apr 04, 2017 8:16 pm    Post subject: Re: Engine compartment seal Reply with quote
mondshine wrote:
Don't have it upside down. I have it exactly like this drawing, in fact I used a print of this out at the car. Looking at the photo, the far left part of the seal where it goes up into the engine tin is where it doesn't go far enough or tight enough to hold. It comes out and like an accordion bellows goes back against it's self where it is in the channel on the body. I have ordered the seal for a bus. Too bad the pipe insulation couldn't take the heat because it worked great and looked good.
74 Thing
74 Thing is offline
PostPosted: Wed Apr 05, 2017 7:37 am    Post subject: Re: Engine compartment seal Reply with quote
Yes, I wish the seals were wider and more rigid. I have read that some of the aftermarket seals are too narrow, but have not been able to confirm myself.
911pickup
911pickup is offline
PostPosted: Wed Apr 05, 2017 8:39 am    Post subject: Re: Engine compartment seal Reply with quote
I just ordered a front seal for my Thing. I'm in the process of pulling out the old seal-what's left of it-and it sure doesn't want to come out.
ldj1002
ldj1002 is offline
PostPosted: Mon Apr 10, 2017 2:27 pm    Post subject: Re: Engine compartment seal Reply with quote
I ordered seal for bus, it came today and I got it in. It looks good and I drove it about 8 miles and the seal hasn't melted yet. The seal gets about 1" from closest J pipe. Does anyone know how close the seal would get to any part of exhaust on bus
oasis
oasis is offline
PostPosted: Tue Apr 11, 2017 10:07 am    Post subject: Re: Engine compartment seal Reply with quote
I don't know but searching the Type 2 threads and gallery, it doesn't look to be that close to me. It seems they last 5-8 years. So, if six years from you need another, you probably just need another.
Now: 2003 New Beetle Turbo S / 1990 Single Cab Transporter / 2014 Tiguan R-Line 4motion / 2013 Tiguan S / 2002 Golf GLS TDI
Past: 1974 Thing Acapulco / 2009 Eos Komfort / 1997 Jetta GT / 2002 Cabrio GLX / 2002 Passat GLS / 1971 Super Beetle / 1993 EuroVan MV Westfalia / 1981 Pickup LX / 1985 Vanagon / 1986 Jetta GLI
