crazyvwvanman Samba Member
Joined: January 28, 2008 Posts: 9923 Location: Orbiting San Diego
Posted: Fri Apr 07, 2017 7:16 pm Post subject: Unusual thermostat failure, causes breakdown |
A family member called, his Vanagon broken down nearby. He said he parked it and then noticed it had made a trail of fluid and was dripping still. The coolant tank was empty and adding some just made the leak faster. It appeared to be coming from the water pump area but not the shaft seal.
After taking it apart it became obvious what had happened. The thermostat came apart and the small disc on the end went into the blades of the water pump. The pump spun it around and it wore a groove into the housing until it wore through and the coolant leaked out.
This van has a VW inline 4 cyl engine.
The thermostat says "made in USA" on it.
Mark |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Fri Apr 07, 2017 8:16 pm Post subject: Re: Unusual thermostat failure, causes breakdown |
I'm surprised that the metal on metal didn't make an interesting noise picked up by the driver. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
furrylittleotter Samba Member
Joined: May 19, 2008 Posts: 1506 Location: West Seattle
Posted: Fri Apr 07, 2017 8:43 pm Post subject: Re: Unusual thermostat failure, causes breakdown |
He's a lucky guy to have you nearby to help!
That corrosion looks sketchy. Wrong coolant or not changed often enough? Think that contributed to tstat failure?
Send us some sunshine ☀️
Neil2 |
Robw_z Samba Member
Posted: Fri Apr 07, 2017 10:12 pm Post subject: Re: Unusual thermostat failure, causes breakdown |
I disassembled an I4 waterpump which had the housing filled in with JB weld, due to presumably an instance such as this.
-Rob |
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Fri Apr 07, 2017 10:17 pm Post subject: Re: Unusual thermostat failure, causes breakdown |
crazyvwvanman wrote: |
The thermostat says "made in USA" on it. |
"Well, there's yer problem!" -Adam Savage _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
