74superTN Samba Member
Joined: April 01, 2007 Posts: 675 Location: Port Saint Lucie, FL
Posted: Sun Apr 02, 2017 5:12 pm Post subject: Best place for rear lowering spring plates? |
So I checked out the search but couldn't find anything...What company is everyone using for rear spring plates? _________________ 73 Thing
80 Vanagon Westy |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Mon Apr 03, 2017 4:27 am Post subject: Re: Best place for rear lowering spring plates? |
Stock, just re-indexed. |
Posted: Mon Apr 03, 2017 8:23 am Post subject: Re: Best place for rear lowering spring plates? |
Bashr52 wrote: |
Doesn't that ride like crap? _________________ 73 Thing
80 Vanagon Westy |
Posted: Mon Apr 03, 2017 10:34 am Post subject: Re: Best place for rear lowering spring plates? |
74superTN wrote: |
Bashr52 wrote: |
Doesn't that ride like crap? |
What are you trying to accomplish? |
GI Joe Samba Member
Joined: April 28, 2005 Posts: 2012 Location: Athens, TN
Bruce Samba Member
Posted: Mon Apr 03, 2017 7:44 pm Post subject: Re: Best place for rear lowering spring plates? |
74superTN wrote: |
Bashr52 wrote: |
The ride is exactly the same as if you put some zig-zag spring plates on it. Don't fall for their marketing bullshit. _________________
63ziggy Samba Member
Joined: June 19, 2005 Posts: 1100 Location: The Woodlands, Texas
Posted: Tue Apr 04, 2017 2:29 pm Post subject: Re: Best place for rear lowering spring plates? |
I went opposite with raised plates from Atomwerks. Essentially same as lowering plates they sell/sold. I got them early on in their days. No issues, retained stock ride function without the pre-load on torsions(re-indexing).
Note: The company had gone from independent seller to Mid America selling their products. With that said, there has been a ton of drama surrounding company etc. Not going there. not sure if they are still in business and selling.
it is basically a z-plate design |
Posted: Wed Apr 05, 2017 8:53 am Post subject: Re: Best place for rear lowering spring plates? |
I looked at AtomWerks website and I guess you have to call to make an order. I'm just looking to lower my rear to even out with my already installed beetle beam _________________ 73 Thing
80 Vanagon Westy |
waxhead Samba Member
Joined: January 19, 2004 Posts: 946 Location: Philly 'burbs
Posted: Wed Apr 05, 2017 10:04 am Post subject: Re: Best place for rear lowering spring plates? |
I found a set in the classifieds and installed them on my '74. The advantage is that you can fine-tune the ride height a lot easier than messing around with re-indexing (which is what I tried initially). _________________ Mike B. |
Posted: Wed Apr 05, 2017 10:30 am Post subject: Re: Best place for rear lowering spring plates? |
74superTN wrote: |
I looked at AtomWerks website and I guess you have to call to make an order. I'm just looking to lower my rear to even out with my already installed beetle beam |
As others said the effective geometry of lowering or raising plates is the same as the stock system. Your money would be better spent on new torsion tube bushings and reindexing the bars. |
Posted: Wed Apr 05, 2017 12:58 pm Post subject: Re: Best place for rear lowering spring plates? |
Alright so AtomWerks looks to be out of question.....
Any other companies sell them? I just keep hearing that reindexing makes your Thing ride worse that spring plates _________________ 73 Thing
80 Vanagon Westy |
Shoyrtt Samba Member
Joined: August 21, 2010 Posts: 1009 Location: Redlands, CA
Posted: Wed Apr 05, 2017 4:21 pm Post subject: Re: Best place for rear lowering spring plates? |
Perfect, thanks! _________________ 73 Thing
80 Vanagon Westy |
Posted: Thu Apr 06, 2017 10:29 am Post subject: Re: Best place for rear lowering spring plates? |
74superTN wrote: |
Perfect, thanks! |
Are you talking about adjustable plates or those Z shaped "drop plates"? |
Posted: Thu Apr 06, 2017 4:53 pm Post subject: Re: Best place for rear lowering spring plates? |
Bashr52 wrote: |
74superTN wrote: |
Perfect, thanks! |
Well I was talking about those Z shaped drop plates but it looks like those are out of the question. AtomWerks has gone out of business.... Adjustable plates and reindexing looks to be my only option _________________ 73 Thing
80 Vanagon Westy |
Posted: Mon Apr 24, 2017 12:17 pm Post subject: Re: Best place for rear lowering spring plates? |
Ok so I lowered the rear of my Thing by adjusting splines. Is it normal for there to be no tension on the torsion bar after this? _________________ 73 Thing
80 Vanagon Westy |
Posted: Mon Apr 24, 2017 3:08 pm Post subject: Re: Best place for rear lowering spring plates? |
74superTN wrote: |
Ok so I lowered the rear of my Thing by adjusting splines. Is it normal for there to be no tension on the torsion bar after this? |
Not sure what you are talking about. How many splines (inner and outer) did you change it by? A few of splines one way on the outer and a few the other way on the inner will make a big difference in ride height. |
Posted: Mon Apr 24, 2017 6:16 pm Post subject: Re: Best place for rear lowering spring plates? |
Nevermind I'm dumb. I was talking about the preload but it's not preloaded anymore because I'm not resting on the stops. _________________ 73 Thing
80 Vanagon Westy |
sidemarkers Samba Member
Posted: Sat Nov 11, 2017 9:21 pm Post subject: Re: Best place for rear lowering spring plates? |
From an IRS type 3 standpoint I recently switched to the atomwerks 3 inch drop plates. Keep in mind this is coming from someone who has driven daily for the better part of 25 years and indexed both raised and lowered with IRS. The improved ride quality and handling characteristics with the atomwerks plates vs stock plates indexing 2 splines is almost unbelievable. |
Bruce Samba Member
Posted: Mon Nov 13, 2017 7:05 pm Post subject: Re: Best place for rear lowering spring plates? |
sidemarkers wrote: |
... is almost unbelievable. |
That's because there's no difference.
Any improvement is all in your mind. Or you did other changes at the same time.
The spring plate is only a connecting link between the torsion bar and the TA. The shape of this rigid connection is irrelevant. _________________
