SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1109 Location: New Brunswick,Canada
lhwood Samba Member
Joined: August 14, 2012 Posts: 70 Location: san diego, ca
Posted: Fri Apr 07, 2017 11:31 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Just a thought. Check your trans after you get out of the car. There have been poster who have their trans oil bubbling after a drive.
Cheers |
williamM Samba Member
Joined: August 07, 2008 Posts: 4333 Location: southwest Arizona
Posted: Fri Apr 07, 2017 9:03 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
That sounds like a bad regulator- check the water level and put a voltage gauge on the battery with motor revved up a little. _________________ some days I get up and just sit and think. Some days I just sit.
opinion untempered by fact is ignorance.
Don't step in any! |
Posted: Sat Apr 08, 2017 7:03 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
williamM wrote: |
That sounds like a bad regulator- check the water level and put a voltage gauge on the battery with motor revved up a little. |
That's what I was afraid of, I noticed last night that when I use my turn signals, it intermittingly flashes with the blinker indicator light?
Do the replacement units fit inside the original housing or is the replacement regulators a self sealed (housed) unit? _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
Posted: Sat Apr 08, 2017 7:22 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
I've seen both the sealed unit with a pigtail connector for the original VW connector, and a few NOS originals here on the classifieds.
seems Stu had one that was adjustable for voltage. _________________ some days I get up and just sit and think. Some days I just sit.
Posted: Sat Apr 08, 2017 6:52 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
you can use the 70 amp alt with the 55 but the regulator will stop the out put at 55 if you go the other way- the alt will eventually be over worked and fail/--I've been told--- not having done it myself-- They have different cooling boots too. _________________ some days I get up and just sit and think. Some days I just sit.
Posted: Wed Apr 12, 2017 6:17 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Yowza!
Yesterday before heading over to Bob's shop, I checked the voltage on the main battery while idling, 16.9v. Scared enough with that, I don't even want to know how high it was revving through gears!
Once arrived, chitchatting about the good ole days when you could by a complete KD motor complete from clutch to exhaust for $400 in a crate from VW dealers, Bob handed me an original Bosch unit regulator.
A few minutes later, voltage running was at 13.5v, good signs of hopefully my voltage woes. Checked again today. All good. Aside...(always has to be something else) I do believe the bus motor is running a little warmer, possibly with correct, even voltage? The past few months I've had an issue with dieseling upon shut off, all last night and today, no dieseling.
Reason being again, besides the warmer motor, I'm getting a light smoke coming up from the passenger side air scoop.
I'm thinking oil on the heat exchanger, plausible?
Battery is no longer getting hot, or crazy voltage on and off, so naturally, I now have a new concern! _________________ The Bus Barn Ltd. Co.
Posted: Thu Apr 13, 2017 12:31 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
With the installment of a new, correctly functioning voltage regultor, the engine was amiss. Shakey and flat.
Getting out my timing light along with my awesome tachometer, idle was high (1,100rpms) and timing was 12* ATDC.
Time for some adjustments.
Idle is now at 900-925, with timing at 8* ATDC. Book calls for 10* but I swear by it, the engine likes it between 6-8*, keeping it there with summer approaching.
Heber Springs show in two weeks, checked thermostat, trans bolts, valve covers, removed bottom tins to inspect push rod tubes, and while messing with everything else, I finally swapped out my leaky oil pressure sending unit.
Amazing what one change can do to the performance of the engine. It needed to be done anyhow, compliance can be a burden on the tail end.
Cheers, _________________ The Bus Barn Ltd. Co.
Posted: Sat Apr 29, 2017 4:47 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Though it never monsooned as projected, the forecast kept a lot of folks home, so the turn out was pretty poor.
But with limited numbers comes delightful surprises!
Now I feel like a fool, but rather than accepting recognition for best bus in the show (I was the only one present in Bay Window) I accepted this monumental trophy as recognition of my hard work, my dedication, and my pride of putting effort forth for resurrecting my bay window!
This was yesterday, headed out for my two hour drive to my campsite next to Greers Ferry Lake.
Met a few good folks, learned a new campsite, and brought home first place!
With weather cooperating next year, I hope to see the typical 70+ cars, and bring it home again! _________________ The Bus Barn Ltd. Co.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51155 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Apr 29, 2017 5:51 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Congratulations on bringing home the hardware!
SamboSamba22 wrote: |
Book calls for 10* but I swear by it, the engine likes it between 6-8*, |
Please remove both hoses from the distributor and rev it until it won't advance any more (likely ~3500 RPM), hopefully it stops at 28*-30*, any more and your engine won't like it for long. The idle timing doesn't count unless you never touch the gas pedal when driving _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
curtp07 Samba Member
Posted: Sun Apr 30, 2017 6:21 am Post subject: Re: Should I buy this bus?!? '74 Campmobile |
Sam I hate to break it to you...that's a Beetle _________________ Subaru |
Posted: Sun Apr 30, 2017 5:32 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
The only I don't like is with the idle noted, the resting or idling timing reads 12* ATDC. |
If it idles OK don't worry, the high speed advance is what will kill it if it's wrong. I wonder if the retard stop is damaged or someone has swapped in an incorrect vacuum can on the distributor?. -12 sounds pretty close for a 74 though, to comply with smog laws VW retarded the idle to increase flow and get the exhaust good and hot while idling, it may be what the distributor is meant to do. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Apr 30, 2017 6:29 pm Post subject: Re: Should I buy this bus?!? '74 Campmobile |
I had Bill rebuild the correct 205 distributor. NOS canister from a guy off the classifieds here out of Ohio.
Stock with California emission timing was 10* ATDC.
Last time I timed the distributor (hoses on) I had as mentioned 6* ATDC, and the drivability and torque was noticeable, but so was a warmer dipstick.
Also noted that the bus seemed to consume (a very minor oil leak out of the fuel pump), 3/4 quart of oil over 200 miles. Lots of hills and downgrades, seems like I was running warming this past weekend than I thought. _________________ The Bus Barn Ltd. Co.
