llilibel03 Samba Member
Joined: February 03, 2008 Posts: 767 Location: Redondo Beach California
Posted: Wed Apr 05, 2017 8:20 am Post subject: Honeymoon's over... |
Actually it never got started...
After searching for a long time I finally found an 85 Westy in my price range. It is a TIICo so that raised my eyebrows, but it was in such nice condition and ran perfectly during the test drive........
Well it didn't pass smog. Ever so slightly high NOS level. So I brought it to my mechanic. I also asked him to look at the brakes as it took a lot more effort to stop than my GL. Maybe because it's a camper? I've never driven a Westy before. Well, he had to replace both discs and drums, pads and front wheel bearings.
The van had been non operational for a year, then the PO registered it (it passed smog last year) and only put 200 miles on it this year. So I thought maybe it just needs to be run for a while before I tried to smog it again. My mechanic said it ran fine and the smog numbers were really close. So yesterday I took it on a freeway run....
First off, it was nearing the end of the "green zone" of the tach (3800rpm) and only going 60 mph. Does that sound right for an automatic transmission's gearing? (I've only had manuals, my GL would do 65mph at about 3500). To go 65 mph I will out of the green zone, over 4000 rpm. Doesn't sound like a good place to be for long distance cross country travel. Oh well, guess I'll be going slow?
Then, today it would not shift into third. 40 mph max. Guess I'll be going really slow! Actually, I guess I have to get the trans (automatic) checked before I can see if I need a need catalytic converter. So much for staying in my price range.....
Any advice about the trans or getting it to pass smog? |
Tobias Duncan Samba Member
Joined: January 15, 2013 Posts: 1390 Location: Taos NM
Posted: Wed Apr 05, 2017 8:50 am Post subject: Re: Honeymoon's over... |
That engine has a much higher redline than the waterboxer so the tack green zone is shifted.
Automatics are geared lower than standards so yes , they need to be run at higher RPMs.
If you are on a budget you really need to be doing things like brakes yourself.
These vehicles need maintenance and having a mechanic do it all is for people without budget constraints. |
bluebus86 Banned
Posted: Wed Apr 05, 2017 9:26 am Post subject: Re: Honeymoon's over... |
high NOx may point to a bad egr valve, if that engine is so equiped. It can also be an indication of over heating, is the cooling system fine? also could be a worn out catalyst
good luck _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
danfromsyr Samba Member
Posted: Wed Apr 05, 2017 9:29 am Post subject: Re: Honeymoon's over... |
ok a few things..
yes VWs make their owners the mechanics.
on the I4 and rpms. the redline for that motor is ~65oorpms. it'll be fine at 5k all day long..
it's possible that your Automatic has suffered an internal seal and can't attain 3rd gear. we had this on mom's stock 86 when we 1st got it.
but you can check the custom linkage arrangement for proper adjustment and function. print/read this manual VW 010 ATs are essentially the same from 1975-1992 https://www.thesamba.com/vw/archives/manuals/1975_010_transmission.php
http://www.cabby-info.com/Files/010TroubleshootingManual.pdf
the AT linkage needs to be checked and adjusted
lastly how the throttle is connected on a Automatic is very important to it's proper operation. in stock form the gas pedal is connected to a relay lever on the transmission via the throttle cable. then the relay lever is connected to the (FI) throttle body as a solid linkage with a spring that allows a little more pull for proper kickdown operation.
now sure some will say you can just pull the shifter into 2 to kickdown. it's almost essentially the same thing. except that the relay lever effects the shift points and 'crispness' of the shifts and if left unattached can cause either hard/harsh shifts or the opposite in soft slipping shifts that WILL burn out your clutches inside the AT transmission.
on our engine swapped vanagon AT we have 2 cables from the pedal, one to the T-body and 1 to the relay lever.
but you must give this some proper thought and understanding or you'll be back repairing more items. _________________
Abscate wrote: |
Posted: Wed Apr 05, 2017 10:06 am Post subject: Re: Honeymoon's over... |
Thanks for the tips. I'll try running the car at 4500-5000rpm and see it how it feels...if I can get it to go into 3rd.
Growing up, my Dad had a Porsche 356 and he did all the work on it himself (Dad was an engineer...I'm an art teacher). I used to watch and pass him wrenches and what not. But that was when I was in elementary school...
In college I decided to follow in my Dad's footsteps and start fixing my own cars. The first job I tackled was to change the brakes of my truck. After completing the job they reaked of burn and were toast after about 10,000 miles. That was the end of my mechanical career....
I've had two other vanagons (for the last 15 years) that have been very reliable and never forced me to obsess about mechanical issues. This one, being a TIICO and all may force my hand.....
Posted: Wed Apr 05, 2017 10:11 am Post subject: Re: Honeymoon's over... |
If you have any skills at all, being a part time mechanic is way easier in the age of youtube and forums like this.
A few successes may make the process far more enjoyable. |
Posted: Wed Apr 05, 2017 10:16 am Post subject: Re: Honeymoon's over... |
Tobias Duncan wrote: |
When I think back the the time I changed my brakes I have no idea how I did it. I think I just started taking things apart and tried to put them back together the same way, albeit with new brake pads. There was no internet back then....
Time to invest in a tool kit??? |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22641 Location: NYC/Upstate/ROW
Posted: Wed Apr 05, 2017 10:25 am Post subject: Re: Honeymoon's over... |
My first Bug was a 66 that I did the same thing with the engine. No Muir book back then either _________________ .ssS! |
Posted: Wed Apr 05, 2017 10:38 am Post subject: Re: Honeymoon's over... |
Never been a better time to buy a tool kit either.
Cheapo tools used to be such garbage that they were not worth owning.
Now you can get passable tools for a fraction of what professional tools cost and the gap in quality is much much smaller. |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Wed Apr 05, 2017 10:42 am Post subject: Re: Honeymoon's over... |
Sound par for course on a new van. No one sells them if they are still using them and fixing stuff. A new Cat will solve the smog problem. Maybe you will need a new transmission, be thankful your engine is working well. And yep, RPM sound about right, I cruise at 4200 all day long. Take a deep breathe, there will be more as you drive it and dial things in. |
Posted: Wed Apr 05, 2017 11:00 am Post subject: Re: Honeymoon's over... |
davevickery wrote: |
You have the Tiico? |
Zeitgeist 13 Samba Member
Posted: Wed Apr 05, 2017 11:15 am Post subject: Re: Honeymoon's over... |
Does your Tiico have an oxygen sensor? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Chainsaw Samba Member
Joined: August 07, 2015 Posts: 249 Location: Issaquah Washington
Posted: Wed Apr 05, 2017 11:24 am Post subject: Re: Honeymoon's over... |
Get a good manual and just follow step by step, you'll run into issues where the book is vague, thats where youtube/ thesamba etc come in. And dont rush trying to get stuff done, know when to walk away and let your frustrations burn off. You'll save a ton of money and feel really good. _________________ 89 Westy. 2wd. Manual. |
70coupyel Samba Member
Joined: September 06, 2006 Posts: 1657 Location: So.Cal
Posted: Wed Apr 05, 2017 11:50 am Post subject: Re: Honeymoon's over... |
Wait Tiico's are smog legal in Calif? Llilibel does your van have a BAR sticker? _________________
TheAndante wrote: |
Saying that specs are different than dimensions doesn't make sense. Porsche specs/VW specs/engineering specs are nothing but a series of dimensions,sizes,percentages,measurements, etc. |
http://www.thesamba.com/vw/forum/viewtopic.php?t=338946&highlight=
70 KG Coup
83 Westy Waterboxer |
Posted: Wed Apr 05, 2017 1:48 pm Post subject: Re: Honeymoon's over... |
70coupyel wrote: |
Wait Tiico's are smog legal in Calif? Llilibel does your van have a BAR sticker? |
They are approved. The owner gave me a copy of the exemption letter. |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2795 Location: North Carolina
Posted: Wed Apr 05, 2017 3:22 pm Post subject: Re: Honeymoon's over... |
Try calling van-cafe, checking roadhaus and calling shops that rate well on there, or just posting here seeking a place that knows Tiico's maybe? Or is there a local club or forum like fullmoonbusclub here in the SE?
When I got my van, I ended up spending a number between 1-2000 dollars at a good shop to get it to a safely driveable baseline, then I started working on making things better...an ongoing process all the time, but it's part of the fun for me. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Thu Apr 06, 2017 9:04 am Post subject: Re: Honeymoon's over... |
Update- was told I need a new transmission. $1400-1800 was my quote... Will find out more this afternoon.... |
jkallo Samba Member
Posted: Thu Apr 06, 2017 10:22 am Post subject: Re: Honeymoon's over... |
llilibel03 wrote: |
I have generally avoided automatics, but a few years back I found a good deal on a BMW that I really wanted. It was an automatic, but I bought it anyway. The transmission went south about 3 weeks after I got it. I feel your pain! _________________ I'm Joe
The bus is Gus, the 1982 Westy Diesel 1.6na |
metropoj Samba Member
Posted: Thu Apr 06, 2017 10:46 am Post subject: Re: Honeymoon's over... |
Well at least being a TiiCo will have no bearing on your tranny problems.
You most likely need a full education on the whole TiiCo system to figure out where you are, where you need to be with respect to its one off Motronic injection, proper timing setting, and piles of other solvable problems, etc.
Post some pics of your engine bay so we can see what you got yourself into , give your ECU ( what RSU### ### # number is on the ECU) and you need some special tools to properly set the injection and timing via a laptop computer.
I suggest to join the Yahoo Groups TiiCo page. There are some great people that can help answer questions.
Welcome to Flavor Country ! Don't fear the TiiCo. There will be costs involved in upgrading it or repairing it however. _________________ John.
86 TiiCo powered Westy. |
